Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
getting it back together!
Old Sep 8, 2010 | 07:29 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
trans number 3 for the year! atleast the engine is finally staying together (Praise G0d!)
should be back together by this weekend.
HUGE HUGE HUGE thanks to Fast 383 and Shagwell for the converter and transmission. i'll be updating you guys over the next few days to let you know what it's like on the street. gotta build a crossmember and redo some of the exhaust stuff. should be getting started hard on it this afternoon after my calculus test.
Old Sep 8, 2010 | 08:11 AM
Shagwell's Avatar
Car: projects.......
Re: getting it back together!
That thing is gonna like having a low gear, lol.
Old Sep 8, 2010 | 05:10 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Keep us posted, good luck on getting it back together. Specs on the trans and coverter?
My car is in pieces now, sold my SBC to start the LS conversion. Mine won't be back together until Spring.
Old Sep 8, 2010 | 05:13 PM
mw66nova's Avatar
Engine: 7.0L
th400 has a bte pro-brake rmvb, alto red clutches, case saver, 34 element sprag, etc. the converter is a 9" unit, has a mechanical diod and anti-balooning plate. it should flash to 4800.
the trans is in the car, working on the crossmember now.
Old Sep 8, 2010 | 06:07 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Awesome man, hope it lasts forever!
Old Sep 8, 2010 | 08:23 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
can't wait for new track results! this thing is gonna be quick
Old Sep 8, 2010 | 10:37 PM
wrenchbender's Avatar
Yep, that low gear is gonna be a wonderful thang!
Old Sep 8, 2010 | 11:04 PM
mw66nova's Avatar
Engine: 7.0L
in! everything is hooked up, everything has been fabbed, except for the yoke swap on the driveshaft and redoing the exhaust before the x-pipe. i should be driving it tomorrow.
Old Sep 9, 2010 | 08:50 AM
Shagwell's Avatar
Yes sir!
The internals in that trans are exactly what I was running low 5's on, except he has new/better clutches, lol. That's actually the case, pan, and vb I was running last, just changed the shafts and drums to some that hadn't had as much abuse.
Old Sep 9, 2010 | 09:49 AM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
we want track numbers! lol. can't wait to see that car dip into the 10's
Old Sep 9, 2010 | 12:15 PM
zz17iroc's Avatar
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
Matt are you going to the track this friday? If so, I'll go just to cheer you on. The Iroc got side swiped about 6 weeks ago sending me into the guard rail. So I won't be in my Iroc, but instead I'll be in my Red 92 Z28 I picked up and guess what it's all stock with AC.
Old Sep 9, 2010 | 01:53 PM
mw66nova's Avatar
Engine: 7.0L
no, someone hit you!?! are you ok?
no track times this week, i got to work :*( i'll see about maybe next week.
Old Sep 9, 2010 | 06:12 PM
mw66nova's Avatar
Engine: 7.0L
back together! drove it, flashes to about 4500ish. i haven't gotten all the way in it yet from a stop. i'd imagine it'd just blow the tires off. can't wait to get it to the track. couple more pics, first one is of the new crossmember i built and the header collectors that i added some flanges to. the other is of the super cooler keeping it cool.
10 min street cruise with a wot pull to the top of first, and going heavy on the pedal yielded about 150* trans temps.
Old Sep 9, 2010 | 08:52 PM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Put the converter against the trans brake when you get a chance. I'd like to get a number in stone for my records. Should go 4800 at 500HP.
How does it feel? Responsive? Should work well with that 3 speed.
Old Sep 9, 2010 | 09:16 PM
zz17iroc's Avatar
The only thing that's hurt is my heart. All that time I put into it and look what happens, I get twin turbos and a very clean untouched 92 Z28 that is now my DD out of the deal. All I can say is thank you LORD!
Old Sep 9, 2010 | 10:37 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
congrats buddy, hope it rips. I'm still putting mine together slooooowly, at least all the side jobs of building other peoples race cars is over with now.
