Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
fitting
Old Sep 26, 2008 | 12:53 PM
gtpro700's Avatar
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
fitting
Do you guys know what fitting I would need to go from the power steering pump to -6an ? I am going ot post a link to what I think mightb e it can you just let me know. Thanks
http://store.summitracing.com/partde...5&autoview=sku
Old Sep 26, 2008 | 01:16 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
Re: fitting
Almost 100% positive it is the 16mm to -6an. I know this because it takes the same fitting to adapt the fuel inlet into the back of the TBI unit to AN fittings.
Some models may take the 18mm fitting.
The fittings on the back of the injector pods on TBI units are 16mm inlet and 14mm outlet. My power steering took the same fitting as my inlet into the injector pod.
I will double check for sure this afternoon. I have a spare p/s pump and extra 14mm/16mm to -6an fittings. So, i will test fit them and will let you know by 5pm central time. OK?
Old Sep 26, 2008 | 06:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: fitting
The steering box is 16mm and 18mm. The larger line should be from the pump. The smaller line is the return.
Aeroquip part numbers
FCM2608 -06 M16 x 1.5
FCM2609 -06 M18 x 1.5
Old Sep 26, 2008 | 06:43 PM
dctrumpet's Avatar
Re: fitting
Stephen... I agree. Just checked mine.
Earl's @ www.ANPlumbing.com
991956 18MM X 1.5 -6 Fuel Injection / Power Steering Adapter. Male -O-Ring Seal. $5.95
991955 16mm x 1.5 -6 Fuel Injection / Power Steering Adapter. Male -O-Ring Seal. $5.95
Old Sep 27, 2008 | 11:15 AM
gtpro700's Avatar
Re: fitting
Thanks for the help guys! going to go order them now
Old Sep 27, 2008 | 11:18 AM
dctrumpet's Avatar
Re: fitting
Good luck!
It's always nice to see step-by-step photos and description if you have the time to do so. This would definitely help anyone in the future doing what you're doing.
Just an idea!
Old Sep 28, 2008 | 02:13 PM
gtpro700's Avatar
Re: fitting
I was wondering if an adapter was made that went from 5/8-18in inverted flare to 18mm x 1.5? Thanks
Old Sep 28, 2008 | 04:34 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: fitting
most likely not, what would you use that for?
if you meant 5/8 inverted flare to 6 an, then they do exsist
Old Sep 28, 2008 | 10:58 PM
gtpro700's Avatar
Re: fitting
I didnt think they did but was just wondering because I bought a new PS line and bought the new pump after and the new pump is 5/8 inverted flare and the factory line is the 18mmx1.5. I am going to just have to spend about 60 + bucks to make an AN line for it now lol thats building a car though everything is expensive and goes wrong lol
Old Sep 13, 2009 | 02:52 PM
1987CamaroZ28's Avatar
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Axle/Gears: factory 9 bolt with 3.45 gears
Re: fitting
I went by this thread and ended up ordering the wrong fittings. My steering box supply and return fittings are 11/16" and 16mm. The 11/16" line should have the Oring seal because that is the input that has a pressure sensative inlet, the other fitting is completely open. So frustrating to get the wrong parts mail ordered.
Fronzizzle
Feb 9, 2017 09:31 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
