What will I run?
Car: 1984 Trans Am
Engine: just a little 305 ; )
Transmission: the original t700r4 ; )
Axle/Gears: stock 10 bolt w/4.10 or 4.56 richmond gears
What will I run?
Hey I posted this same question a couple months back, but the question remains the same what do you thin ill run? Build up should be in sig. Can yall give me 1/4 time and mph and also horsepower and tourqe ratings. I have an online dyno but i would like to see what people who have actually built them up this bad think i will have. thanks
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Race weight? Tire size?
If you really want to know what it will run, you need to go to the track and make a pass. Computer dynos will assume everything is set up perfectly which it never is.
Car: 74 Nova
Engine: 383
Transmission: TH350
What's your cam specs and stall speed? If you've never ran at the track, you have no idea if you will hook up or not. Have you scaled your car to see the front to rear weight distribution?
Car: 1984 Trans Am
my cam specs are in my sig and my stall will be about 3800 and no I dont know about my front to rear weight distribution
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
You should be able to make some 9 sec passes on the spray but it looks like you will have to much gear to me on spray on motor you will be some where in the 10s
Car: 1989 Iroc Z L98
I have a friend with a 6" rod 383 with 12:1, Brodix Track 1's and a big solid roller (too big actually imo) and he runs in the 10.9's with a small 3000 converter.
Car: 1984 Trans Am
Well what kind of gear do you recommend?
Car: 82 camaro
Engine: 434 ci
Transmission: t400
4.10 with a 28 to a 29 in tall tire on the spray you will want the extra top end. I run a 3.89 gear my car ran 9.70s on a 275 shot.
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
