Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
spring rates???
Old Apr 28, 2009 | 11:49 AM
auto-x1990RS's Avatar
Car: 1990 Camaro RS
Engine: 3.1 MPFI V6
Axle/Gears: 3.23 open diff
spring rates???
i've got a question here. i'm thinking about either dropping in a 496 or a 6.6L TD into the RS for auto-x. i know both engines are heavy (the 6.6L even more so) and i was wondering what the highest spring rates are that could be run on the front???
any input would gladly be appreciated
Old Apr 28, 2009 | 11:54 AM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
Re: spring rates???
as much as your butt can tolerate.
http://stockcarproducts.com/hyper2.htm
places like this will have much higher rates and different lengths available
Old Apr 28, 2009 | 04:11 PM
Tpx's Avatar
Tpx
Car: 1982+1988 Z28 Camaros
Engine: 1982=350 carb 1988=383 Carb
Transmission: 1982=4 speed T-10 1988=6 speed T56
Axle/Gears: 1982=stock
Re: spring rates???
perfect dragon, I've been looking for this info too. What dimensions do our cars take?
The site lists two sizes: Available in 5 1/2" o.d x 12" long and 5 1/2" o.d. x 11" long
Also, what is the stock rate, somewhere around 700# right? I'm thinking of getting 1000# springs for my SBC equipped third gen front+rear.
Old Apr 28, 2009 | 07:10 PM
Car: 1990 Camaro RS
Engine: 3.1 MPFI V6
Re: spring rates???
ok, i know that a Duramax (6.6L TD) is quite a bit heavier than what's listed. the engine alone is 1100lbs (diesel's are heavy). the 496 should be right around 750lbs full dress.
Old Apr 29, 2009 | 12:13 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: spring rates???
you want to autocross a diesel? first off I doubt it will fit in the engine bay let alone be a good idea even remotely. You'll want a snappy motor, you should be looking to reduce weight as much as possible, not add another 800 pounds to the nose of the car.
Old Apr 29, 2009 | 07:50 AM
Car: 85 Camaro IROC
Engine: 5.7 TPI
Re: spring rates???
yeah, you are completely correct... thats why you wont ever see any diesels winning lemans...
as for the rates, i made a spreadsheet that will tell you what rates to use based on weight and spring height ect.
unfortunately it doesnt work when i upload it or something.
i plan on using 900# 11" springs on my mostly stock weight camaro.
you would probably want to go with 1400 or 1500# in 12 or 11" length.
if you can give me a semi accurate front end weight i can give you a better guess.
Old Apr 29, 2009 | 01:41 PM
Car: 1990 Camaro RS
Engine: 3.1 MPFI V6
Re: spring rates???
well it's going to be around 1500-1700lbs front end weight. that's just taking a stab in the dark though, i'm not really sure what the front end of a Camaro weights.
Old Apr 29, 2009 | 02:51 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
Re: spring rates???
typical is about 1900 lbs on the front wheels
do you mean the engine weighs that much?
Old May 12, 2009 | 02:54 PM
rhit_rs's Avatar
Re: spring rates???
To be honest, I don't think either one of those engines would be the ideal choice. A potent, torquey small block would be plenty of power depending on how much tire you plan to run. The major advantage of the third-gen over other pony cars is it's relatively light weight. Drop in a diesel or a big block and you're handicapping yourself.
Before you start modifying the car, what class are you wanting to run? Do you want to be competitive in that class, or are you simply wanting to go faster? IMO, there are several other modifications you should make before doing anything to your engine (besides a general tune-up).
1. Get lots of seat time. Driver skill is by far the cheapest improvement you can make, and will make a larger difference than perhaps any modifications you make to the car.
2. Tires. What are you running now? Depending on what class you are running/plan to run, tires can make more of a difference than any other car modification. Switching to r-compound DOT tires (Hoosier A6, Kumho V710) from street tires is night and day difference and is the easiest way to improve your times. That being said, some suggest staying on street tires regardless of the class, until you want to be competitive. Street tires will help you learn faster since they won't cover up mistakes like race tires tend to do for beginners. Plus street tires are much cheaper
3. Suspension. A good set of shocks (Koni or Bilstein) also make a large difference especially in transitions. Stiffer springs that lower the car also help handling. I think most competitive 3rd gen auto-x cars are running somewhere between 700-1000 lb/in in the front and 200-300 lb/in in the rear, but I'm not 100% sure on that.
