how much will a tuned chip help?
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
look at my sig, this is current times with my mods, if i got into chip burning and tuning it, how much faster you think i can get?
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
Transmission: 700R4 2500 stall
about ure chip question
save ure money to much advance for nitrous even a custom one save ure money or get a boost retard box
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
well i say for u get a set of tires bfg drags about 135 each and somthin else to take a lil time off a torque converter theres 300 and if u havent got a set of march pulleys u cant go wrong with that either under a 100 and summit has it all so just in tires and converter u can knock off a about a solid half second theres mid 12 and well if u up ure shot on nos like 150 deep 12 or high 11z time for a cage lol and if ure wonderin well i be at sac i have the blue iroc z and my buddy has the grey one with the blue hood and nose best on mines 13.6 him 13.8 but he can get it down hes gettin a set of tires more consistent and well me mines down for the month went 2 sac last weds night but ill be outthere in about 3 weeks up and runnning again
Car: '02 Z06
Engine: L33 5.7
i think i met you out thier, the 350 swapped in right? and cam and ****?
we can go their together sometime. in those 3 weeks maybe, my tires are way bald, but i want to pull my times on street tires.
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
hmm all i gota say is good luck on street tires hmm i cut 1.8 60 i did that on bifg drag radials and know i run et streets e t streets are more consistint but for the money the bfg thats what im guna buy again look nicer and well thats what works ill be out there i n about 2 weeks im sure i have my car apart right now i just got a base AND CONVERTER for mines . runners throttle body that give much of a gain and a chip save ure money dont bother u can tune on it ureself JUST HAVE URE TPS DIALED IN AND URE TIMING AND RIGHT AMOUNT OF FUEL PRESSURE I NOTICED 50 52 ON STOCK INECTORS AND WELL EVERYBODY I KNOW THAT UPGRADES THERE INJECTORS RUN SLOWER EVEN WITH AN ADJUSTABLE FUEL PRESSURE REGULATOR CANT TURN THE PRESSURE DOWN ENOUGH
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
JUST GET SOME TIRES ILL BE BACK AT THE TRACK BY THE END OF THE MONTH IM SURE I DUNNO HOW ITS GUNA RUN B UT HEY ILL MESS WITH IT GOTA DIAL IT IN BUT I GOT A STALL AND A BASE FOR MINES KNOW
Car: '91 Formula
Transmission: TH350 built
I paid a guy I know like $90 to tune a chip specifically for my car. This is what you need to do, not buy one off the shelf. This involves driving with the computer connected to the car and then modifying the chip based on the data, then doing this several times till you get the optimum setup. This was good for about 2 tenths for me, which is pretty good bang for the buck I would say
ramicio
Sep 28, 2015 01:18 PM
