Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Another what do you think she'll run thread...
Old Dec 9, 2005 | 03:31 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
I'm buying another thirdgen and I'll have some money to put into it. These are the engine specs I'm planning on:
358 block
Late model vortec heads - 239/160 @ .500
220/230 @ .50, .510/.510 on 114 or 112 LSA - 1.5 RR
Either:
Edelbrock performer rpm vortec carb manifold
750 dp carb
Or:
Holley Stealth Ram with vortec provisions
30 lbs injectors
Proper tuning
I'm not sure whether I want to go FI or carbed yet.
Pushed through long tubes dumped before the rear axle.
The rear end will be a 4.10 posi and a T-5 will handle shifting duty. Stock style suspension with SFCs, LCAs, relocs and good tires.
What do you think a beastie with this setup would be capable of running? I'm hoping someone on here has a similar setup or knows of one.
Old Dec 9, 2005 | 04:25 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
with a good driver and absolute optimal conditions and traction, i'd say 11.5-11.9...what is the goal for vehical weight?
Old Dec 9, 2005 | 04:35 PM
Car: '72 Chevy Nova
Transmission: TH350
Pretty much stock weight. Maybe slightly more since I'll have a sound system in it, although I might pull some stuff to balance it out.
Old Dec 9, 2005 | 04:52 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
hey urban, i'm just curious but what car are you gettin/have thats 5 speed. Is it a z, rs, iroc? hardtop? jw
Old Dec 9, 2005 | 05:12 PM
Car: '72 Chevy Nova
Transmission: TH350
I'm currently looking at a trade for an IROC (G92, LB9, 5-speed) + cash, and there's a 91 Z28 for sale with 305 5-speed.
I'm buying a car already with a 5-speed, so she's either going to be a roller with no motor or I'll be pulling the 305 she comes with. Figure it's easier to do a motor than an auto -> manual tranny swap.
And yes I am selling the T/A to get this. ....
Old Dec 9, 2005 | 05:27 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
11.5 is really really optimistic. i would bet more on 12's
Old Dec 9, 2005 | 07:03 PM
Car: '72 Chevy Nova
Transmission: TH350
I was hoping for low 12s with a nasty 60 ft. If I dropped some weight hopefully 11s, but I think she's gonna stay stock weight.
Old Dec 11, 2005 | 08:22 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
if you decide to keep the t5 make sure that you beef it up. the reason they never put the t5 behind a 350 was because it was only rated for 300 pounds. if you put any slicks on it be prepared to grenade the trans.
Old Dec 11, 2005 | 09:53 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
well since the T-5 trans should blow up behind that motor, and rear end should probably blow up on the first pass with slicks on it. i'd say one tow truck home.
Old Dec 12, 2005 | 03:22 AM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Mid 12s. That cam isn't huge by any means. Some guys have had good luck with the vortec/perf. rpm/xe 274 combo though.
Old Dec 15, 2005 | 11:55 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Mid - high 12's with the FI/HSR setup.
I don't know a thing about carbs.
Old Dec 16, 2005 | 11:16 PM
Car: '72 Chevy Nova
Transmission: TH350
actually some recent evidence has shown that T-5s can DEFINETLY hold their own.. a few guys on the boards will know what I mean so I'm set on running one.
The rear end will be upgraded for a 12 bolt as money permits, however 10 bolts can hit 1.8 60s and be just fine, I'm going to try to push the envelope a bit.
and why do you say the motor will blow up xpndbl3? only if I don't assemble it right.. and I'm having a shop balance/blueprint the bottom end for me. it can more than handle the power. like tevor said, the cam isn't huge. but it is the biggest that will pass CA emissions.
Old Dec 17, 2005 | 12:29 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
all i can say is its slower then mine.
Old Dec 17, 2005 | 01:04 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
I hope that the trans does hold, I was just speaking from personal experience. After I started getting 1.7's with slicks the trans didn't make it 3 more weeks. That was on a stock t5 from an 84 HO though. Good Luck with the project!!
Old Dec 17, 2005 | 02:30 PM
JesasaurusRex's Avatar
id have to guess a mid low 12 is possible, courses its a guess, that t-5 and 10 bolt are gonna explode the first time you put some sticky tires on her tho
Old Dec 17, 2005 | 04:13 PM
Car: '72 Chevy Nova
Transmission: TH350
haha alright i'll eat my words okay happy?
and yes trav, we WILL race
Old Dec 17, 2005 | 09:25 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
mid-high 12's with a good 60' and good DA.
Old Dec 17, 2005 | 11:38 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
how fast do u guys think i can be with my 383cubic inch canfield heads, 64cc chambers, 190cc runners, stealthram 30# injectors, steel crank forged rods, hyp flat top pistons 10.75 :1 compression. 2.1 intake 1.6 exhaust valves, hedman shorty headers 3" exhaust 3.42 posi gears spintechmuffler and a well built 700r4 2400stall. ?
Old Dec 17, 2005 | 11:40 PM
what r the specs on ur cam again
Old Dec 17, 2005 | 11:46 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
oh ya. 224/230 duration 112LSA, 532/544 lift thats what my old cam was, i will probably go with the same cam, cant seem to find anything else
Old Dec 18, 2005 | 12:19 AM
Car: '72 Chevy Nova
Transmission: TH350
well u trapped 109 before, with 33 more cubes i'd say you'll trap prolly 111. your cam is slightly more aggressive than mine, your heads are better (although i don't know flow numbers) and you'll have more cubes, so for all intents and purposes you should be faster. However I'll be running lower gears, a stick and sticky tires. You'll be running a 700r4 with street tires. I think it'll end up being close in the ET but you'll outtrap me.
and our DA is great, sea level track, usually colddddddd
Old Dec 18, 2005 | 12:51 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i got VHT bish
Old Dec 18, 2005 | 12:56 AM
dude ull out ET him easy if hes really thinking about the gears hes telling me about, f*ckin r*cer trav
Old Dec 18, 2005 | 12:57 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
hey you made me at least change my mind some.. 4.11's or 4.10's whatever the **** it is. i gotta have SOME highway glory.
Old Dec 18, 2005 | 10:22 AM
Dialed_In's Avatar
700r4, 6% converter slippage, 4.10's and 28" tall tires. ought to put you through the traps around 6k.
Old Dec 18, 2005 | 11:31 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I agree with the mid high 12's. Lot's of variables to consider. The cam is OK for your I/E ratio. I like higher lift myself. If you go with fuel injection I would consider a 113 LSA. With a Carb maybe 110 LSA. Talk to the cam supplier.
Old Dec 18, 2005 | 08:15 PM
Car: '72 Chevy Nova
Transmission: TH350
i believe the lift bumps up to .544/.544 with 1.6s iirc. 510/510 is at 1.5.
what gears are you going with travis? I thought u had 3.27s or whatever? I'm actually considering going 4.56s, but i'll have to compute my highway rpms and what i want to cross the traps at and see if i can do it.
Old Dec 21, 2005 | 12:16 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i have 3.42 right now. if i upgrade in the future its only at the same time when i do a manual trans swap.ill laugh if u do 4.56, youll just spin off the line and when your car is actually fast, youll just over rev at the end.
Old Dec 21, 2005 | 11:13 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I agree. That thing ain't hittin 11's unless a 10sec. car is towing it.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