4. Brakes. Before you add power, it's good to be able to slow the car down quickly. At the very least, make sure your stock brake system is in good working condition. Bleed the brakes regularly and flush the system with good, fresh brake fluid. You can piece together relatively cheap brake kits from newer f-bodies and have 12" fronts and 11.5" rear disc brakes that have tons more stopping power than the stock setup. Depending on what class you plan to run, this may or may not be an option.
Give us more feedback on what your auto-xing goals are and we can give you better advice on how to get there.
Another great resource for auto-x info is www.FRRAX.com (F-Body Road Racing and Auto-X forum). There are some real pro's over there that have great advice.
Happy Apexing!
Josh
Old May 12, 2009 | 05:38 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Re: spring rates???
If you decide to go with the DMAX I want pics!!!! I have been helping out at a diesel performance shop and know that these things can make some serious power real easy and could get a 3rd gen moving in a hurry. If you go with the DMAX are you going to run single or twins on it???
Old May 12, 2009 | 05:42 PM
xpndbl3's Avatar
Car: 1984 Z28
Re: spring rates???
the DMAX would probably require new shock towers with all that added weight up front. Not to mention how wide they are, probably won't fit in between the towers even. It's all a pipe dream.
Old May 12, 2009 | 08:50 PM
Car: 1990 Camaro RS
Engine: 3.1 MPFI V6
Re: spring rates???
i've done three years and an advanced racing course through Bondurant. right now i've maxed out the car's potential. even Russ Wiles can't seem to get the car any faster (if you don't know the guy, he's like a friggen driving machine. he beat an STi with an Odyssey van)
i'd actually like to be competative right now actually, i was looking at 17" fronts (not exactly sure on width yet) and 17"x10" rears wrapped in 275/40-17 front and 345/30-17 rears. Hoosier A6's i've been running on Hoosier Radial GT's for the last two years, and they're finally done.
Happy Apexing!
Josh
over all it's kinda going to become a dual purpose car, auto-x and road racing (track days). the reason i like the Duramax so much is that bottom end torque (peak tq @ 1900rpm) and the fact that it doesn't really drop off till 4500rpm.
Old May 12, 2009 | 10:24 PM
rhit_rs's Avatar
Re: spring rates???
The Duramax will put waaaay too much weight on the front end, making it very tail happy and difficult to turn. With all the torque of a duramax and the weight imbalance, you'd just spin the wheels everytime coming out of a corner (even with 345's). Like xpndbl3 said, fitting it in the engine bay would be a major PITA.
An aluminum headed 383 can get you close to 500hp for a reasonable price, plenty for autocrossing, and enough to be fun on track days. If you want even lighter, you could go to an all aluminum LSX and perhaps make even more power.
What class are you running in/do you want to run in?
Josh
Old May 13, 2009 | 01:22 PM
Car: 1990 Camaro RS
Engine: 3.1 MPFI V6
Re: spring rates???
right now, i'm classed as NXF, i wouldn't mind running NXA or possibly RUS.
Old May 13, 2009 | 07:56 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: spring rates???
build a large LSX motor, its the way to go, kinda wish i went that route.
Old May 13, 2009 | 10:33 PM
rhit_rs's Avatar
Re: spring rates???
Are those NASA classes or something? I'm not familiar with those you mention. Could you elaborate on them please?
Old May 13, 2009 | 10:39 PM
Car: 1990 Camaro RS
Engine: 3.1 MPFI V6
Re: spring rates???
ya, it's NASA. my local club switched over from SCCA last year, and we're all getting used to it.
MrPackstin
Oct 25, 2017 08:09 PM
92projectcamaro
Dec 8, 2015 12:25 AM
tcflint
Sep 27, 2015 05:58 PM
Dragonsys
Sep 25, 2015 03:51 PM
