Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Race heads ???
Old Dec 22, 2005 | 02:16 PM
slow86305's Avatar
Car: 86 camaro
Engine: 572
Transmission: TH400
Race heads ???
I have a 388 with world products sportsman heads. I have been running 10s for a while on the bottle. I want to get nitrous pistons and heads. My goal is to get into the 9s.
Whats 23 degree heads do you recomend?
I want do go as fast as possible?
My current heads are mildly ported. Should just get them fully ported?
Old Dec 22, 2005 | 03:53 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
how much of a shot? what's your combo, cam specs, etc. what size stall? all this on a 700R4 trans? Gearing, etc? Are you running high 10s now and expect more nitrous to get you high 9s? your question is VERY vague, need a ton more info.
Old Dec 22, 2005 | 04:42 PM
slow86305's Avatar
Car: 86 camaro
Engine: 572
Transmission: TH400
388ci
eagle bottom end
srp 7cc dome pistons
sportsman heads 58cc
supervictor intake
850 demon
cam 254,260 duration, 582 588 lift 110 lobe seperation
cheater 180 shot
700r4 10in converter. I have th400 in th garage. All it need is a converter. The 700r4 just will not die.
1.64 60ft 10.60 @128
Old Dec 22, 2005 | 04:53 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
For what you want, look seriously at AFR 215cc raised runner heads with competition porting from the factory. You will have to run offset rocekrs/lifters, but to get the flow you need from a 23* head, that is the only option you realistically have with going 18*. One of the dowfalls of juice, getting that first 1 full second faster is the easy part, trying to get it faster than that and it becomes more difficult. Even if you hit a 250 shot with what you have, chances are you wont pick up much more than you've already got.
All my juice buddies explained it like this, it took 150 shot to get 1 second faster, to get it 2 seconds faster you will need at least a 300 or more shot-doubling shot to double the et gain. and from what I've seen this seems to hold pretty true. So starting off with a good motor runnign quickly by itself and your winning the battle from the get go.
Old Dec 22, 2005 | 08:20 PM
brutalform's Avatar
For the nitrous use, considering a camshaft with a wider 113-114 LSA, than your current 110, would not be a bad idea, IMO.
Old Dec 22, 2005 | 08:35 PM
slow86305's Avatar
Car: 86 camaro
Engine: 572
Transmission: TH400
Thanks guys. IHI the jegster torque arm really hits the tires. Iam still not used to it. Finally gettin some air under the tires.
Old Dec 22, 2005 | 09:33 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Whats up evil twin hay I'm selling the heads off of my old 380ci combo if you still have my # call me. Ill help you get in the 9s the heads were AFR 195s set up for a solid roller. I went in the 9s with those heads and a 275 shot at 3400lbs.
Old Dec 22, 2005 | 10:06 PM
IHI's Avatar
IHI
Glad to hear it's working for you!! I've been really impressed with since since bolting it in last year, but since my racing involves consistency and tracks get slimey in the summer, I'm going to try out a longer tq arm again when the car comes back out. I plan on more power N/A than what I had along with some juice shots and I feel with whatI have/had it was really pushing things to the limit for traction. Hopefully the longer tq arm will transfer more of the power into the chasis and take a load off the tires so when track goes away, traction stays
Old Dec 23, 2005 | 07:57 AM
slow86305's Avatar
Car: 86 camaro
Engine: 572
Transmission: TH400
Originally posted by ross
Whats up evil twin hay im selling the heads off of my old 380ci combo if you still have my # call me. Ill help you get in the 9s the heads were AFR 195s set up for a soild roller. I went in the 9s with those heads and a 275 shot at 3400lbs.
whats up man. yea i still have your #. Ill give you a call.
Old Dec 23, 2005 | 08:05 AM
slow86305's Avatar
Car: 86 camaro
Engine: 572
Transmission: TH400
we went to a 1/8 mile track last weekend and i was the only one not hooking. 700r4 first gear,short torque arm, n2o, combined was over whelming the tires. But when the track is good its alot of fun.
Old Dec 23, 2005 | 12:24 PM
brutalform's Avatar
Hey slow86, is that 60' in your sig, with or without the shorter torque arm? I was considering one. My best 60' is 1.57 with the stock arm.
Old Dec 23, 2005 | 03:26 PM
slow86305's Avatar
Car: 86 camaro
Engine: 572
Transmission: TH400
thats with the new torque arm. The car is alot more responsive. I have to work on getting it to hook.
Old Dec 23, 2005 | 04:25 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Slow are you still using the 1 5/8 long tubes and slow master muffs?
Old Dec 23, 2005 | 08:43 PM
slow86305's Avatar
Car: 86 camaro
Engine: 572
Transmission: TH400
same headers. bullet mufflers
Old Dec 24, 2005 | 06:37 AM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
My offer still stands if you want to try out the hookers let me know bring the car up and you can use my garage.I think they will make some improvement on your ets.
deracer
Apr 11, 2016 12:04 AM
Ducati900ss
Sep 2, 2015 09:05 AM
355tpipickup
Aug 25, 2015 12:54 AM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
