Nasty launch kills Rear...
The ol 400ci motor is making some power... Enough to destroy my 12 bolt. I broke the ring and pinion , here is a small video of the launch.
http://www.rhodescustomauto.com/donbreartrash.mpg
I hope to get down the track soon, i'll keep you posted!
DonB.
DonB.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Time for a Dana 60 with some pro gears and a full floater. With the parachute on the back I can only assume that you're going to hit 150 mph soon.
Car: 92 Mustang Coupe/89 Camaro RS
Engine: 5.0 carb'd/305
Transmission: T5/T5
Axle/Gears: 3.73 and stock TrakLok/stock GM
Originally posted by 87TPI350KID
Damn, time for a built 9 bolt then.
Damn, that was gona be pure nasty man.
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Transmission: 4L80E/4L80E
Good to see you pull out of the groove when it banged.
In 8 oil-downs in the last 3 days of racing here, not a single one pulled out of the groove. I've never had cause to do it, but I can imagine it isn't the first thing on your mind when the need arises.
Elephantismo
Feb 13, 2019 12:51 AM
darwinprice
17
Oct 11, 2015 11:51 PM
