Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
front bumper ?
Old Jan 17, 2008 | 06:04 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
front bumper ?
well i am finally going to lighten my car up . it has become mostly a track car that i drive on the street once in a while.
i have the nose off the car and the front bumper bar and honeycomb off. should i put a lightweight brace accross where the bumper mounted ?
Old Jan 17, 2008 | 06:53 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: front bumper ?
I never did but mine is a track only car.
Old Jan 17, 2008 | 07:08 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: front bumper ?
i plan on just hitting the factory support with a plasma cutter to lighten it up as much as possible. The nose can fold flat at high speed, so it needs some sort of reinforcement
Old Jan 17, 2008 | 09:35 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: front bumper ?
Just how fast do you plan on going? My nose stays in place at 140 mph. The bottom spoiler may fold under slightly but I don't have any top end pictures to confirm it.
Old Jan 17, 2008 | 10:10 PM
xpndbl3's Avatar
Car: 1984 Z28
Re: front bumper ?
at 140 i've seen pics of the nose looking like a brick wall, can't be good for aerodynamics
Old Jan 17, 2008 | 11:05 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: front bumper ?
Depends how much you remove. I still have the brackets on the inside of the headlights attached to the rad support.
Old Jan 17, 2008 | 11:10 PM
car_fixer's Avatar
Re: front bumper ?
mine hung down low enough to drag the track before i put some aluminum braces at the bottom, I have seen half track vids only but it looks ok now.
Old Jan 17, 2008 | 11:44 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Axle/Gears: 4.11
Re: front bumper ?
thats what i was lookin at doing . a aluminum brace accross the bottom of the bumper bolts holes and some braces going out to the bottom of the nose piece. and i was leaving in the brace between the headlights.
Old Jan 18, 2008 | 12:02 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: front bumper ?
well, if you went with a sportcoupe bumper cover you wouldn't need it. they are stiff enough to not require any support underneath. i love having a sportcoupe!
Old Jan 18, 2008 | 04:51 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Re: front bumper ?
What is the average weight of the front bumper support. I took mine off and it cant be more than 20 lbs, and its steel.
Old Jan 18, 2008 | 05:44 PM
mw66nova's Avatar
Engine: 7.0L
Re: front bumper ?
mine weighed in at 30lbs., steel bumper as well.
Old Jan 19, 2008 | 01:24 AM
JesasaurusRex's Avatar
Re: front bumper ?
mines completely out and doesn't fold
Old Jan 19, 2008 | 07:12 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: front bumper ?
front bumper and attaching hardware was 24 lbs on a scale when I removed mine, I had to put aluminum brace from the bottom of the core support to just behind where the front plate would go, nice and straight at 143mph so far
Old Jan 19, 2008 | 08:36 AM
automec's Avatar
Car: 82 Z-28
Engine: 408
Axle/Gears: 4.11
Re: front bumper ?
mine weighed 35lbs. on my digital scales with all the honeycomb stuff on it. so far i have droped 100 lbs. !! plus i am moving the battery to the back.
oh ya , how did you guys reattach your turnsignals? mine mounted to the bumper piece that i have removed. i was thinking just a couple of little angle brackets to hold them to the nose piece.
Old Jan 19, 2008 | 01:46 PM
mod313's Avatar
Car: Camaro
Engine: 305-150/254 combo
Transmission: TH350 or T200
Axle/Gears: Srange 12 bolt; 5.14 or 5.38
Re: front bumper ?
Just locate an aluminum support from the 82-84 and swap out the steel one. Minor trimming will be needed to the honeycomb part to fit it to the 85 and up years.
Old Jan 19, 2008 | 02:08 PM
xpndbl3's Avatar
Car: 1984 Z28
Re: front bumper ?
I have yet to see an aluminum one. I know a guy who has parted out probably 300 thirdgens of all different years and he's never had one either. Looking in junkyards for probably 8 or 9 years locally for the ever elusive aluminum support from 82-84
Old Jan 19, 2008 | 02:17 PM
mod313's Avatar
Car: Camaro
Re: front bumper ?
Check on Ebay. Myself and most of us in Stcok and Super Stock have these pieces. Most common in the Z28's but can be found in non-Z's too. Not as uncommon as you might think, these may also have been painted black so you may not have recognized it visually. When I picked up mine, that same boneyard had three of them in cars in the yard.
Old Jan 19, 2008 | 02:32 PM
mw66nova's Avatar
Engine: 7.0L
Re: front bumper ?
i too have never seen the aluminum bumper support. i thought about getting one, but i really just don't see the need on a car that barely gets driven.
Old Jan 21, 2008 | 01:00 PM
kamu's Avatar
Car: 84 Z28
Engine: 400
Transmission: tex racing t101a
Axle/Gears: 4.56
Re: front bumper ?
Now I know why mine did not weight much when I removed it..I have a 84 sport coupe with the aluminum bumber. I just thought they all were aluminum.
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
mikey8494
Aug 22, 2015 07:57 PM
Wylecoyote08
Aug 22, 2015 01:58 AM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
