How fast can a 3rd gen go with a stock style suspension and a 23* NA sbc?
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
This guy has a 3225lb 84 Trans am with a naturally aspirated 440cid small block chev running 9.23 @148.7.
http://enginecombination.com/viewtop...bd7449cef90a36
I don't recognize the car as on TGO so I thought I'd post here to see if you guys know of anyone running within the same parameters.
BTW - the "Outragous Engine Combinations" is pretty cool in itself so I was going to post the link anyways.
Trevor
Took along time to get the car to work, My Engine builder( HOMER RACING ENGINES) is the best out there; to me. Future plans would to be; getting the car to go out; instead of up. i know the car could go high 8's to low 9's.the motors making plenty, and to be the Fastest 3rd. Generation Car in the Country on Stock Style Suspension,with a 23 degree head, for a SBC. with NO POWER ADDERS. ALL MOTOR.
Give me some ideas if you know someone who has a car like mine with what i described above. not tubbed,no chassis car,all factory glass in car.
Trevor
Car: 1989 Iroc Z L98
Re: How fast can a 3rd gen go with a stock style suspension and a 23* NA sbc?
Trevor
Trevor
Car: 86 Trans Am
Engine: 406
Owner Information
- Home Town: Easton,PA.
- Primary Use: Racing
- Estimated Investment: Way to much!!!!
- % of Wrenching by Owner: 80%- 20% hire out.
- Year: 1984
- Make: Pontiac
- Model: Trans-am
- Weight: 3225
- Best ET/MPH: 9.38 @ 148
- Best 60´: 1.29 rear tires.
- Performance Rating (5 is best): 5
- Street Manners Rating (5 is best): 5
- Engine CI: 440" SBC
- Bore: 4.185"
- Stroke: 4.0"
- Block: Dart Little "M"
- Heads: Protopline Raised Runners(IRON)23*
- Ported? (With flow numbers): fully hand ported,int.357 - ext.265 @.800lift.
- Crank: Eagle (lightened)
- Rods: Howards coated 6.125" w/ 9" deck
- Pistons & Rings: CP -Specially made
- Cam & Lifters: Comp. Cams Roller & lifters
- Intake: Edelbrock #2971, Dom. 1" HVH spacer
- Distributor/Ignition: All MSD. -Front Dist. Drive,Digital 6, 8.5mm wires.
- Headers: Lemons - 2" x 4" - oval 4" w/Spintech Mufflers.
- Tran & Brake: TH - 400, J W Pro Brake
- Converter: Lupo - 8" - 6000 stall
- Rear End Gear: 12 bolt - 4.30
- Tire Size: Phoenix -29.5 x 10.5
- HP/TQ Number: i really don't know.
- Power Adder: N O N E !!!!
- Compression & Fuel Used: 15.01 -VP -114 +
- Chassis Tricks: Stock Style Suspension Replacement parts.
- Carb: A .E. D. - 1240 cfm.Dominator
- Go on (www.photomagic-digital.com), go to NMCA,Maple Groves 2005 race, pick Friday, pg.43 two pictures, pg.29 four pictures of White 84'Pontiac Trans-am.
- Took along time to get the car to work, My Engine builder( HOMER RACING ENGINES) is the best out there; to me. Future plans would to be; getting the car to go out; instead of up. i know the car could go high 8's to low 9's.the motors making plenty, and to be the Fastest 3rd. Generation Car in the Country on Stock Style Suspension,with a 23 degree head, for a SBC. with NO POWER ADDERS. ALL MOTOR.
- Give me some ideas if you know someone who has a car like mine with what i described above. not tubbed,no chassis car,all factory glass in car.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
15 to one compression and heads that flow to .800 lift... and he gives that thing a 5 for street manners... LOL
lol. Supreme Member
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Originally posted by unknown_host
lol exactly what I was thinking, goes well with the 6000 stall. I hear a 6000 converter is actually real streetable
lol.
lol. I would love to see some 215/60's get murdered with that
Car: 84' firebird
Engine: 440"SBC (N/A)
Transmission: th-400
Thanks Trevor, that is damn impressive! IIRC, the runners on those cylinder heads are like 260cc lol.
Car: 84' firebird
Car: Z/28
Engine: 355
Transmission: Turbo 400
The bottom line is: How fast do you want to go? It takes $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
Car: 86 Trans Am
Engine: 406
JRS - besides your car, what's the fastest stock style suspension 23* NA sbc third gen? Or even with 18* heads?
What other setups are you shooting to beat?
Car: 84' firebird
Well, an 18* head flows more than mine, like 370's to 400's, so that would be hard to compare a 23* head, but there are 23* heads out that i know that flow in the 380's or more, just that spending $10,000.00 to run with the best is alot of money, plus getting your car to handle over 850hp's is hard to do now, i tryed some time back, getting on every f-body site and posting who had the fastest 23* headed car people don't talk or tell you the truth, but at 9.23 @ 148, there's faster cars out there trust me. i'm just looking to be the fastest 23*,stock susp., car in the country. thanks. JR.
Thats an awesome setup u have to go low 9`s NA. I cant wait to get my car to the strip hopefully this year ,im going to be running a 18* setup.
My heads are 257cc runners, but this year i'm opening them up to 305cc, for more head flow.
Car: 84' firebird
What kind of car are you running,what size motor are you going with the 18* heads. want a good set of 23* heads look on (www.ronsportingservice.com)look under heads, AllPro, 382 @.800int., 261 @.800ext. thats a head. let me know, i love hearing about all motor SBC. thanks. JR.
my car is a 89 GTA. The motor is a 426 CI SBC. Check out my topend parts at
18 degree setup
Im going NA also.My heads have been heavily ported.At the moment im having them flowed.There is only a few that i know of on this board that into the max NA effort ,the rest are into turbos(seems like it).
Car: 84' firebird
i'll give a secret, if you lightly buff out all the CNC marks in the chambers,int. runners,ext. you could pick up as much as 1* to 1-1/2*, thats 10hp. let me know how you made out with flow #'s. JR.
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Where do you get headers to fit 18* heads in a thirdgen, or spreadport headers to fit our cars for that matter? I guess you could use the spread port adapter plates, but then the headers wouldn't fit in our engine bay anyways....
or u could try Lemon headers.
Car: '88 IROC-Z medium orange metallic
Spend the $$$ and have a set made. If you've got an engine of that caliber, chances are that a set of off-the-shelf headers aren't going to do the trick for you.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
I know of two faster with stock type suspension and a SBC, but it's a twin turbo car, all these guys with huge lifts and big compression are great for class cars, but for the easiest on the wallet I know of 2 faster than the ET posted, not sure what their mph is though. None of them say much other than I know for sure it's a torque arm setup in the rear and twin turbo SBC with 23' heads.
Car: 91Z28 L98
Engine: HSR 350
Just checked out Stahl and Lemon's prices. You gotta be pretty serious to drop $1200-$1800 just on headers. I tried getting a quick total with some spread port or 18* heads, forged internals, headers, etc, but my calculator ran out of digits....
it cost to have bbc power in a sbc package. Horsepower cost money.
theres cars running in the 8's with stock style sus and 23* heads, usually turbo cars though. my car is stock sus, but im gonna be running 18* heads. no clue what it will run. anticipating low 9's, maybe a high 8 if it hooks.
i fit the bill!!!! 8.91@151 stock suspension 23deg heads(afr195s ported) on a
.028jet.....been faster but thats a secret!!!LOL
Fast355
Dec 2, 2016 06:33 PM
