Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Bolt in roll cage for AutoX
Old May 13, 2008 | 08:35 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
My first question is if in AutoX STS class, is a roll cage legal since I know that subframe connectors aren't. My reason for asking is that I hear that a cage will stiffen up the chasis some, would this be beneficial. If so I would just want a bolt in 8 pt tops so that I can remove it after each event. My car is my DD also. Its an 89 RS
Old May 13, 2008 | 09:10 PM
Stephen's Avatar
Car: 87 GTA
Re: Bolt in roll cage for AutoX
http://www.scca.org/documents/Solo%2...lo_Rules_2.pdf
Cages & SFCs are both legal in STS, as it conforms a lot to Prepared. Both can be welded or bolt-in, you just can't cut body metal to fit them. IE:custom built through floor SFCs are not allowed..
Old May 14, 2008 | 08:37 AM
slow305's Avatar
Car: 1982 Z28
Engine: LC9
Transmission: AR5
Pretty sure SFCs are NOT legal in STS. The only mention of "subframe" in the ST* rules is in regards to bushings. SFCs were added to the rules just this year for Street Prepared, and there's a whole section that outlines the specifications on what you can and can't do.
The Solo rules reference the General Competition Rules (i.e., roadrace) as far as rollbar/cage requirements.
For open cars in the Stock, Street Prepared, Street
Touring, and Street Modified categories, the roll bar or roll cage
height may be reduced from Appendix C or GCR Section 9.4 requirements
to the highest possible height which fits within an installed
factory specified hardtop or convertible top.
As far as whether it's beneficial, anything can probably help the flexible flyer chassis. My ESP car has a four-point bar (I think only because it was used for hillclimbs or Solo I at one point in its life), but I'm going to take it out once I get SFCs installed.
Pat
Old May 14, 2008 | 01:53 PM
Stephen's Avatar
Car: 87 GTA
After re-reding thge rule book, over & over all this morning, your right. I think my Search ended up in PreparedClass & I didn't realize that.
SFCs are NOT allowed in STS. Cages are, welded or bolted-in. Even in Stock category....
13.2.H. Roll bars and roll cages may be added (See Appendix C). It is strongly recommended that roll cages be constructed according to the GCR, though they must be bolted (not welded) into the automobile and be contained within the driver/passenger compartment. Roll bars may be welded in. A roll cage has more than four attachment points to the body or frame, or has bracing both fore and aft of the main hoop.
Old May 14, 2008 | 04:51 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I thought SFCs were illegal. Anyone know of a 6pt cage that is bolt in, or at least so I can get rid of the bars by the door?
Old May 14, 2008 | 05:04 PM
Stephen's Avatar
Car: 87 GTA
Just take the weld-in mounting plates, drill 4 holes on them, bolt them in instead & copy them for backing plates on the other side. I know of bolt-in SFCs, but not bol-in cages. Not saying they aren't out there, I just don't know of any sold that way.
You can always buy the step-down door bars & a 4-pt cage.
Old May 14, 2008 | 05:59 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
So then this one from Spohn would work:
http://www.spohn.net/?action=product&pid=1211
Looked at the Wolfe bolt in 6pt roll bar. Does it all come in seperate pieces and bolt together requiring no welding?
http://www.wolferacecraft.com/detail.aspx?ID=242
Old May 14, 2008 | 08:59 PM
slow305's Avatar
Car: 1982 Z28
Engine: LC9
Transmission: AR5
Also check out Autopower for bolt-in bars or cages:
http://www.ioportracing.com/Merchant...ry_Code=AP7150
I still think you're better off getting better tires if you want to go faster. You will have faster times on an autocross course with stickier tires more than any single bolt-on mod.
Tires, shocks, springs, alignment ... then worry about other stuff like rollbars/cages.
Pat
Old May 14, 2008 | 09:03 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I'm working on getting that stuff first for sure. I'll be getting a set of Koni Yellows for the rear Bilsteins, some sort of new springs, got WS6 swaybars, wonderbar, will be doing bushings. The rollcage will be one of the last things on the list.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
billybob6110
Sep 23, 2015 01:30 PM
Jlanz55
Sep 6, 2015 07:28 PM
FormulasOnly
Sep 6, 2015 10:42 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
