Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Post Wheel and Tire Setup
Old Jul 23, 2009 | 10:43 AM
Iroc Adio's Avatar
Car: 1987 IROC
Engine: Destroked 377
Transmission: TH-400
Axle/Gears: 9inch with 3.70's
Lets see what size slick or drag radial you guys are running.
Also what size wheel and back spacing.
Old Jul 23, 2009 | 11:24 AM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Re: Post Wheel and Tire Setup
Good idea. Wanna start it off ?
Old Jul 23, 2009 | 11:39 AM
Iroc Adio's Avatar
Car: 1987 IROC
yea heres mine with a 15x10 6" BS and a M/T 28x10.5S ET Drag
Old Jul 23, 2009 | 11:48 AM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Axle/Gears: G92 3.23, G80, J65 disc
im running a 15x8 wheel with 255/55 drag radials on them
i think its with 5" BS
Old Jul 23, 2009 | 04:18 PM
DIGGLER's Avatar
3.5" front, 10" rear weld prostars.
hoosier front runners, and hoosier 28x10.5 rears.
5.5" backspacing on the rears.
Old Jul 23, 2009 | 04:35 PM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
I'll be the first to post up the 28x11.5's ( 9 inch tire) on 15x8 wheel with
4.5 BS........***Yawn**** I want to go to 15x10 wheel soon.
Old Jul 23, 2009 | 06:36 PM
squeeezer's Avatar
Car: 5 cars
you must have a ton of romm between the tire and INNERfender well?????
im lookin to use a similar sized tire
mt et street 28x12.5x15=same size as yours
Old Jul 23, 2009 | 09:39 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
15x10 weld draglites 5.5"bs w 275 mt street radials... pic in sig theyre about even with the fender lip, not quite "tucked"
Old Jul 24, 2009 | 08:24 AM
Iroc Adio's Avatar
Car: 1987 IROC
anyone running a 325/50/15 M/T drag radial?
or how about a 28x10.5W M/T Et Drag Slick.
i just bought a set of 10.5w's ill be putting them on soon. ill have some photos
Old Jul 24, 2009 | 08:42 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
15x10 Billet Specialties Street Lites, 6.5" backspacing, 5/16" spacer, 29x9 Hoosier Slick, fronts are 15x4 with 1.75" backspacing, ls1 brake upgrade, and 5/16" spacer running a 165radial (going to go to a 27" hoosier up front)
Old Jul 24, 2009 | 09:21 AM
Shagwell's Avatar
Car: projects.......
15x15 - 5" bs, 33x10.5W - either going to less bs with the dbl bead locks or a wider rear when I swap it out. They need to be about 1.5 further out.
the car is about 1" lower in the front now, working on a front gfx.
Old Jul 24, 2009 | 11:14 AM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
one of my all time favorite cars here, between you greeze and ross lol. made me change my mind about the Billet Specialties wheels too...didn't really like them till i saw them on your car and RTK's
Old Jul 24, 2009 | 12:29 PM
stiletto's Avatar
Car: 85z28
Engine: sbc
Transmission: th400
Axle/Gears: 3.80 gear 35 spline axles
15x10 w/6" of back spacing with 295-65, this is old car, but same wheel and tire combo on new car
Old Jul 24, 2009 | 05:11 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Damn stiletto, i always thought that was the best tire fit i have seen yet for these, i think i will run the same size but i am trying to see what i have to do for the wheel.
Old Jul 24, 2009 | 06:30 PM
gtanut's Avatar
hey stileto was wondering what you had to do to the wheel wells to fit that wheel and tire combo thanks
Old Jul 24, 2009 | 11:31 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
15*4 in front with M/T sportsman and 15*9 With M/T et streets.
Old Jul 24, 2009 | 11:32 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
325/50/15 on 15x10 6.5" BS:
295/65/15 on z28's:
Old Jul 25, 2009 | 02:53 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
28x12.50 et street
15x10 6.5bs
28x7.50
m/t sportsman pro
15x4 rims
Old Jul 26, 2009 | 12:14 AM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
82z what'd the tread wear look like on those 295s running on those 7 inch wheels? i may have to keep using those if it seemed ok
Old Jul 26, 2009 | 12:23 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
I see no problem with the tires. Without the tires mounted on wheels, the bead width is quite close to 7" which is why I thought to use the stockers. Haven't gotten the motor setup quite right yet, but while the race motor was broke, the turbo on the 305 made for a wheelie on a semi-slick track.
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
i run the 275/60 15's on stock 7 inch rims and love the look.
Old Jul 26, 2009 | 12:46 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
15x15, 5.5" backspace 32x14 slicks.
