Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
wheels up!!
Old Jul 27, 2005 | 08:08 AM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
wheels up!!
hey its been awhile, but with the tubular front end the car is now pulling the wheels consistantly......but still not going quicker.....some tuning to be done i guess.
heres the pic
Car: '91 Camaro RS
also psyched to see rear end lift instead of squat
at least my suspension is working right
Old Jul 27, 2005 | 08:24 AM
turbotater's Avatar
what type of rear suspension changes have you
made to see a difference ?
nice launch
Old Jul 27, 2005 | 08:36 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
nice launch, I dont think Ive ever seen a pic of a 3rd gen pulling the wheels with full size front tires. What kinda times are you running?
Old Jul 27, 2005 | 09:40 AM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Nice launch, that car looks kickass.
Old Jul 27, 2005 | 12:55 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Nice pic...its always great to see a thirdgen with the front wheels up.
Old Jul 27, 2005 | 03:36 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
Just curious how much weight did the tubular K member take off? Do you have the tubular A arms too?
Old Jul 27, 2005 | 08:29 PM
Car: '91 Camaro RS
nice launch
well for starters it has south side machine lift bars, no torque arm
that has a lot to do with how straight and level it launches
hotchkis lca's, and panhard rod, eibach drag launch springs front and rear, koni adjustable struts and shocks all urethane bushings
PA racing tubular K member and a-arms
Old Jul 27, 2005 | 08:33 PM
Car: '91 Camaro RS
car ran a best of 11.89 at 117mph last year
and its damn near 100lbs lighter this year, with the tubular front end, and i personally lost about 30lbs since last year.
i've also changed transmissions from a tremec TKO II to a tremec 600
getting a 2.87 1st gear instead of the 3.27 it had before......
so the car should run quicker and faster, but it seems to need a good flogging/tuning on the dyno, as its best this season is 11.94
but it was only at 115mph, so its running quick with less mph than before, which shows the weight loss (as does the air under the tires lol....so once i get it tuned up and making power again, 119-120mph traps should be where its at....hopefully 11.7 if not better then
Old Jul 27, 2005 | 08:34 PM
Car: '91 Camaro RS
should be about 60lbs or so with the a-arms......its significant......i had them both next to each other and picked them up......and it was impressive....although i didn't weigh them
i have both the k frame and a-arms
the glossy print of this picture is amazing in detail, you can see the wrinkles on the slicks and everything
Old Jul 27, 2005 | 08:52 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Cool pic. Nice to see the big tires up in the air!
Old Jul 27, 2005 | 09:17 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
Nice launch, glad to see the tubular stuff is working for someone. I had the opposite effect happen, here's me with the tubular front end(best 60ft 1.55 pumpgas)
And here's w/the stock stuff back in(new best 60ft 1.51 pumpgas and 100# heavier)
Same tires and everything
Anyhow, nice pic
Steve
Old Jul 28, 2005 | 05:53 AM
84firebird383's Avatar
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
TTA850,where did you get that cowl hood? I want something like that. Is it a 2" ?
Old Jul 28, 2005 | 06:00 AM
stroked1990RS's Avatar
Car: 1988 formula 350
Axle/Gears: 373
thats funny how you pull the wheels with a 100 pounds of exta weight in the front? you would think it would have just pulled them a lil higher with the new K-member.
Old Jul 28, 2005 | 07:05 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
what rpm do you lauch it at with the manual. Im in the the process of going from a th350 to a manual. just wondering cause mine didnt pull the wheels with auto and runs similar times (7.50 1/8 mile with stock gear)
Old Jul 28, 2005 | 08:27 AM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
Nice wheels up launch.
Good looking car as well.
Old Jul 28, 2005 | 10:55 AM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
It's a Harwood I got from Jegs, P/N 487-B20101. They call it 3" but I think it's shorter.
Old Jul 28, 2005 | 06:12 PM
Car: '91 Camaro RS
used to be between 4600 and 5000 with the old 3.27 first gear
with the 2.87 1st it seems to want to be launched around 5100.....
the variance is depending on track conditions (prep quality)
i used a 2-step so its consistant from pass to pass.
of course the motor has alot to do with it as well, i make peak power at about 6600 rpm.
i have a nasty stumble coming off the tree right now just after the launch, so i gotta tune that out and get it to run should be in the 1.5x area after that i would assume....best this year was 1.65 with the stumble....last year running mint was 1.64
Old Aug 5, 2005 | 11:43 PM
BT283's Avatar
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
Man that is the coolest wheels up pic of a third gen i have ever seen, you just dont expect to see them pull a full sized wheel in the air
Old Nov 25, 2005 | 09:34 PM
kamu's Avatar
Car: 84 Z28
Engine: 400
Transmission: tex racing t101a
Axle/Gears: 4.56
I know this is a old thread,but I wanted to show a pic. of my car. I'm also using southside machine lift bars with a Tremec TKO. 3.27 first gear and a 9 inch with 4.11. The rest of the suspension is all stock. best run to date is 11.29 at 119.78 I'm also looking for advice on what shocks and strut changes I should make. Best 60' is 1.58 the car will now be a track only car.
