Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
shift rpm????
Old Sep 21, 2005 | 02:07 PM
ssean92's Avatar
Car: sold
shift rpm????
kinda have a question for all you racers out there. what rpm's are you guys shifting at? im trying to get the best time i can at the track, were does a stock lt1 run out of power. i have adjustable fuel reg,lt4 rr's, smog delete, 373, headman shorties with 3 inch all the way back.throttle bypass, and what do you guys guess on my track time? its a 95 lt1 in my 3300lb 92 camaro. and is there anything that i can do to get a few more ponies out of it before i go to the track. i am using a 700r4 with tci lock up kit. no shift kit but corvette 1to2 servo
__________________
Old Sep 21, 2005 | 05:59 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
I would suggest shifting at 5500 to 6000 rpm the lt1 should run all the way up to that. I shift at 5500 and thats with my carbed 305.
Old Sep 21, 2005 | 09:44 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I put my car on a dyno took a look at the graph of where the power was being made. In my case I have my 700R4 shifting at 6000rpm on the 1-2 shift and 5600rpm on the 2-3 shift. Trying to get the most power under the curve.
The reason the 1-2 shift is at 6000rpm is the low gear ratio of 1st gear. There is a big drop in the ratio from first to second gear.
Old Sep 22, 2005 | 06:49 AM
ssean92's Avatar
Car: sold
i have noticed that there is a big drop from 1st to second. i will have to try that. thanks for the info i will let you all know how it goes
Old Sep 22, 2005 | 10:07 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i shift at 5500rpms on both the 1-2 and 2-3.
Old Sep 22, 2005 | 12:16 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
LT1's usually dyno peak horsepower in the 5000-5500 rpm range. this one guys 96 TA put down 277rwhp bone stock at 5250rpms or so. the torque curve is very flat up till about 4800rpms where it starts to fall. the hp curve rises quickly and peaks at 5200rpms or so and stays relatively constant thru 5700rpms.
with that, i woudl try shifting 5500-5600rpms. see how that works.
Old Sep 22, 2005 | 01:10 PM
ssean92's Avatar
Car: sold
mw66nova u coming friday?
Old Sep 22, 2005 | 02:12 PM
mw66nova's Avatar
Engine: 7.0L
no, gonna take the girlfriend out to dinner/movie and go to the track sunday.
Old Sep 23, 2005 | 12:54 PM
ssean92's Avatar
Car: sold
thats cool i might see ya sunday
Old Sep 23, 2005 | 01:28 PM
mw66nova's Avatar
Engine: 7.0L
try to come if you can, it's gonna be some great fun!
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
89fast5oh
Sep 8, 2015 09:55 AM
