engine cuts out
Subscribe
Aug 3, 2011 | 09:20 PM
maybe someone can lead me in the right direction here. my car cuts out right before the traps right around the 6500 rpm range. the motor is a 385ci. 13 to 1 compression, dart heads, a single plane intake. also it has a msd 7al, pro billet distributor, ive changed timing and it doesnt matter. it has a holley 750 with a race main body. just ordered a quick fuel 850. the darn thing acts like it runs out of fuel, or hits a rev limiter. i took the chip out of the box and it still did it. anybody run into this or have a similar issue.
Reply 0
Aug 4, 2011 | 02:08 PM
Re: engine cuts out
I'd say out of fuel. new carb will tell
Reply 0
Re: engine cuts out
did you try bigger jets?
Reply 0
Aug 4, 2011 | 02:12 PM
Re: engine cuts out
i tried bigger jets, with no success
Reply 0
Aug 4, 2011 | 02:48 PM
Re: engine cuts out
I did think a 750 my be a little small. what times and mph you running
Reply 0
Aug 4, 2011 | 03:17 PM
Re: engine cuts out
high 10's low 11's anywhere from 121 to 125
Reply 0
Aug 4, 2011 | 03:33 PM
Re: engine cuts out
nice times all my friends that run in ten's have at least an 850 or bigger with less cubes than you
Reply 0
Aug 4, 2011 | 03:37 PM
Re: engine cuts out
i just finished putting the 850 on it. now all ill have to do is hopefully dial it in
Reply 0
Aug 4, 2011 | 03:45 PM
Re: engine cuts out
post how much that helps
Reply 0
Aug 4, 2011 | 03:55 PM
Re: engine cuts out
if the weather holds ill be out there tomorrow. i'll let you know
Reply 0
Aug 5, 2011 | 03:13 PM
Re: engine cuts out
has it always done it, or just progressively getting worse? If progressively getting worse, I would look at valve springs. If it has always done it I would start looking at carb, and also what are you running for a scoop? Is it possible you are running into air turbulence issues, where it is trying to pull fuel out of the carb?
Reply 0
Aug 5, 2011 | 03:23 PM
Re: engine cuts out
thanks for the advice. i thought about adding a scoop. it only started doing it after i changed to a 4.11 gear. it didnt do it before that because i wasn't winding it out going through the traps. i put a new quick fuel 850 on it yesterday, so ill see if anything changes tonight.
Reply 0
Aug 5, 2011 | 08:57 PM
Re: engine cuts out
what does the rest of the fuel system look like? running a sumped tank and a good quality pump, or what?
Reply 0
Aug 7, 2011 | 07:50 PM
Re: engine cuts out
sumped tank. magnafuel 300 pump -8 line to regulator and -8 line to carb.
Reply 0
Aug 7, 2011 | 07:51 PM
Re: engine cuts out
put a quick fuel 850 on it. right out of the box it ran great, no problems whatsoever. ran strong 10.90's all night and i havent even touched it yet. thanks for all the help.
Reply 0
Aug 7, 2011 | 08:51 PM
Re: engine cuts out
nice
Reply 0
Aug 7, 2011 | 09:31 PM
Re: engine cuts out
Quote: sumped tank. magnafuel 300 pump -8 line to regulator and -8 line to carb.
how is the tank vented?
Reply 0
Subscribe