Old Nov 25, 2005 | 10:19 PM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Hey Mark it's good to see you posting back here on TGO.I can't tell you how many times I've talked your car up here.lol.I've been trying to come up with a way to keep up with you with out breaking the bank now that you are dedicating the camaro to track only duty
Old Nov 30, 2005 | 09:58 PM
SnkSknrZ28's Avatar
Car: 1988 Camaro IROC-Z
ur car aint fast unless u can pull the full size tread off the ground
Old Dec 1, 2005 | 05:59 PM
Car: '91 Camaro RS
my car does that....only straighter hehe
Old Dec 1, 2005 | 09:50 PM
c-u-later's Avatar
Car: 84Z28
Engine: 12:1 355
Transmission: fairbanks turbo350
this pic is on motor, it realy twists when i shoot it. i think i need some lift bars. all i have now is a boxed tourqe arm and lakewood lower controle arms and air bags.
Old Dec 1, 2005 | 10:02 PM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
c-u-later. Do you think you will make it to WIR this summer for any RDS's? If so we should set up a heads up race.
Old Dec 1, 2005 | 10:59 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
I am SoOOO envious of u guys. hopefully my car will be able to do that with my 383.
and if it doesnt a 150 shot should help
Old Dec 2, 2005 | 06:46 PM
c-u-later's Avatar
Car: 84Z28
Engine: 12:1 355
Not sure if im going up there this upcoming summer. I went up 2 summers ago to race RSD and had a blast. The next night we did a street crues and hungout, it was a great time! It all depends on getting a new set of gears for my 9". I can run the 1/4 fine with my 4.86s without nitrous but after running on the bottle this last summer in the 1/8 and going through the traps at 7200 rpm with only a 100 shot i know the 1/4 is out of the "?". I need to get some 4.11s and another 3rd member.
Old Dec 2, 2005 | 06:54 PM
c-u-later's Avatar
Car: 84Z28
Engine: 12:1 355
Hay Kamu looks like your cars been running good, you still driving it down to WIR from all the way up north or are you trailering it?
Old Dec 2, 2005 | 06:57 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
We're going to have to get some N/A runs in next year... i think i'll have a lil somethin somethin' for ya
Old Dec 2, 2005 | 07:03 PM
c-u-later's Avatar
Car: 84Z28
Engine: 12:1 355
Ya i here ya Rogue86. after i heard about the combo you were building i wondered how long it would take!! I will be up for it. so hows everything coming together?
Old Dec 3, 2005 | 01:14 AM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
Transmission: Powerglide
Axle/Gears: Moser 31 spline / 4.86
mine won't lift the front end at all... 1.46 60ft.
Old Dec 3, 2005 | 10:57 AM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
I dont understand whats the hell is wrong with my car at all. i have a 355 13.5 compression all the good stuff and i cant get mine to run your guys times. i hvae the south side rear in mine as well with 4.30's, th350 a lot of the same stuff as you guys but mine jsut sucks ***. the best time i have gotten so far is 11.82 the motor is supposed to be making 600 h.p. but its sure not showing those numbers. i have the stock suspension up front spohn control arms and panhard bar 50/50 rear shocks for the rear. i just dont get it, but i am glad your cars are running so good keep it up.
Old Dec 3, 2005 | 11:14 AM
kamu's Avatar
Car: 84 Z28
Engine: 400
Axle/Gears: 4.56
Hey Jerry. Good to hear from you again. I bought a trailer last year. I can now go to the track without wonder if I will be able to get home or not. I hope that you can make it to WIR next summer. If you do we will have to get that race in. I pulled the motor this winter to freshen it up. just some new rings and bearings. Everything looked really good when I pulled it apart. When you run your car on the juice let me know what you run. Someday I would like to put mine on the bottle.
Old Dec 3, 2005 | 12:13 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
Still have a lot of little odds and ends to get, but the big stuff is here. I plan to have it broke in sometime in late december/early January. But I probably wont have all the race goodies on it until we get a little closer to spring.
Actually you could probably run me in you fiereo...I prolly wont be going to fast when the 10 bolt goes pop
Old Dec 3, 2005 | 08:28 PM
c-u-later's Avatar
Car: 84Z28
Engine: 12:1 355
I bett you get more runs in then you think before your rear goes boom!
