Another 1/4 What will I run
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
88 firebird Was V6 Now V8
Engine: LG4 w/ 4Barrel Edelbrock Carb,
Edelbrock performer intake,
Summit Cam and lifters 214/224 2000-4500,
Moroso Super blue ignition system
and Edelbrock filter.
Removed A/C and Clutch fan (Electric Fan Assembly)
Exhaust- Hooker-2055 Headers,
Hooker 3" Y-pipe, deleted cat, and 3" Edelbrock catback system.
Suspension- Just a Poly tranny mount, and Lakewood 50/50 rear shocks.
Also a Rearend from an 83 Trans am
Thanks in advance
Thanks in advance
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
If you have your carb tuned better with the proper jets, i wouldn't be surprised if you ran mid 13s
Car: ws6
Engine: ls1
Transmission: m6
Its an LG4 engine right? Those only make like 165 hp stock which is good for low 16's. It will take a ton of mods to get an lg4 into the 13's. I dont think it can be done with the stock heads.
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Hard to guess withouth knowing gears, posi?, tires, etc.
That being said; mid 14s at 93ish mph.
Car: GTA
Engine: 383 HSR
I do not know what gears I have. Just that I took the rear end off of an 83 t/a
Car: ws6
Engine: ls1
Transmission: m6
I had an 86 lg4 5-speed with headers,cat-back,intake manifold,filters,chip,gm dual snorkle intake, 3.73's, dual friction clutch, and drag radials, and low 15's were normal. I really cant see you hitting low 14's.
Car: 3
Engine: inboard
Transmission: underfloor
Hey Cale did you get it running yet? Haven't heard from you in awhile.
As far as what it will run that will depend SO much on the gears, and an '83 TA could have had anything from 2.73's to 3.73's in it.
Actually the V6 cars had deeper gears in them- but you swapped in the TA rear for the disk brakes correct? IF you still have the other rear the carrier and gears can be swapped in.
The TA rear could be anything, my '83 TA had a 3.23 open rear in it with drum brakes.
I suspect the car is capable of mid to high 13's depending on gears, tranny... maybe low 14's if things are really mismatched, though I'm betting that it will acually run high 14's to low 15's, people just don't tend to run fast with mystery meat parts and matching tuning and driving.
Car: ws6
Engine: ls1
Transmission: m6
If that car runs mid 13's then you shaved off three seconds of what it [LG4] typically runs from the factory. With just bolt ons and a cam swap i dont think you droped three seconds. So good luck with that. Dont get your hopes up from what people tell you. The only way to find out is to run the car.
Car: GTA
Engine: 383 HSR
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Fast355
Dec 2, 2016 06:33 PM
