Battery cut-off switch
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: Battery cut-off switch
i highly doubt it. it needs to be right there in the open so everyone can see that you have a cutoff switch.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Location is questionable but I doubt it. Depends on your tech inspectors. Off is also not clearly marked.
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I would let it pass once and tell you that it better be much more visible next time. how about a big arrow sticker on the lower portion of your bumper? And yes, you need to have "OFF" undeniably visible. Look at it this way, put yourself in the starter's shoes. Now say this car caught fire at the 60' and you went running up to the car, would you be able to notice the switch?
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
Would this be a better place?
Car: 1982 Trans am
Engine: 383
which one of theses wires do I have to run to the battery to kill the engine when the switch is turned off?
Car: 1983 z28
Engine: 383 .060=388
Transmission: th350
are you running a 4 or 2 post cut off switch? if a 2 post you want to run the heavy gauge wire from the back of the alt to the back. if your running a 4 post you want to run the alt field wire (one of the 2 wires on the clip at the top it will be marked with an F) to the back.
Car: 1982 Trans am
Engine: 383
I was going to put it there but I don't want to drill a hole in my taillight. And I wanted keep it mostly hidden cause I still use this car as a daily driver and I know if someone walks by my car and they see a switch that says off in big bold letters there either going to turn it off or try break it off.
Car: 87 IROC L98
So install the switch inside the car with a rod that goes through the back to the outside. Install it so push is off. When not at the track, remove the rod and put a plug in the hole.
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
FormulasOnly
Sep 10, 2015 09:07 PM