Old Dec 3, 2005 | 08:40 PM
c-u-later's Avatar
Car: 84Z28
Engine: 12:1 355
The night i ran a 7.38 N/a witha 1.61 60' then i tried a 75 shot and and ran a 7.10 with a 1.58 60'(on the 75shot run my window switch was only set to turn it on at 4000 and shut it off at 6500 and then i went to the 100 shot and spun alot,my 60' was only 1.71 but i still ran a 7.01 at 98mph. next spring i will do more tweeking and try 150 shot! Those are 1/8 mile times buy the way....
Old Dec 3, 2005 | 09:12 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
What size are those tires?
Old Dec 4, 2005 | 12:12 AM
kamu's Avatar
Car: 84 Z28
Engine: 400
Axle/Gears: 4.56
Those are some nice times. The best I did last year was
1.58 60' 7.201 95.63mph 11.29 119.63mph
Old Dec 4, 2005 | 09:35 AM
TBI92Camaro's Avatar
Car: 92 Mustang Coupe/89 Camaro RS
Engine: 5.0 carb'd/305
Transmission: T5/T5
Axle/Gears: 3.73 and stock TrakLok/stock GM
on 150 wet shot with an NOS or NX kit....rule of thumb is you pick up a full second in the 1/8th!
I know my buddy runs mid/high 13's in the 1/4 in his 04 GT and on the 100 wet shot, he runs mid 12's all day long...in the 1/8th he runs 8.6's N/A. on 100 shot he runs 7.8's/7.9's. His car is a freak for osme reason. I think if he sprayed 150 wet shot he'd run 7.5's/7.6's easily...course he powershifts and launches pretty hard on his ET Streets. I got him teaching me the tricks in powershifting...Im teaching him how to launch
Old Dec 4, 2005 | 10:16 AM
w1964bgta's Avatar
Car: 89 gta ws6, Dodge Turbo Diesel, H-D
Engine: 383 4-bolt #638 block
Transmission: 700r4, corvette servo, 2200 stall
Axle/Gears: 3.27 9 bolt b-w, pbr discs
pull them wheels
You guys got some tight rides and I'm w/most of the reply crowd
WOW, AWESOME,KILLER,BADASS,SWEEEEEEEET!!
Old Dec 4, 2005 | 06:37 PM
muggsyjack's Avatar
Car: 1992 RS Camaro bracket car
Transmission: TH-350
This is kids car on motor.
Old Dec 4, 2005 | 07:54 PM
  #42
muggsyjack's Avatar
My car, not as dramatic....
Old Dec 6, 2005 | 04:50 PM
  #43
zz17iroc's Avatar
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
Toat them wheels man. I'm hoping to toat my wheels one day and still be able to drive it home when I'm done racing. Maybe next year with more tuning.
Old Dec 8, 2005 | 12:28 AM
  #44
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
My suspension is untouched. All completely as-is from the factory minus the sway bars. No frame connectors or rollbar... I can't believe it hooks hard enough to pull a wheel off the ground with a light burnout on the 27x10.5 QTP's @ 20psi
Old Dec 8, 2005 | 06:30 PM
  #45
c-u-later's Avatar
Car: 84Z28
Engine: 12:1 355
You better get frame connectors on that before you twist it up.. Nice ride,that hood looks cool!!!
Old Dec 8, 2005 | 06:34 PM
  #46
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
1988 IROC-Z:
10:1 350, unported Vortecs, XE274, NX Hitman kit,
single 3" exhaust, 750cfm Demon, Dana 44 rear,
all stock suspension, minimal weight reduction
(Motor) 12.52 @ 108mph - 1.70 60ft
(Nitrous) 11.67 @ 115mph - 1.56 60ft
Still no tuning whatsoever....
Nice launch for what you've got although I'd say your playing with a bit of fire without connectors and running nitrous if you havent' 'tuned whatesover'.
Old Dec 8, 2005 | 08:45 PM
  #47
Car: '89 IROC-Z
I figure I'll run into traction problems long before I twist anything... I'm a bit silly I suppose though. If I twisted the chassis on my car I'd probably be proud.
Old Dec 8, 2005 | 09:50 PM
  #48
Car: '91 Camaro RS
ummm....if the front wheels are off the ground, then no thats a completely incorrect assumption lol
Old Dec 9, 2005 | 03:13 PM
  #49
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
yeah good luck getting your doors to close back after a few more launches like that with no sfc's or roll cage..
Old Dec 9, 2005 | 06:26 PM
  #50
10.90streetcar's Avatar
This may be my last wheels up launch. Im building an sb2.2 headed motor and thinking about putting wheelie bars on it. And that pass was my best 9.97
