Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
finally i got a camaro again. what u think?
Old May 11, 2008 | 10:25 AM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
1988 iroc z everything was there but a motor. it has subframe connectors, hotchik lca and penhard, drag shock, build 350th with fully manual vavle body,4500 STALL WHICH IM SALLING using my 3500 stall, has holley feul pump with 9/16 in hose, has a be cool radiator. trans cooler with its own fan, has a vacuum pump and msd ingnition. do u think my 1/4 mile time will be better?
Old May 11, 2008 | 10:49 AM
intex1982's Avatar
Re: finally i got a camaro again. what u think?
here is some pic
Old May 11, 2008 | 10:56 AM
intex1982's Avatar
more
Attached Thumbnails finally i got a camaro again. what u think?-051008_15121.jpg   finally i got a camaro again. what u think?-050908_18511.jpg
Old May 11, 2008 | 11:00 AM
intex1982's Avatar
pics
Attached Thumbnails finally i got a camaro again. what u think?-051008_17001.jpg   finally i got a camaro again. what u think?-050908_09361.jpg   finally i got a camaro again. what u think?-050908_09371.jpg
Old May 11, 2008 | 11:02 AM
intex1982's Avatar
last one
Attached Thumbnails finally i got a camaro again. what u think?-050908_09381.jpg
Old May 11, 2008 | 11:32 AM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Im jealous man i wish i had a good body to put my engine in... did you have SFC and all the goodies that the new car has on your old caR?
Old May 11, 2008 | 12:37 PM
intex1982's Avatar
had boxed lca and penhard no sfc and msd
Old May 11, 2008 | 12:43 PM
Car: 92 Camaro
Axle/Gears: S60 373
I'd say the times would be the same, maybe .1 difference.... run it and find out man!
Old May 11, 2008 | 01:26 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I didnt notice any time difference with subframes....cause i went to a whole bigger engine when i put them on, couldnt tell
Old May 11, 2008 | 03:25 PM
intex1982's Avatar
well i run 12.88 on old set up with 3.73 gear. new set up has 4.10 and build trans and better susp.
camaro11j
Sep 19, 2018 08:49 AM
Polo Z03
Sep 10, 2015 06:43 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