Old Sep 10, 2010 | 08:30 AM
Shagwell's Avatar
Sweet! - glad to hear it's driving again.
Old Sep 10, 2010 | 04:02 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Wheelie Time!!
Old Sep 11, 2010 | 03:45 PM
mw66nova's Avatar
Engine: 7.0L
took the limiter off and going all the way against the converter, it flashes to 4500, so it's a little tighter than i thought, but man it drives GREAT. i can't wait to get it to the track.
Old Sep 11, 2010 | 05:09 PM
xpndbl3's Avatar
Car: 1984 Z28
That's not bad at all, mine doesn't flash that high on motor either, 4500 would be a good match with your cam combo.
Old Sep 11, 2010 | 09:20 PM
mw66nova's Avatar
Engine: 7.0L
it's mighty torquey in the mid-range...i like it
Old Sep 13, 2010 | 08:34 AM
Shagwell's Avatar
SWEET!
Old Sep 14, 2010 | 11:58 AM
mw66nova's Avatar
Engine: 7.0L
did a 40 mile cruise to school and back today. here's my two reports, first is on the way there, second is on the way back:
ok, drove the pig to macon...it's oober loud...dare i say maybe a muffler change again? ugh...either way, ambient temps were in the mid 60's, averaged 180* water temp, 145* trans temp, 60psi cruising oil pressure. i averaged 3000 rpm, which after a quick calc, is ~55mph (taking converter slippage into account). it also didn't seem to consume too much fuel. was above the F hash mark when i left wartown, still above the hash when i got to macon.
no one wanted to play though?
ok, drove it home, ambient temps 85*. the trans temps never went over 155*, and the water temps 185*. about 15miles of interstate and 5 miles (give or take) of back roads at 3000rpm. i'm very happy so far. i'm not sure i could ask for much more, other than maybe some quieter exhaust. i'm thinking of building some tail pipes or something to get it away from the passenger compartment...
Old Sep 14, 2010 | 12:09 PM
built91Z28's Avatar
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Good to hear.
Whats your exhaust setup now?
Old Sep 14, 2010 | 12:26 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
getting the exhaust to the rear of the car definitely helps, any time it exits under the car you'll get some drone etc. but you already know that
Old Sep 14, 2010 | 12:40 PM
mw66nova's Avatar
Engine: 7.0L
hawks lsx swap headers, dual 3" x-pipe, and dynomax bullets.
Old Sep 14, 2010 | 07:52 PM
xpndbl3's Avatar
Car: 1984 Z28
well bullets are loud huh......who would have thought
race mufflers are loud.....say it isn't so matt
Step up to fullsize mufflers like the rest of us fast guys and don't annoy the people in the lanes next to you. Besides you'll feel better beating those "loud" race cars with your quieter street car
Old Sep 14, 2010 | 08:15 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
Do you have any pics of your completed exhaust system? I am in the process of a longtube header installation witha turbo 400 trans. I'd like to see how you routed the tubes for the x-pipe and the duals.
Old Sep 14, 2010 | 09:37 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Man, i love the sound of my dual 1 chambers but the T56 keeps things down till i want to get the revs up but i am sure it is just where it might be annoying after a bit.
Old Sep 14, 2010 | 10:46 PM
mw66nova's Avatar
Engine: 7.0L
this is basically it. it's changed a little since this picture, but not enough worth mentioning. what mufflers are you running steve? i was thinking of going to a dynomax ultraflow...but then again, tailpipes would do everything i need to as well..just don't know if i feel like trying to package them or not...
Old Sep 14, 2010 | 10:49 PM
mw66nova's Avatar
Engine: 7.0L
ok, just wanted to say, that after driving my mom's 14 second firebird....this thing really rips! i can't wait till friday!
Old Sep 14, 2010 | 10:59 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
You and us her as well, we want to know how the ol girl is gonna get down.
