Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Gains from a 150 shot...
Old Oct 26, 2010 | 12:59 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Right now, i am at 7.6 at 95 MPH, so i am trying to see what my MPH gain will be with a 150 **** plate kit i have.
Basically, i had a buddy goof off that i want to run in his procharged vette, show a slow **** time slip of 14 seconds and 13 seconds in the 1/4, well, i am not dumb, i want to know how i stack up as it is since i want to strip him of his dignity with my old **** POS third gen(guy is a vette or nothing lover), his slip revealed all i needed to know.
He went 7.57 at 105 MPH, so on gas in the 1/8 i would no doubt have him covered, but in the long stretch in the 1/4, i am sure he would nto be able to run me down, but what MPH gain might i get from a addtional 150 shot in the 1/8th? I think 10 more MPH is not asking too much from that mught gas, but i have never sprayed a car that ran 95 all motor so i dont know what kind of MPH gain to expect, i have sprayed 305s and mild stock 350s and it was good, but the faster you are going, you pretty much start gaining less.
So, is 10 more MPH possible? Or better? Worse? I am sure some of you would know pretty well how much one might get from a single plane with a decent cam on a 110 LSA.
Old Oct 26, 2010 | 07:18 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Gains from a 150 shot...
I doubt you'll pick up 10 MPH in the 1/8.
HP required goes up exponentially the faster you go. A 150 shot in a 15 second vehicle is a huge increase. A 150 shot in a 13 second vehicle is a mild increase. If I had NOS on my car and gave it a 150 shot, it would only be a small increase.
Old Oct 26, 2010 | 09:05 AM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
I went from a high 12 to a mid eleven on a 150 shot back in the day.
Got a buddy right now that goes 11.5 at 118 on motor and 10.58 @ 128 on 150 shot.
7.6 is a high eleven so I would say you could go very high 10's (high 6's) on a 150 shot.
Old Oct 26, 2010 | 09:16 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I ran 11.4 at 118-119 1/4, which is 7.3's at 93mph in the 1/8 with my old 383.
150 rated hit went 10.63 at 126.7 withthe bottle running low. Has trapped 128.x with full bottle. That was a 6.76 at 101.6 mph 1/8 mile but has hit almost 103mph in the 1/8
So i gained almost 10mph in the 1/8 alone, but its common to see 8mph.
Old Oct 26, 2010 | 09:40 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Well, that should be enough to capitolize on the vette. As i have whooped his **** on motor and Orr90, that is what i wanted to hear, i would go 200 if i had to but it is just a sniper kitt hat goes to 150 i scored for 100$ a while back, used it with the 100 pills on the stock L98 and it rolled out ok, but this thing has allot better everything and i know it can take advantage of the gas.
Orr89RocZ, how much bottle pressure were you running?
Old Oct 26, 2010 | 09:41 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Yea, that is what i was saying. The faster you go, the more it takes just to go a little faster.
Old Oct 26, 2010 | 09:53 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
7.6@92 BEST on motor
7.0@100 BEST on N20
This car was very limited on the top end due to the intake, so I think you will hit 103 or so on a 150
Old Oct 26, 2010 | 10:06 AM
87draggta's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: Th-400
Axle/Gears: 4.56 Richmond Gears
I've been 7.44 on motor and 6.7XX on 125 shot. However, the night I ran 6.76 I was running 7.5X on motor.
Old Oct 26, 2010 | 10:18 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Get the car to hook and you won't need the extra 150 shot. You'll be so far in front of him on the hit he'll never catch you. This is how I schooled guys running 126 in the quarter when I was only going 112.
Old Oct 26, 2010 | 10:22 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
The run will likely take place on the street.
I should hook better than him on the street and track, he hit a 2.0 on the track.
Old Oct 26, 2010 | 10:23 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
7.0@100 BEST on N20
Well, looks like 8-10 MPH is the average gain.
Old Oct 26, 2010 | 01:56 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Some cars respond better to nitrous than others.
i ran between 900-950 psi. I think the kit was rated for those pressures. I ended up running 75 shot fuel jets and 150 shot nitrous jets to lean it out near 12.0 to 1.
87TA's car picks up a ton on spray. He was 11.0-11.1's at 124-ish with the motor with 6 spd. On a 150 I think he went 10.08 at 138 mph end of the year in good maryland air. SICK
Old Oct 26, 2010 | 02:02 PM
mw66nova's Avatar
Engine: 7.0L
well don't go from a roll. i think even with a 150 shoot you'll loose. go from a dig on a prepped surface and he'll never get anywhere near you.
Old Oct 26, 2010 | 04:25 PM
DIGGLER's Avatar
a 150 shot on slicks would take my car from 7.20-.30's@96ish to 6.20-.30's.@108-110ish.
Old Oct 26, 2010 | 05:32 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
That is the plan, whoop him from a stop and never let him think of catch up.
Old Oct 29, 2010 | 11:04 PM
DIGGLER's Avatar
TTT
just went a 6.26 with a 1.312 60' on the 275 radials......
WITH A 100 SHOT! lmao!
the new plate seems to work pretty well. i didnt run it on motor, but i bet its picking up a full second with that little shot. it also stumbled twice down track due to a progressive fart which i havent figured out yet.
Old Oct 29, 2010 | 11:22 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Mine bogged on motor tonight since i dumped it more than slip it the first pass, but i got a 7.5 all motor with the 1.7 60.
Old Nov 24, 2010 | 05:56 PM
j69camz28's Avatar
On a125 hp shot, I went from 11.89 @ 112mph to 10.90 at 121mph.....
Old Nov 24, 2010 | 06:03 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
EFI or carbed?
