Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
First time at the track 305 tpi
Old Sep 2, 2008 | 12:22 AM
bmfIROC-Z's Avatar
i was just wondering how i did for my first time at the track?,i dont have a scanner or digital camera on hand to post my time slip yet but heres what i ran shifting a little late at about 6k rpm(got a little excited): (r/t -.506) ,(60ft-2.025),(330ft-6.081),(1/8 mile-9.491@72.11mph),(1000ft-12.419)and (1/4 mile-14.887@91.36mph)the car weighs 3480lbs with me in it and 1/8 tank of gas,does this seem about right for my mods? and what could i do to improve?thanks in advance,joe
Old Sep 2, 2008 | 07:15 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: First time at the track 305 tpi
i would honestly have expected you to go a little quicker.
were you experiencing any tire spin?
Old Sep 2, 2008 | 07:41 AM
vette9190's Avatar
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
Shifting a 6k? was it still pullin that hi up? Maybe shifting it at around 5200 would work better. the 305 can pull more rpm then a 350 from the tpi setup but i wouldn't think that much more. Also might be time for a stall converter.
Pete jackson gear drive huh, how does that thing work with your knock sensor? when my buddy tried to use one it caused his knock sensor to go crazy.
Old Sep 2, 2008 | 08:11 AM
bmfIROC-Z's Avatar
yeah i kinda expected a little quicker times to but no off the line i got pretty good traction on street tires,im thinking i just over reved a bit from 2nd to 3rd cause im used to shifting by ear and with the tpi it kinda screwed me.
Old Sep 2, 2008 | 08:22 AM
bmfIROC-Z's Avatar
yeah somewhere around 6k,it was still pullin a little i think but im used to shifting by ear so on oct 3rd im going back and im gonna put my aftermarket tach back in and set my shift light to 5200 and see what that does,as for the gear drive i havent had a problem with it i heared it was mainly the (loud) gear drives that caused problems with the knock sensor because of to much harmonic disturtion,what kinda times you think i could pull shifting at 5200?
Old Sep 2, 2008 | 12:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
These are ported stock runners? You aren't "pulling" beyond 5200 RPMs, you're only "spinning".
Shifting at 5200 will pick you up a little, but probably no more than a few tenths.
Old Sep 2, 2008 | 12:59 PM
vette9190's Avatar
maybe 2-3 tenths
I see ur using a maf setup with a hypercrap chip. I would look into a custom prom. I use speed density which obviously needs more stuff done in the chip when modifing the engine butI think with a good custom tune you could make better use of all that power. Do you have a wideband? I would get one to help tune that thing and I wonder if wit all ur mods those 19lbers are enough to feed that thing. maybe even a walbro intake pump to help feed her
also I see you have some upgrades to the ignition but no box. With all that done a MSD 6 or a Accel 300+ ( I have used this ignition on all of my 87 up f bodies with great results. Got 5 mpg more out of my 87 and knocked a little more then a tenth off with just that system. its a nice multistrike kit).
I like ur list of mods but some small tweaking like this might help bring it all together.
by the way were in IL are you? I am not familar with Galesburg. What track did you go to?
Old Sep 2, 2008 | 03:46 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
Upgrade your suspension.When I had my 86 IROC with a lot of the mods you have I was able to run 13.90's consistantly.Installing subframe connectors, Spohn adj torque arm,Spohn relocation brackets,aftermarket LCA's etc I was able to pull 1.9 60'.Also had a chip burned for it by a friend that put the $400 chip by Performance Resource to shame.
Old Sep 2, 2008 | 04:17 PM
bmfIROC-Z's Avatar
maybe 2-3 tenths
thanks for the help man,im about 45 minutes away from peoria off 74 and it was cordova dragway near cordova il that i raced at.
Old Sep 2, 2008 | 04:23 PM
bmfIROC-Z's Avatar
wow thats pretty quick,is there anybody on here who would burn me a custom chip for a decent price?
Old Sep 2, 2008 | 07:48 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Better off learning to do it yourself.Really wish I would have then instead of now.Also had 22# injectors & 3,000 stall vig converter or else I'd sell you my chip.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
