Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
How much slower would my car get if i swapped from a 3.73 to 3.42??
Old Oct 8, 2005 | 07:59 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
right now i have a one wheel peel 3.73 rear end and im thinking about swapping out for a posi...but i was thinking maybe i should change the gears to 3.42 so i dont run out of rpm in the 1/4 mile......right now im running 13.5's @101mph and i never pay attention to what rpm im at but im afraid that IF i do some more mods and get my car into the 12's then i will be running out of rpm....and i definately dont want that to happen
any comments or suggestions would be greatly appreciated...
Old Oct 8, 2005 | 09:31 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Well going by what SLP used to advertise when they sold the gears I would say around .1 second.
Old Oct 8, 2005 | 10:08 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
It should be easy to get a better launch with the 3.42s. The 3.73's must burn those tires pretty easy huh?
Old Oct 9, 2005 | 02:08 AM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Re: How much slower would my car get if i swapped from a 3.73 to 3.42??
You are likely not even close to running out of gear. For example, I use tiny 26" tires with 3.73 gears and go through at 114mph between 5600-5900 depending on which converter I have in there. Even if you pick up to 110mph, you should be fine unless your converter is slipping outrageously.
BTW - are you running slicks?
Old Oct 9, 2005 | 08:25 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
yah since i have a peg-legged 3.73 rear it is VERY easy to spin off the tire.....and i dont run slicks....i wanna get some DR's soon....either BFG or MT ET steets.....right now my best 60' time was a 1.945...which is why i really wanna get a posi and DRs
i will really have to look at my rpms next time, because it seems like it is reving up pretty high.....but yah if im under the 5500 range then i will keep 3.73's when i swap to a posi......and if im over i will just keep the gears and then go with a taller tire for the drag strip.....
Old Oct 9, 2005 | 11:21 AM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
There is a link to an RPM calculator on the main TGO page. Enter your tire size, gears and MPH and it will do the math for you. Try it wit the current MPH and desired MPH. Also remember that the calculator doesn't consider TC slipage and that trap MPH is an average of the last 60' while you actual peak MPH (and therefor RPM) is a little bit higher.
Old Oct 9, 2005 | 06:34 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
yah well the tc slippage is what i am afraid of....when i swapped the motor i needed a torque converter for a cheap price because i wasnt planning on buying one when i did the motor swap....so i think that this tc is a cheap crappy one so it probably slips a little more than the better ones.....
Old Oct 9, 2005 | 07:03 PM
itsjustabird's Avatar
Car: 91 firebird
Engine: sb2.2 headed sbnos
Transmission: tsi glide
Axle/Gears: 4.30
personally i say stay with the 3.73s and spend the money on tires. if in the future the rpms become a prob then swap a set of 28" drag radials on it and youll be fine. besides the taller tire looks good on these cars. just my $.02
Old Oct 9, 2005 | 07:15 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
I'll trade you some 3.42's for your 3.73's
You'll lose around a tenth but you'll pick up some in the 60 and gas mileage.
Old Oct 10, 2005 | 10:52 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
hell you might not loose at all....
i have yet to get solid evidence yet but i went slower going to 3.27's from 2.77s. so it all depends on ur power band and such.
i would think u might trap abit higher with the 3.42's, but not too much more.. maybe just 1-2 mph. and the ET should be about the same
but it depends on what rpm ur at now when u cross the line
Old Oct 14, 2005 | 12:03 PM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
Transmission: TH350 3000stall
Last year my setup was somewhat like yours stock vortec - manley race flow valve - xe268 cam - 1.6 roller rockers -Air gap rpm intake - holley 600 hp -1 5/8 shorties with 2.750" single exhaust - th700 with shift kit... with MT ET drag 28X9X15 sliks and locker rear with....
-3.42 I went 13.35@103
I change for a
-4.10 and i went to 13.17@104
So the gain is about .18s
Old Oct 14, 2005 | 03:37 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
You also have a stall, which helps the guys with lower gears tremendously and compliments the weak power-band of the TPI. The 3.27 gears are nice for guys without a stall.
I doubt you would loose any time. If you spin of the line now, those will help you hook better and give you a better trap spd.
hectre13
Dec 11, 2023 08:14 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
draco
Oct 4, 2015 09:25 PM
jharrison5
Aug 19, 2015 05:53 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
