Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
solid cam going flat?
Old Jul 22, 2007 | 11:29 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
When you lose a lobe does the valve stop moving completely or can you lose a lobe slowly over time on a solid flat tappet cam? Reason I'm asking is I put 300 miles on the car now and have to keep tightening up the lash every 50 miles or so and the car feels down on power, not to mention slower cars are pulling on me on the street. Is there any way short of pulling the cam to tell? All 16 valves seem to me to move about the same amount, and the carb has been wideband tuned, timing is at 32/33 locked out with vortec heads.
Old Jul 23, 2007 | 12:12 AM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
Re: solid cam going flat?
Dial indicator.
Old Jul 23, 2007 | 11:10 AM
xpndbl3's Avatar
Car: 1984 Z28
well since I don't have that either, guess it limits my low budget way of knowing
Old Jul 23, 2007 | 11:17 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A dial indicator and a stand is about $15.
Old Jul 23, 2007 | 11:30 AM
xpndbl3's Avatar
Car: 1984 Z28
I am unsure of where to purchase one that cheap, this wouldn't be a home depot stocked item or a sears store would it?
Old Jul 23, 2007 | 01:49 PM
JesasaurusRex's Avatar
wow n00b
Old Jul 23, 2007 | 03:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Probably not. Harbor Freight, or eBay would be your best bet for the cheapest price.
Old Jul 23, 2007 | 04:05 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
what kinda oil you using?? if your not already, get that bad boy on some delo or rotella.. i've been going strong on delo oil, but rotella is basically the same thing.. just a different brand..
also, take note of the poly lock.. if the hex-headed "lock" keeps coming up, out of the nut, i would guess your cam is toast.. i had a freak lobe grind down once(actually a few times) and found one poly lock was almost out of the nut.. didnt even realize it till i bottomed out the rocker on the stud and it wouldnt tighten anymore.. on my motor, the poly lock is about a tread or 2 out..
Old Jul 23, 2007 | 05:04 PM
IROC4LIFE's Avatar
Car: 1986 IROC-Z
Engine: SBC
Transmission: Manual Th-350
Axle/Gears: 9" Moser 3.89's Spool.
It could be either the cam going flat OR bad poly locks. I had a set of ploy locks keep coming loose and we thought it was the cam, when I cut open the oil filter and didn't find ANY metal in the pan/draing plug, we tried new poly locks (same rockers) and poof ran awesome.
Poly Locks on Solid cams will sometimes wear out (constant valve lash ajustment) so its not uncommon.
What I would do first though is pull and cut open the oil filter, if there is alot of fine (size and consistency sand) metal. Don't run the motor anymore. Better to pull it apart now before u destroy the crank and pistons. (and god knows what else)
If there is no metal in the oil filter, try another set of poly locks.
And as mentioned before, makesure your running racing oil or Rotella. Flat tappet cams and most oils (even off the shelf synthetics) no longer work.
(also when using rotella, its never a bad idea to *** some lucas oil treatment).
Old Jul 23, 2007 | 05:47 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Originally Posted by JesasaurusRex
wow n00b
wow are we playing video games online or something? Why is he a noob because he asked a place to get a tool?...wow he must be a noob what was he thinking.
Old Jul 23, 2007 | 05:53 PM
how bout cuz that's my boy
Old Jul 23, 2007 | 05:59 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yea, i'd use mcmastercarr.com. They have a dial indicator and base set for ~$20. You'll use it enough to justify that.
Get the one that has 1" of travel, accurate to .001"
Set it up on the valve tips, zero it out (or set it to .100") when the valve is fully closed. Then rotate the engine over and record how much it lifts. If you're down less that .020" I wouldn't be too worried, that could be measurement error, imperfect cam, rockers not exactly 1.5 etc etc.
Any more then that and i'd start to sweat. Or you can try to measure on the pushrod side, directly over the pushrod itself (on the rocker). Be sure the indicator is set up to go straight up in the direction of the pushrod. (know what I mean Verne?)
Good luck! (You're gonna need it.)
Old Jul 23, 2007 | 08:22 PM
xpndbl3's Avatar
Car: 1984 Z28
running rotella oil 15w40, have to hit up a harbor freight later this week and see what they have to offer then.
Old Jul 23, 2007 | 08:40 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Also make sure youre not pulling the rocker studs if you are running the GM press in studs. I have seen cams wear one or two lobes but never all of them. Good luck.
