Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
New best, Almost touching 11's!!!!!
Old Aug 16, 2008 | 08:05 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Well I went last night and got my new personal best.
60 ft -----1.62
1/8 et-----7.641
1/8 mph---90.02
1/4 et-----12.01
1/4 mph---112.45
I need to do some more carb tunning and add some 110 race fuel and it should hit 11's. Im still thinking of getting a Cervini hood and going with a S10 steering box. Im still running stock LCA's and no subframe connectors.
My old best is in my sig.
Old Aug 19, 2008 | 08:48 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Re: New best, Almost touching 11's!!!!!
Is my mph low for my ET??
Old Aug 19, 2008 | 12:34 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Not sure how the MPH relates to ET..but either way nice time!
Old Aug 19, 2008 | 12:40 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Nice times. Not necessarily for an automatic car.
Old Aug 19, 2008 | 01:31 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
1989GTATransAm Nice times. Not necessarily for an automatic car.
So say a 5 or 6 speed might get more mph with my same setup? Not that I am going to change but just curious.
Old Aug 19, 2008 | 01:50 PM
Car: 1989 GTA
Engine: 369 TPI
From what I have seen that is generally true.
Old Aug 20, 2008 | 07:32 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I still need to jet the carb for max mph and tune a little more.
What do you guys suggest to get me into the 11's and stay there?
Old Aug 21, 2008 | 07:42 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Im running a comp xe282hr-12 hyd roller cam. Im running 1.5 Crane Gold RR's.
The lifts with the 1.5's are .510 and .520 lift.
If I go to 1.6 rr's then the lift jumps to like .545 intake and .555 exhaust. My heads flow good at that range. Will going to the 1.6 rr's help much or is it not worth it?
Rousseau92maro
Feb 1, 2016 05:12 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
327IROC85
Sep 23, 2015 12:11 AM
timonator
Sep 17, 2015 06:57 PM
