pullin the wheels
Car: 89 camaro
Engine: 383
Transmission: 350 tci 3000 stall
pullin the wheels
I was wondering about what does it take HP wise or 60 foot wise to pull the tires or tire! I know there are many varibles far as weight and the setup but want a basic idea for a street car with maybe ac removed, aluminum heads, fiberglass hood using a foot brake!
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: pullin the wheels
mine still doesn't pull the tires, some do, some don't
Car: 1986 Iroc-z Camaro t-top
Engine: 355 SBC
Transmission: 700r4 TCI const. Pres. Valve body
Axle/Gears: 3.73 posi/mosuer axles
Something that helps is 90/10 front struts, but very unlikely to pull a tire in the 12s off foot brake without draglite skinnies in the front.
Engine: 355 SBC
Would love to race you. We almost have same set up
Car: 89 camaro
Engine: 383
The motor in my sig is getting a little tired so I have another bullet on the engine stand im gathering up parts for! But I love a good race!
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Lots of torque and deep gears make it easier. I've seen 12 second cars easily pull the wheels and 8 seconds cars that don't. I can change my suspension settings to keep the front end down during competition but during test and tune days, I loosen up the front to carry the front end about 40' down the track. The crowd loves it. I also launch at 6000 rpm off a transbrake.
To "just get them off the ground" typically you need to be in the 12's although if the car isn't nose heavy like our third gens, 13 seconds may be possible.
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I'd say typically once you get into the 1.5X 60fts the wheels (or more likely WHEEL) starts coming up. At least that's when my junk started doing it.
Car: 89 camaro
Engine: 383
Around a 1.5X 60 foot time is what I was thinkin too! I know people say its a waste of energy but It sure is sweet!
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
Mine would barely pull the left front at 1.60 60' times, and thats with 275/60/15 BFG Drag Radials. the car was running in the low 12 - high 11 range. Now with my Procharger motor, it better pull them both!!
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
I barely pulled them running 9's. Look below what 8's got me.
Car: 1984 Z28
Car: 89GTA, 62' GSXR1000-SS
Engine: 406-HSR
Transmission: Nocturnal
high rpm launch might 'pop' a wheelie just from shock to the suspension or maybe be able to do it if your suspension is setup that way.. but to do it with good suspension would take alot of hp/tq 550-600 ish maybe? and a fairly lightened up car..
I had an awd laser that ran 13.00s with horrible broken front end that would lift them maybe an inch with 2-step and anti-lag lol
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Going to be launching pretty hard tomorrow, if nothing breaks, i will have vids, i am sure a wheel might hop off the ground, but not actually pull them.
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Off the footbrake, I go 1.62 to the 60' beams, it will barely pull the left front, don't have any pics or vids of it yet. I was informed by a coule of people watching my make passes and they were asking if something was wrong with the brakes, cause the front tire wasn't turning when I first left the line. Thats how I found out it was happening, and that some people need to be taught about racing.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i got a set of 90/10's in the mail, i'll be sure to post my findings from this coming saturday.
for reference, this is with stock struts and about a 1.52 sixty:
i'm REALLY hoping the 90/10's do something for me...they might go backwards, but i don't think so.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Took advise and removed the front sway bar tonight, and i removed the front impact bar as well, dont think i have much left to remove now
Car: '82 Z28
I barely got both fronts off the ground footbraking to a 1.42 60'. That's with stock springs and probably stock struts and rear shocks lol. I've never changed them and when I bought the car, the stock exhaust system was still in place.
Matt, the 90/10's will be fine for your power, it's about another second faster that they start becoming more a hinderance than help.
Personally, with a street car I keep the front sway bar on, but use well greased poly bar mounts and custom spherical end links. - That allows the sway bar to do it's job in corners, but also allows for little-no drag during launch when both wheels drop together.
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
1.52. Off footbrake with 3200 stall. Bone stock chassis.
It's ugly but I think you can slide a mosquito's wing under there.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Car: 1987 Camaro
Engine: 406
Axle/Gears: Moser 31 spline / 4.86
Car: 1984 Z28
he said more consistent from pass to pass but no 60' or ET improvement
Engine: 7.0L
yup, more consistent and much more stable right out of the hole, but no numerical improvements. yeah, that's my dad's website...it's cool that you look at it!
i'm still thinking a 4.30 gear would be about perfect.
it is lifting the front wheels higher now though:
Car: 1987 Camaro
Engine: 406
Engine: 355 SBC
The launch looks more consistent with the old struts..do you have adjustable rears?
Engine: 7.0L
what you don't see is how the car acts on the landing, it's much more stable and the sixties are much more consistent. it's keeping the nose lifted now, where as before it was coming down and squatting the front badly. it does have a set of comp. engineering rear shocks set on a 50/50 setting right now. i know there is much to be had in a good set of adjustables, but can't afford a set so what i got is what i got.
Car: 1987 Camaro
Engine: 406
Engine: 7.0L
i thought about it trying to run the 7.50 class or something...i'm right in the middle, lol. the car runs 7.0x's, and 6.9x's. but i have a linear algebra test two days before, and a physics test two days after...no way i can not focus on school right now.
Engine: 7.0L
i'm sure you would
oh, got something in the mail today that should help a bit
thanks steve!
thanks steve!
Car: 1984 Z28
no problem, hope it works out well for you.
drptop70ss
Oct 4, 2015 09:44 PM
punkmaster98
Sep 8, 2015 09:45 PM
