Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Intake swap results
Old Jan 22, 2009 | 06:35 AM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Intake swap results
I switched out intakes to gain some hood clearence and et. went from a Holley keath dorton strip dominator with a 2'' adaptor for a 4500 carb to a motown 4500 intake. I went out to the track early last night put down 5 pass in 2.5 hrs first pass cold I went 10.001 at a 135.58mph and the last pass was a 9.91 at 136.19mph my best et before was a 9.95 and best mph was 134.27 so the conclusion intake was worth about 20-30 hp just need to find the new shift points also 60ft times best with old manifold 1.37 new 1.35 I was done racing and loaded up at 9:15 last night and watching every one else race from the stands.
PS: I know im lucky to live in south Fl.
Old Jan 22, 2009 | 08:15 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Intake swap results
That's not a very good comparison unless the intake swap is done on the same day. Comparing results on different days means nothing unless you have all the weather conditions factored in. Your results may actually be worse than before but better weather conditions make it look better.
Old Jan 22, 2009 | 08:29 AM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Congradulations! Sounds like the swap was worth it.
Old Jan 22, 2009 | 08:35 AM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
It may not have been on the same day but I have run the car enough to know what it runs it's like running a bracket car so the 2 mph gain is what I am using as a reff point.
Old Jan 22, 2009 | 02:37 PM
Shagwell's Avatar
Car: projects.......
bradenton?
Congrats on the results.
Old Jan 22, 2009 | 06:15 PM
slow86305's Avatar
Car: 86 camaro
Engine: 572
Transmission: TH400
congrats on a new best!!!!
Old Jan 22, 2009 | 08:33 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Thanks every one.Shagwell I live close to PBIR or the old moroso. I will be back in braditon for the nmca race. Hay tanks slow how are your two babys doing?Have not seen you lately.
Old Jan 24, 2009 | 09:03 AM
slow86305's Avatar
Car: 86 camaro
Engine: 572
Transmission: TH400
lol. How did you find out? They are doing well. Its a boy due may 20. I got my motor and its big heavy bitch.
Old Jan 24, 2009 | 12:07 PM
onebadzz's Avatar
Car: 1991 Camaro RS
Engine: 555ci BBC
Congrats, any time you can go faster for just alittle change is great.....
Old Jan 24, 2009 | 06:19 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Slow your buddy that went to SAM. ratted you out the last time I saw him at the track. CONGRATULATIONS its a BOY. I hope every thing works out good for you three..
Thanks badzz.
midge54
Jan 29, 2017 07:00 PM
bamaboy0323
Sep 3, 2015 06:07 AM
theshackle
Aug 22, 2015 06:52 PM
theurge
Aug 21, 2015 12:46 PM