Old Jul 23, 2007 | 09:25 PM
xpndbl3's Avatar
Car: 1984 Z28
I'm running ARP screw in studs. Just checked the dipstick and there appears to be very fine sediment on there. How much "wear" would there be on the lobes? Is it noticeable while cranking the motor over that the valves wouldn't move the same amount? They appear to move the same to me, but when a stock ls1 car pulls on me on the street by a few cars and the carb is set up with a wideband, I have to wonder where all the power went.
Old Jul 24, 2007 | 01:58 AM
IROC4LIFE's Avatar
Car: 1986 IROC-Z
Engine: SBC
If there is sediment on the dipstick, pull and cut open the oil filter ASAP. If its also in the oil filter, then the cam is toast.
It won't be visually noticable until the lifter wears though the cam's surface hardning, once that happens, it will be flat in a matter of 2 mins run time or less.
Old Jul 24, 2007 | 12:12 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
If theres sediment on the dipstick thats a bad sign. Like the others said, I would drain the oil and see how it looks and cut open the filter and see if you have a bunch of metal in it. Theres no way your valve lash adjustment should change that much that soon. Mine hardly changes at all, and I just check it 2-3 times a year.
Old Jul 24, 2007 | 09:03 PM
plumminfool's Avatar
Car: 1988 camaro sport
Engine: 355
Transmission: 5 speed
Axle/Gears: Ford 9 inch - 4.11 gears
Are they adjusted right? After I finally asked someone how to properly adjust mine, the car ran fine.
Old Jul 24, 2007 | 09:17 PM
xpndbl3's Avatar
Car: 1984 Z28
yes they are adjusted properly, I have set lash on cars for years now, just never seen one where they all are losing lash, but the sediment on the dipstick and the lack of power definitely point to a bad cam or lifters, which after asking around some people have had soft metal lifters do the same thing from the comp lineup. So it looks like I'll just switch to a roller setup and not worry about it again and give up a little power.
Old Jul 24, 2007 | 09:54 PM
hope **** works out homie
Old Jul 25, 2007 | 12:43 AM
IROC4LIFE's Avatar
Car: 1986 IROC-Z
Engine: SBC
Yea, damn comp has has some issues lately, even with some roller cams going flat. How would going to a roller give up power? would you use a smaller grind?.
I think Cammotion,Bullitcams,or Lunati is the way to go for cam's and Lunati or Isky for lifters. (Solid Roller).
Also when u rebuild it, makesure you do an INSANE about of cleaning inside the block/oilpump/heads etc etc. That fine ground down cam metal **** loves to destroy everything.
Old Jul 25, 2007 | 01:23 AM
xpndbl3's Avatar
Car: 1984 Z28
well the solid cam had a 106lsa which created a very tight powerband that the motor made the most power in and revved very quickly. Now I'm thinking of a 236/242 or slightly smaller roller in the extreme energy lineup, possibly the nitrous lineup for a boost combo this winter.
Old Jul 25, 2007 | 02:37 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
236/242 is a bit much for turbo...i wouldnt go much more than 230/230 especially since you're doing twins on a streetable setup. alot of people have made gobs of power on as little as 218/218 cams. i believe single pattern is the way to go for boost, and on at least 112 lsa ut 114 would be better. ...but you already knew all that.
Old Jul 25, 2007 | 10:52 AM
xpndbl3's Avatar
Car: 1984 Z28
single pattern over the split duration nitrous type cams? Guess I'll have some more research into this, but I was always under the impression that extra duration on the exhaust was a good thing for FI
Old Jul 25, 2007 | 03:36 PM
um...call the cam company and ASK them for which off the shelf cam they recommend. Call all of them, and youll be surprised how close the specs for the cams they recommend are. I already told you to get a custom grind but you don't want to so atleast ask them which off the shelf grind would work best for you.
Old Jul 25, 2007 | 05:17 PM
IROC4LIFE's Avatar
Car: 1986 IROC-Z
Engine: SBC
A Custom gind is needed to make real power for any custom turbo setup. Everything off the shelf will be leaving alot on the table.
Only the mustang guys with 302's and bolton turbo kits see the full potential off of the shelf cams.
Not to mention its the same price off the shelf VS custom so. Might as well have one that matches.
Old Jul 25, 2007 | 06:42 PM
i already told him it costs the same, can't put a price on ignorance
Old Aug 5, 2007 | 10:52 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
sears tool dept. should have them. maybe alittle pricey paying for the craftsman name on a tool made in china.