Old Sep 14, 2010 | 11:15 PM
car_fixer's Avatar
thats awesome....a battery to hold up exhaust for welding? and is that a dosentlast........dont you work at...and arent...hmmm turncoat
cant wait to see it though man looks good, and it appears you didnt blow yourself up being a lil foolish there, ever see a battery blow up? you dont want to brother.
Old Sep 14, 2010 | 11:32 PM
mw66nova's Avatar
Engine: 7.0L
lol, that was actually a bad battery out of another car, not one i bought. it was holding the exhaust in place while i fought with the slip-fit collectors (now running bolt-on style collectors ) it's a side post 78 series battery. can't say it was super smart looking back, but i assure you the welder was no where near that battery
Old Sep 15, 2010 | 12:04 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Get rid of them Bullets and get a couple of these http://www.aeroexhaust.com/index.php...e-exhaust.html
(or the 2525's if doing dual 2.5").
Don't get hung up over the truck/SUV part.
Glad to see you're getting it together.
Old Sep 15, 2010 | 03:52 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
That is one fat *** little muffler.
Old Sep 15, 2010 | 06:44 AM
mw66nova's Avatar
Engine: 7.0L
yeah, not sure how i'd package those...they'd scrape everything if i were to put them in my current muffler location.
and they're pricey. i'd go with a borla xr1 at that price. i was thinking more like a dynomax ultraflow.
Old Sep 15, 2010 | 10:38 AM
Shagwell's Avatar
Dynomax ultraflows, Hooker max-flows, are both the same design; Pypes has a straight-through performated screen type muffler as well(not sure what they call theirs). Any of those would definitely be quieter than bullets, as would adding tail pipes.
Didn't you inx-nay the rear seat? If so, cut the humps out of the floor and cover it with some flat tin. Gives you a good spot to tuck full size mufflers underneath w/o loosing any ground clearance.
Old Sep 15, 2010 | 11:28 AM
mw66nova's Avatar
Engine: 7.0L
i've been thinking of doing that very thing JP, i'll make that happen this winter i think.
Old Sep 15, 2010 | 11:37 AM
zz17iroc's Avatar
I'll see you there Matt.
Old Sep 15, 2010 | 01:16 PM
mw66nova's Avatar
Engine: 7.0L
Awesome! You bringing the new car for some baseline numbers?
Old Sep 15, 2010 | 01:43 PM
  #42
Shagwell's Avatar
There's a really old thread on here somewhere that has pics of my old duals under my GTA. - They tuck up nicely in that location.
Old Sep 16, 2010 | 09:35 AM
  #43
zz17iroc's Avatar
Well, I might take it down just run high 14's to low 15's.
Old Sep 16, 2010 | 11:18 AM
  #44
xpndbl3's Avatar
Car: 1984 Z28
just some dynomax ultra flows here, I already cut out the back seat area and welded in two boxes that I made into the floorboard, looking back a flat sheet of steel would have been even easier and about the same height, but making the box took 2 days on a lift.
Old Sep 16, 2010 | 04:20 PM
  #45
mw66nova's Avatar
Engine: 7.0L
couple pics of my new good. had to do something different, lol. let me know what you think
Old Sep 16, 2010 | 04:25 PM
  #46
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Would be cool if it was body worked into the hood. No too bad. I assume you'll be getting a real hood in the future?
Old Sep 16, 2010 | 04:27 PM
  #47
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
THink if it was a 1-1 1/2 inch shorter it would look really good.
Old Sep 16, 2010 | 04:40 PM
  #48
mw66nova's Avatar
Engine: 7.0L
i will be getting a real hood in the future, but not anytime soon. this is a semi-permanant solution. the pictures honestly don't do it any justice either...it's pretty cool looking in person.
Old Sep 16, 2010 | 07:33 PM
  #49
xpndbl3's Avatar
Car: 1984 Z28
you don't want my opinion
maybe painting it white would "slightly" change my opinon.
Old Sep 16, 2010 | 07:40 PM
  #50
mw66nova's Avatar
Engine: 7.0L
man i'm really having to zip my flame suit up for this one...
