so i see a lot of auto-x/drift thirdgens with carbs?
1 Post
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
arent carbs bad for throttle response??
just wondering
just wondering
Car: '82 Z-28
Engine: 355
Transmission: TH-400, 8" ATI MRT
Axle/Gears: Moser 9", 4.56's
Re: so i see a lot of auto-x/drift thirdgens with carbs?
Not at all. Although an extreme example (and not an autocross application), have you ever seen the throttle response of an NHRA Pro Stock?
EFI is very convenient, but carburetors are a great method of fuel delivery; the problem is that many people write them off because they don't want to/don't know how to tune them.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
my motor is extremely snappy, in fact I'd say it responds faster than any EFI that came stock on a thirdgen.
They've got to be tuned right, but when they're right you woudlnt know the difference between them and a fuel injected car just by driving it.
Race cars have been using carburetors for a LONG time before EFI was around and some still do use carbs.
1 Post
Engine: 5.7 350 TPI
hmm...interesting :P think my impala needs a carb rebuild
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
It could just as rightly be said that many people write off EFI because they don't want to/don't know how to tune them.
I agree with that statement 100%... Think that is more so than a carb.. I like and use em both.... May sometime throw a carb on my squarebore VR efi just to see the comparison.
Car: '82 Z-28
Engine: 355
I agree, there is no doubt that tuning EFI can be involved. I suppose I was basing my opinion on my own experience- I'm 26 and most of my friends around my age don't have the slightest idea as to how a carburetor works, but they can really work some magic with a laptop and the appropriate software for their application (evotune, K Pro, etc). When it comes to something with a carburetor on it, they are scared to death of it.
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
I started on carb cars, went to EFI cars, then went back to carb cars. Now I'm back to EFI and I'm doing an MS2 on the new build.
Either can be tuned to work well, and either can be screwed up by a moron who will then complain that it is a "bad" setup.
1 Post
Engine: 5.7 350 TPI
just to be clear..there still very responsive? (carbs) when tuned right if im understanding correctly? im not considering changing the GTA over, i was just curious
Biggest difference is my car has a wonderful fuel smell that emanates from the carb.
Car: 83 Camaro
Engine: 4 Bolt 350, Bowtie aluminum heads
Transmission: TH350
Axle/Gears: 3.42, superior axles, Torsen diff
Other reason for carbs is rules. In the class I run in autocross(CP) Aftermarket fuel injection wasen't legal until last year. Getting the HP required to be competitive through a restrictive stock TBI or TPI just wasen't going to happen. I suspect that since aftermarket FI is now legal in CP more cars will go to it but there really isen't anything wrong with a properly set up Holley Double pumper.
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Are you doing this to the car in your information at the left? 3800 series 2? Do you have a build thread or swap thread that you did?
Very interested because I am gathering parts for the Buick V6 swap right now. I am pretty sure I am gonna run port f.i. but you never know when someone else has already done it.
I'd especially like to know if you have run this car in auto-x, and how it did. I am also gathering up suspension parts and I am really curious what you are using.
