Thirdgen Representin' at the LSX shootout! 9.0 True Street Title!
Former Sponsor
Car: 91 Firebird
Engine: LSX
Transmission: T400
Axle/Gears: 3.50
Took mine down to Indy at the LSX shootout. Since I built the car as a fast street car, True Street is the ultimate category. 21 mile cruise, 3 back to back passes.
Anyhow, ended up winning the 9.0 second True Street Title!! Some discussion over at LS1tech.... I don't think they saw my Thirdgen coming...
http://ls1tech.com/forums/gm-perform...t-results.html
Thought you all might appreciate,
J. May
J. May
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Thirdgen Representin' at the LSX shootout! 9.0 True Street Title!
What happened on that second pass? That could have killed your chance.
You got a typo in your sig
Former Sponsor
Car: 91 Firebird
Engine: LSX
Transmission: T400
Axle/Gears: 3.50
Unfortunately, I spun the second pass a bit...
With 100 cars running 3 back to back passes, the track goes away I've found.
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Congrats!!
John Force will be looking for you!! Lol!!
Good job!!!
Good job!!!
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Good Job! I was there for the event too.
Car: 1991 B4C Camaro RS
Engine: 370 lsx ls3 heads victor jr w/carb
Transmission: TH400 w/brake coan 8"4500-4800 stal
Axle/Gears: Moser 9" locker w/ 4.11's
I was there in true street with the black rs blew it up on second pass. Lol
Former Sponsor
Car: 91 Firebird
Engine: LSX
Transmission: T400
Axle/Gears: 3.50
JBenge,
Did you run true street? Sorry i didn't get to meet up. I thought it was a little too busy there....
I was planning on running true street but didn't, I only ran the LSX rumble class. The fuel pump wasn't supplying enough fuel volume so it was going very lean on the top end..didn't want to risk hurting the engine. Yesterday I talked to aeromotive and they said my pump should fill a gallon jug in 28 sec, mine took 72 sec. I'm surprised it was running as good as it was being starved for fuel like that. Hopefully we can meet up sometime. Very nice car!
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Not nearly as well as I'd hoped. I've only made a few passes this year and I'm still trying to work out the bugs
. I ran in the 10.5-10.7 range which is horrible for my combination. The AFR meter that I bought before this event did confirm it was going lean and by how much so I feel much better after figuring out my fuel pump is bad. My AFR would start at about 13.0-13.2 and be at 14.8-15.2 by the end of a run. I was slowing down about .15 in the evening in better air because it was so lean. I'm lucky I didn't burn a piston or valve. I've got a feeling its going to be a whole different car with enough fuel volume.Issue #2 is that it isn't hooking well, it hooked better with my old SBC and trick springs. The new combination with the Spohn coil overs isn't giving me the weight transfer that I used to have. I may need to try some lighter springs in the coil overs and/or get the torque converter adjusted.
Even though its an underperforming turd it did look good with the new Weld RTS rims though
Former Sponsor
Car: 91 Firebird
Engine: LSX
Transmission: T400
Axle/Gears: 3.50
I've had some mixed results with those coil overs..What struts up front?
Engine: 7.0L
sounds like we need pics of all the cars at the lsx shootout from tgo!
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I would like to run in that one year when i have a auto car together that is able and ready. Congrats!
I've yet to see a coil-over kit using light enough springs. Stangs and f-bodies alike, their "drag" springs are well suited for decent handling, their heavier springs just beat you up riding in the seat. - I only run 10" 175# springs with the blown BBC hanging out front. If I ran much strut travel I would have to run an even lighter 12" to keep it from un-loading.
I'll post all the 3rdgen pics I have from the event. This is a super clean Trans Am with a LS swap that was in the Car show.
Some thirdgens racing and the event pic of mine.
Engine: 7.0L
car looks great j!
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
Congrats! Checked your car out at Indy nice ride
CarGuyDennis
137
Dec 6, 2016 11:02 PM
3rdgenparts
Aug 6, 2015 09:03 AM
