Tire type and size???
What is the best tire type and size to run on both the strip and street. I want to only have the single set of tires. I am probably only running a little over stock 235hp but cannot ever full throttle it in first gear. I have the stock 16" rims for a 1991 camaro Z28. Thanks
1991 Z28
30,300 Original Miles
305 TPI HO
1LE Performance Package 3" Performance piping and Cherry bomb turbo muffler
1991 Z28
305 TPI HO
Thanks what brands are best??? Should I go with bigger rims??? If so what is the best size rims??? Thanks
1991 Z28
305 TPI HO
1991 Z28
305 TPI HO
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I guess finding a happy medium between a street and track tire is a must for some people. When you mention a bigger rim, I hope you mean width. Tall rims make poor drag racing rims. A 15" rim with a tall sidewall is prefered for drag racing. That extra sidewall takes a lot of shock off the drivetrain.
Now if you're autocrossing or roadcoursing, then yes you want a tall rim. The smaller the sidewall, the less tire roll in the corners.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Best 60 foot: 1.662
Stephen is right.
You'll need to decide which is more important, straight line's or curves.
Eventually my goal is a high 12's car in the 1/4 mile.
I think it's possible with my combination while still getting great handling also.
It's up to your personal goals.
Wow! Thanks for the info. Anything will be better than the 60 series allseasons on it now but I didn't realize that the rim hight had that much input so I appreciate it!!
1991 Z28
305 TPI HO
1991 Z28
305 TPI HO
well if you want some kick a$$ tires get yokohama AVS intermediates in 245 50 16's. I have them and man you can really launch on them. i pull 60 foot times out here that are pretty much unheard of without slicks or drag radials. they are only 2.0's but with the altitude and the track not ever being preped for raceing it is pretty good. once i heat them up they stick like glue and allow me to hook my 2nd gear shift enough that it does not slow me down and it is a hard shift!!! but be ware if you drive like me they will only last a year.
90 iroc l98
last season best corected 13.62 @102
mods
full exhaust, AFPR, pulley, jet stage 1 chip, billet servo, 52mm throttle body and a few other little things.
90 iroc l98
mods
I would get some Yokohama's or Bridgestone's. I have some Bridgestone Potenza's on my IROC and I love them. Since I bought them my handling has been superb.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
colton_carlson
Mar 8, 2019 12:21 PM
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