Old Jul 26, 2009 | 08:02 AM
Iroc Adio's Avatar
Car: 1987 IROC
i just got my 28x10.5W slicks. im having second thoughts now. Id like to go with a drag radial. Ive been looking at the 275/60/15 M/T or the 325/50/15. I want to run the 325 but i have a 15x10 with 6"backspacing so im not sure if they will stick past the fenders
Old Jul 26, 2009 | 09:48 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Imagine this, but with the tire 1/2" farther out since this is a 325 with 15x10 6.5" BS.
Old Jul 26, 2009 | 10:50 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
What made you put that on the stock wheel??? LOL
Old Jul 26, 2009 | 01:02 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
The bead width of the 295's is quite close to 7" without the tire mounted, which is why I thought to use the stockers.
Never put the 325's on stockers, and I'm sure that wouldn't pan out too well.
Old Jul 26, 2009 | 10:30 PM
JesasaurusRex's Avatar
15x9 w/ 5.5bs
True 28x10.5
Old Jul 27, 2009 | 08:48 AM
stiletto's Avatar
Car: 85z28
Engine: sbc
Transmission: th400
the 6" back spacing wheels are hard to find. American racing pro series are hard to find. they no longer offer them. I was going to buy a spare set but cant find them.
Old Jul 27, 2009 | 08:52 AM
stiletto's Avatar
Car: 85z28
Engine: sbc
Transmission: th400
you will need a BFH, big friggin hammer and that will do it.
Old Jul 27, 2009 | 09:24 PM
superT's Avatar
Car: 1985 camaro z28
Engine: 355 sbc what else
Transmission: TH 350 manual vb/ 4200 stall
Axle/Gears: 4:30 on the street
Hoosier DOT drag radials (P255/50R16) on '88 front iroc wheels and for the front I got 20 year old 14x4 American racing multi-hole wheels with some cheap indy skinnies
FYI its looks like crap but it works so i don't care!!!!!!
anybody ever fit a 15" pro star over '99 SS rear brakes?
Old Jul 28, 2009 | 06:27 AM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
It can be done with a sustanial amount of grinding to the caliper.
Old Jul 28, 2009 | 11:57 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Yea, i can post some pics if you like of what they look like before and after grinding.
Old Jul 28, 2009 | 12:52 PM
squeeezer's Avatar
Car: 5 cars
Originally Posted by JesasaurusRex
15x9 w/ 5.5bs
True 28x10.5
most helpful
im getting the 28x12.5 et street same size as this one
Old Jul 28, 2009 | 01:12 PM
Iroc Adio's Avatar
Car: 1987 IROC
well ive decided to go with the 275/60 M/T Drag Radial.
So my brand new 28x10.5W are for sale. Never been mounted.
Ill post a pic with the radials once i get them
Old Jul 28, 2009 | 02:50 PM
superT's Avatar
Thanks guys, I wondered if I would have to grind or not. Never had a wheel to see.
If you could post those pics or just IM them to me, I would appreciate it.
Old Jul 28, 2009 | 04:22 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
No real good pics, but 28x10.5's on a 15x8 pro star, 15x3.5 in the front. BTW Fast Ls1: Is that your Bee that you're towing with? Any mods?
Old Aug 1, 2009 | 02:51 PM
87_TA's Avatar
15 x 8 Greg welds, 26 x 10" ET streets, will be using 28's again after these wear out. Thirdgen offset rear in car, 5" BS.
17 X 8 Stockers on truck, 35 x 12.5" BFG's..
Attached Thumbnails Post Wheel and Tire Setup-img_5491.jpg   Post Wheel and Tire Setup-img_5497.jpg
Old Aug 1, 2009 | 05:50 PM
86iroc2try's Avatar
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
stock rear 16x8 iroc wheels w/28x10 hoosier qtp's.....15x4 summit fronts with 26" hoosiers
Old Aug 4, 2009 | 12:13 PM
tcollinssr's Avatar
Car: 88 formula
Engine: 5.7
I,m thinking of going with hossier 28 x 10 x 15 with 5 1/2 " back set. Tried a pair on looks like i wont have problems with rubbing. What do you guys think?
Old Aug 28, 2009 | 02:16 AM
amng04's Avatar
Car: 1980 Malibu
Engine: 496 BBC (E85)
Transmission: TH400 w/brake
Axle/Gears: Moser 12 bolt 4.10
28x10.5W 15x10 6.5" backspace
Old Aug 28, 2009 | 07:14 AM
mw66nova's Avatar
Engine: 7.0L
nice! can't wait till mine is fast enough to justify a spoiler like that
Old Aug 28, 2009 | 07:33 AM
  #42
chikn305's Avatar
325/50/15 hoosier drag radial 15x10 5in bs (narrowed rear) 15x4 165r
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Fronzizzle
Aug 9, 2015 01:15 PM