Old Nov 12, 2007 | 10:02 PM
niceroc's Avatar
Car: 87 iroc
Engine: 454 .030 over
Transmission: th-350
Axle/Gears: 9 bolt
i had a buddy that had prolly 5-6 lifters/ cam lobes go bad on his cam, he had about 500 miels before he pulled the cam and found out, he was having the same probs as u and just decided to pull the cam and put in a hyd. cam. when he pullled it he had found the soup cup lifters and worn lobes, some of the lobes were prolly worn down 1/2 way but we didnt notice it when we just looked at the valves, when we took the oil pan off there was prolly 1/2-1" of metal/oil paste in the bottom, it was a messy jjob
Old Nov 12, 2007 | 11:13 PM
xpndbl3's Avatar
Car: 1984 Z28
cam will be out this week and i stopped driving the car, got a roller cam to go in instead, might be replacing bearings and such as well, we'll see how it looks.
Old Nov 13, 2007 | 04:02 AM
Car: 91 z28
what specs did you decide to go with on it? is it for boost?
Old Nov 13, 2007 | 11:44 AM
xpndbl3's Avatar
Car: 1984 Z28
no idea on specs until i get it from the cam grinder, i'll have to ask his permission if i can even post since it's a custom ground cam. Yes it's for boost setup for my motor specs, he had probably 30 questions to ask me before he got off the phone with me.
Old Nov 13, 2007 | 12:29 PM
Sonix's Avatar
Car: 1982 Trans-Am
So then are you willing to divulge the specs on your now toast cam? Or is that still a hush hush?
Old Nov 13, 2007 | 12:59 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
vortec setup up also. I was doing an intake & rocker swap when I noticed I was having problems with my cam. I had been down on power lately and the car would run rich. I pulled a couple of lifters, and one would not come all the way out of the block! When the cam wore down it mushroomed the lifter!
I just flushed my block with some cheap oil. I would take a ride or two and change the oil. Did it about three times. It never did come out too dirty.
Old Nov 13, 2007 | 02:33 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Why such a thick oil?
Adjusting every 50 miles or so is wayyyy to often. I bet it takes just as long for a cam to wear out, as it does for an engine to wear down, or get "tired".
Is your oil pressure good?
Please take pix when u are disassembling, its valuable info. Hope the new build goes smooth,.
Old Nov 13, 2007 | 03:41 PM
xpndbl3's Avatar
Car: 1984 Z28
custom cam, can't divulge lobe profiles, you want one I can get you one for $375/400-ish.
oil pressure is fine i'm running that oil because it has the zinc, etc that solid cams require which synthetic oils have removed due to stricter emission standards. 15W40 isn't really much thicker than 10w30 anyways and the bearing clearances were right in line for that oil. Solid cams do not have a shelf life of a typical hydraulic or roller cam.
and talk about bringing a post back from the dead from july.....
Old Nov 13, 2007 | 06:57 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Actually, even Rotella is losing most of its zinc content now, from what I hear. The best route now is either a racing oil "off road use only" sorta stuff, but it only really comes in 20/50 weights, or add some cam break in lube to your oil, like the stuff Comp or Crane sends with their cams. Its loaded with the good stuff.
Old Nov 13, 2007 | 09:59 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
I wasnt aware that the lack of zinc was an issue. I havent owned the same engine long enough to know, but between my freind and i, we run high mileage full synthetic mobil 1. Hes been running it in the same olds 350 for about 4 years now, and its in good shape for such an old engine thats pushed so hard.'
Youre right, 15w40 isnt much thicker than 10w30, but it makes the difference on start up. The quicker you can lube the engine at its peak wear moment, the better it is.
I think we can all agree though, 300 miles is premature wear for a cam the way youre describing. Curious to find out what happened, cuz im stumped.
Old Nov 14, 2007 | 12:27 AM
xpndbl3's Avatar
Car: 1984 Z28
I know it's probably a bad batch of lifters that comp was known for probably 2 years ago or the hardness on the cam suffered, I'll find out later this week when I tear into it.
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
Jorlain
Oct 8, 2015 01:57 AM
Stryker412
Sep 7, 2015 09:11 AM
TheExaminer
Sep 6, 2015 11:40 PM
greenyone
Sep 2, 2015 03:39 PM
