Few Questions
Few Questions
I know this migh tbe hard to answer but im looking into getting a new car and need some help
the car has 40 passes on the motor and 20 passes on the trans
is this ok and will the motor and trans last or does this throw up red flags
just need some help because im new to this stuff
also the motor has forged internals and aluminum heads
thanks
thanks
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Re: Few Questions
We will need all the specs of the motor how fast is the car? On a typical bracket racer you will be fine. A heads up car that runs in the 7s may need some maint.
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Re: Few Questions
Yes you will be fine do a compression and leak down test on the motor. Look at the tranny fluid and rear dif look for metal and to see if the tranny fluid is burnt.
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
Re: Few Questions
my last motor had over 400 passes on it and 10k street miles . plus at least 150 of them were on spray. 3 years of racing. when i pulled it apart to ck it , everything was fine. it ran 11.4 on motor and 10.3 on spray. i put the moser rear end in in 2002 , built the trans in 04. all i have done to them is change oil.
to me that sounds like it is just broke in.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Re: Few Questions
my old 388 had over 1800 passes and 5-6K street miles on the entire combination, was still running great but the crank snout broke off...alternator and pulley set up problem more than anything else, so with those low a passes i would'nt be scared in the least...heck, i just put on more than that in the last weekend racing and previous weekend 1 day test and tune.
Ross gave good advise, compression and leak down test, trans fluid check, rear diff oil check, but if it is new gears, expect some metal shavings...you can get a cutter and peel open the oil filter since this will show exactly what's going on inside the engine with the bearings...if you see big chunks of copper, budget for a new engine..if just tiny speckles of metal..that's normal for a new engine.
40/20...not even broke in yet LOL!!
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Few Questions
my 158K mile motor had like over 20 passes on it and countless 'passes' on the street
held up great
if yours was fresh and has done 40 passes with some oil changes between, your fine or should be fine
held up greatif yours was fresh and has done 40 passes with some oil changes between, your fine or should be fine
