ready for autocross but what class?
Car: 91 rs
Engine: 350 tbi with EBL
Transmission: t56!
Axle/Gears: 2.733
so like stated in the title im ready to run autocross but have no clue what class im in. i looked at the scca rule book and its a little over my head right now with so many classes maybe a web link would help? my car is a 91 350 tbi rs so im not going to be in a stock class but i hope it doesn't push my car to a class i cant compete in. any help would be appreciated.
ps any1 go to Nassau Coliseum for Autox?
pss most of the cars that compete are BMW's at Nassau Coliseum
Re: ready for autocross but what class?
NYR SCCA starts their season at Nassau Coliseum Sunday 4/17. car to describe what is not original or oem to a non-american iron guy so I can u class the car.
Car: 88 Trans Am
Engine: 305 tpi
any suspension mods? and is the engine an L98? (guessing it is)
if it is an internally un-modded L98, my guess would be it's in E Street Prepared (ESP).
Car: 91 rs
Transmission: t56!
Axle/Gears: 2.733
its internally un-modded l98 that came from a tpi. no suspension mods except poly bushings. thank you for your reply
is the L98 stock to that year? the bushings would bump you to E Street Prepared or Street Touring Ultra. As a 1st timer, no one will hassle u the bushings are the only alteration on a 20 year old car in stock unless u show an immense amount of skill. at subsequent events, u should be where ur supposed to be and if u like autoX w/ scca, there plenty more u can chnage and remain in either ESP or STU.
hope to C U Sunday. If u wish to pre-reg, www.msreg.us/nyr2011-1. if u wish to save a bunch of time in the morning, pay online as well.
Car: 1982 Z28
Engine: LC9
Transmission: AR5
The bushings put you in ESP as well as the TBI since it's matched with an L98 350. It was originally an L98 TPI car, it could run in STU. Probably nobody would care anyway, but I've usually been a stickler for the rules (my very first autocross, in my old '92 Sentra SE-R, I ran in CSP because I had a header ).
Pat
Pat
Car: 88 Trans Am
Engine: 305 tpi
The 350 with tbi is what put you in ESP since it allows update/backdate and intakes are pretty much open.
If it was just bushings, you'd be in STX (assuming it was originally a 5.0)
Car: 88 Trans Am
Engine: 305 tpi
Then again, probably no one would care if you go in STU if it's a local event.
Car: 91 rs
Transmission: t56!
Axle/Gears: 2.733
thank you all! i will look at the link to preregister thank you. when i get more cash and exp this will be first place for advice
Car: 91 rs
Transmission: t56!
Axle/Gears: 2.733
just finished going to my first event! Started my first run with a 52.4 and ended with a 46.1 to 46.4 for the last three runs. I feel that i could have gone faster with a new set of tires since the ones on the car are 3yrs old. I pushed my car pretty hard more than i thought capable of doing but i knew i lost time every time i ended up drifting a corner or the rear sliding when accelerating out. I was hoping to see another Camaro that had also preregistered to see if he could give me some pointers but never showed.
Ken w/ Camaro bailed. He'll be hit or miss till August then. I'm pretty sure all the storms late Saturday night gave people the idea to sleep in. All teh fun happens when you make sure to wake up early. At least for autoX.
