Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Rear Suspension Help
Old May 12, 2008 | 04:06 PM
redformula88's Avatar
i own an 88 formula that im finishing up and getting ready to hit the track in but i need help setting up the rear suspension.here is the list of goodies:
438 ci 10.9 to 1 comp.,ported victor jr. heads, super victor with 1150 dominator,nos big shot set at 300hp, the rear is a moser 9'' with 35 spline and spool, bmr extreme everything(torque arm, lca, panhard) strange adjus. shocks and stock springs.
the rear end was squared when i had the allingment done on the front end and i know i have to set the pinion angle but what else do i need to adjust on the rear susp? do i need to adjust the lca and panhard, if so how do i do it? also whats the best way to set the pinion angle? thanks
Old May 12, 2008 | 06:56 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Rear Suspension Help
Pinion angle is adjusted with an aftermarket adjustable torque arm. Measure the angle of the driveshaft. Measure the angle of the pinion. There should be 2-4* down angle on the pinion in relation to the driveshaft. Changing the ride height (lowering springs etc) will change the pinion angle.
Panhard bar just keeps the diff centered under the car. Unless you do drastic suspension changes, it never needs adjusting.
LCA should be parallel to the ground or down slightly at the rear. Using LCA relocation brackets allow the back end to drop down. If the suspension is lowered, this will help make the LCA parallel again. It can be down slightly at the rear but the rear should never be higher than the front.
Old May 12, 2008 | 08:11 PM
DIGGLER's Avatar
if your stuff is all rod ended instead of poly bushings, i would run -1 pinion angle. -2ish for bushings.
Old May 12, 2008 | 08:20 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Originally Posted by Stephen 87 IROC
Pinion angle is adjusted with an aftermarket adjustable panhard bar.
adjustable torque arm you mean i'm sure.
Old May 12, 2008 | 11:17 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I stand corrected
Old May 13, 2008 | 06:12 AM
I was told to start at -3 pinion angle. Yes everything in the rear is rod ended. thanks
Old May 17, 2008 | 04:35 PM
badsonic's Avatar
Car: 84 Berlinetta
Engine: 360
Transmission: 350 turbo
Axle/Gears: 9"/4.11
mine works best 2 3/4 with my spohn torque arm
Old May 17, 2008 | 07:57 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
I'm running a 4 link in my GA, and only running about -1/2 degree pinion angle. That's where it works the best. I used to run leaf spring cars and every body used to say -4. Mine never worked with that much. I'd start with -2 and try it. What kind of tourque arm mount do you have? That will determine what angle you need to run. The tighter it is the less of an angle you will need. If you go too much, the car will start hopping, and unloading the tires.
Old May 18, 2008 | 11:06 AM
DIGGLER's Avatar
bingo. nobody realizes more pinion angle doesnt make the car hook. all your trying to do is put the trans,driveshaft, and rearend in a perfectly straight line when the suspension is loaded and going down the track.
with my rod ended stuff i run -1.
customblackbird
Aug 15, 2021 10:16 PM
bjpotter
Jan 22, 2019 12:27 PM
cam-mike
Aug 24, 2015 07:23 AM