Old Nov 24, 2010 | 06:07 PM
DIGGLER's Avatar
Originally Posted by ZONES89RS
EFI or carbed?
shouldnt matter.....
Old Nov 24, 2010 | 06:09 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
A single plain intake for a carb usually yields extra gains in some cases, EFI can some times not his as hard and what not, every car is different so it really doesnt matter.
Old Nov 24, 2010 | 06:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The '57 went from 13.3's @ 100 to 12.0's @ 110 up here on a 100 shot at the hit. Don't recall the change in 1/8 mile, but it was significant, as was the 60'.
Done for Pinks All Out '08.
Old Nov 24, 2010 | 06:33 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
1.3 secs from a 100 is good, but at a 100 MPH trap speed, i would not be so lucky already hitting 95 in the 1/8th.
Old Nov 24, 2010 | 09:13 PM
five7kid's Avatar
Yeah, my stuff's pretty lame.
(But that was in a 3900 lb car...)
Old Nov 25, 2010 | 12:05 AM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
not to mention at altitude lol.
my car picks up around .7 to the eighth on a 100 shot, from 9.2x-8.5x. they mph stays the same because the 700r4 wouldn't shift so there's more in it for sure
Old Nov 25, 2010 | 12:20 AM
3rdBird's Avatar
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
Mine natural runs 11.2, but with a 100 shot at the throttle body has run a best of 10.1 @ 138.
The new Direct Port w/ a 2 stage kit should produce lower ETs.
The goal is 100 shot on take off, 2nd gear 200 shot comes on & the 1st 100 turns off. 3rd gear the first 100 comes back on.
Old Nov 25, 2010 | 01:12 AM
five7kid's Avatar
Whoa, I hope SRP can hold that!
(Or are they just calling it "Sacramento Raceway" now?)
Old Nov 25, 2010 | 07:06 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
That is allot of work, LOL.
Old Nov 25, 2010 | 09:08 AM
mw66nova's Avatar
Engine: 7.0L
with a nitrous controller it won't be any work. he's not flipping switches on the way down the track i'm sure...
Old Nov 25, 2010 | 10:43 AM
DIGGLER's Avatar
mine is a single plane intake and its also injected. i hit mine with a 150 off the tbrake a couple weeks back and here's what it did.
http://www.streetfire.net/video/oops_2086216.htm
the audio is not right- i pedaled it and then hit it again as it was coming back down, but it sounds like i didnt hit it until i had landed.
1.42 with the rears, and the fronts came back down 80-100ft out. lol
Old Nov 25, 2010 | 11:25 AM
3rdBird's Avatar
Yea, its still called Sacramento Raceway.
On Grudge night theres cars running high 7's & low 8's. Theres usually 6.50 pro mods & dragsters at bigger events.
I'm running the Accel Gen 7, it can control 4 stages of nitrous. I've had alot of help from Theo @ Wizard Racing, He's the tuner for Chris Alston Jr.
Old Nov 25, 2010 | 01:32 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Yea, installing and tuning all off that, that is allot of work to me. Flipping switches for that would be insanely inconsistent as well.
Old Nov 29, 2010 | 11:35 AM
Shagwell's Avatar
Car: projects.......
The earlier you can bring it on, the bigger the gain will be. With the spray combo I come out of the gate with over 500hp and no progressive...lol. Being as though it was set-up for spray, the combo is a total dog w/o it.
If you can't leave with your right foot on the floor, then you can gain more there than turning on a small kit 60+ feet out.
As Orr89RocZ eluded to, the tune-up will make a huge difference as well. NOS has completely revamped their reccomended tune-ups for most of their systems in the past year or so. As it was it was comon for the carb kits to start off reversed of what they reccomended.
Side note: Always run your bottle pressure around 900 psi and tune accordingly. Any more will have too drastic of pressure change through the run, thus resulting in an overly rich tune on the big end.
Old Nov 29, 2010 | 10:51 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
i run 7.2x @ 98 and 11.2 @120 on motor. on a 150 shot 6.5x @ 106 and 10.2 @ 135 with a NX plate
Old Nov 29, 2010 | 11:46 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
15mph with a 150 shot, must be quite the nitrous combo....good job!
Old Nov 30, 2010 | 12:47 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Only gaining 8 mph in the 1/8th makes me think he is not getting on the juice off the line. But 15 total on the back? Bad ****.
Old Dec 4, 2010 | 11:46 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Axle/Gears: 4.11
spray comes on when i release the trans brake.(not progressive) i have been running the same JW converter for 7 years . back then i had a 355 with a pro race fogger. now it a 408 with a plate, it always has left soft and pull hard on top. my best 60 foot is a 1.48 on a 10.12 135 run.
Old Dec 5, 2010 | 12:54 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
i'd get a modern converter for it and i'd bet you'd be into the 9's easily
Old Dec 5, 2010 | 01:00 PM
DIGGLER's Avatar
i was running a ~$350 JW converter in my car up until this past year when i bent the fins backwards in it. 60's fell off from 1.35ish to 1.45-1.50ish. also lost a couple mph.
Old Dec 6, 2010 | 02:55 PM
Shagwell's Avatar
JW makes a good product, but nothing yet that's really designed for the outlaw type stuff. A buddy of mine made 6+ fins completely "dissappear" twice in his JW before he changed brands.
We sent a high dollar Coan in to them to be checked out a few years back; kept getting trash in the tb circuit, the car was staying steady in the 4.7x range even with more blower thrown at it, and it had burnt the paint off itself a couple times. - Got a call back from a tech and the first words out of his mouth were "this thing MOVED????" -
antman89iroc
36
Jan 31, 2016 08:42 AM
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
