Gap
Transmission: 4L80E/4L80E
Run it stock unless you have upgraded the ignition.
Close it down if you run nitrous.
.005" increments to evaluate changes.
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
Re: Gap
Nothing about my car is even close to stock now lol So how would I go about figuring it out?
Start by looking at the information about your heads, calling the manufacturer if necessary. That's were 90% of the variability lies.
Re: Gap
I just got off the phone with AFR and MSD and AFR told me to call MSD and MSD said .050 to .060 would be fine with a sbc with 10.5:1 cr N/A. Does this sound about right it seems to be a bit big but maybe not. Thanks
Sounds about right.
Back in the early days of HEI, the factory was using .060" gap. MSD should be able to zap that without any trouble.
I'm surprised AFR didn't have more to say.
Re: Gap
Yea I thought AFR would have more to say as well. I think I'll probably set it at around .050 unless anyone thinks differently? Thanks again
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Gap
Mine are at .035 but I'm also dumping a lot of alcohol into the cylinders. Same goes for NOS. You need a smaller gap so the spark doesn't get blown out but need a hot ignition to keep it lit. I use a HCV-2 coil. 2 full amps of spark energy.
I've never played with plug gaps very much. I increased them to .045" once and didn't notice much of a difference.
Re: Gap
What about all you sbc guys that are N/A with an MSD ignition? what are you's running? Thanks for the help
Re: Gap
Is that also because you have nitrous or no? Anyone else tell me their gap size because now im confused why the guy at MSD told me .050-.060" Thanks guys
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Re: Gap
I've never noticed any performance difference with any of the plug brands nor gapping when i used to piddle around with that stuff back in the day, but like i said, i've been very happy with these new race plugs, they've never crapped out on me, i just change them once maybe mid season for piece of mind, but they always look great and have never put me into a spot where i had to swap them out.
Car: 87 IROC L98
Re: Gap
Trying different gaps doesn't make a big change in power. Indexing the plugs probably has a better result. Index the plugs so that the ground strap is up. This allows the spark to go directly at the top of the piston instead of around the ground strap. The main reason I index my plugs is because I have huge dome pistons and if the plugs are not indexed, the piston will hit the ground strap.
Read this page
http://www.centuryperformance.com/sp...ch-spg-26.html
Read this page
Re: Gap
We have to index the plugs in the S10, talk about a major PITA!!!! if i ever had an engine like that, then i know for sure they would get installed new at the start of the season and that would be it...indexing sucks azz!!!
Car: 87 IROC L98
Re: Gap
Indexing with the heads off is so much easier. When indexing, buy 2-3 sets of plugs. They're not really that expensive. I think my NGK race plugs are less than $3 each. Keep trying different plugs in each hole until you get them indexed without needing washers.
Of course if you want to try a different heat range, you need to index another complete set and have them marked for specific cylinders when you change them. I was going to find some way to have an 8 plug holder that could fit in a drawer just for that purpose. I found a nice 6 compartment holder that would work but couldn't find an 8 compartment one. Look in the fishing section of a sports store. Lots of cool little tackle holders just the right size to hold plugs.
Car: '82 Z28
Re: Gap
That and it seems to not break up at the top end like it used to with a larger gap. Mosts of my runs are off the nitrous but I'll be using it more now that the car is legal to run quicker than 11.49.
Re: Gap
I have had different results with different plugs. Mainly I run autolite ar3910, gapped at .035 (untill i went up on nitrous) that plug is a projected tip, I have tried an AR3932, which is one step colder and non-projected, that plug just doesnt work at all for me, no matter what gap or weather i index them, it will not run good under load. I was going to try some NGK plugs but some unknown debris in oil pan stopped that, turned out that the valve springs were deburring the head lol
diana227vegas
Jul 8, 2016 12:27 AM
roysatikas
Sep 22, 2015 08:15 PM
Dialed_In
Aug 20, 2015 01:45 PM
