Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
distributor gear with cast roller cam
Old Apr 23, 2006 | 06:57 PM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
Transmission: TH350 3000stall
With a cast core solid roller cam do i need to run a bronze distributor gear or the stock one is ok Cam is Comp cams 12-772-8 XR286
https://www.thirdgen.org/forums/afte...id-roller.html
Old Apr 23, 2006 | 07:14 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Email Comp Cams and ask them. If it's a billet cam, it needs a bronze distributor gear unless it's been designed for street use and has a cast gear on the cam.
Old Apr 23, 2006 | 07:41 PM
Rancid87's Avatar
That cam comes with a pressed on iron gear so the stocker will be ok.
Old Apr 23, 2006 | 08:36 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Then it doesn't need a bronze distribuotr gear.
Old May 30, 2006 | 08:15 AM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
Just call comp cams and they said that cams finishing with a 8 like 12-772-8 are cast and they can be used with the stock distibutor gear & fuel pump push rod so no need for the bronze thing.
junkcltr
Aug 2, 2019 11:12 PM
MoJoe
Sep 24, 2015 09:12 PM
camaro71633
Sep 1, 2015 10:24 AM
anesthes
Aug 8, 2015 09:37 PM
