Stock LO3 pulled a 15.983 in 1/4
pretty good base I think to start off eh?
PMD Power
ICQ 70557275
AIM Curds301 or PMD Power
79 T/A 455 WS6
91 Firebird LO3
Ask me How to Make a Underpowered LO3 Shatter a Flywheel
PMD Power
ICQ 70557275
79 T/A 455 WS6
91 Firebird LO3
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yah, thats great! Automatic or manual? What tires? What altitude? Congrats!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
My very first run with my completely stock L03 89 RS was 15.82 and I advanced the timing a little and removed the air cleaner assembly and went 15.68 @ 88 before the day was over.I think the Firebirds are a little heavier, though, and mine is a hardtop car. With a some basic mods, not even spending a lot of money, I've been able to get mine to 14.91 @ 92.8 , but I've been told this is a little faster than average for one of these cars, so yeah, I think 15.90's stock is a good baseline.
82 Z28 350, Ported #882 Heads, Performer RPM cam and intake, hedman headers,650 Demon carb,
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET: 12.52@107.2
Future plans: Dart headed, Roller cammed 383 in early '01
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
New Best ET: 15.03@92.7
http://www.bassettracing.cz28.com
Good job.. thats a really good time for a stock L03
and Basset, as youve been told your car is a freak, its most likely an LB9 longblock with a TBI intake. And no, Firebirds are no heavier than Camaros.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
91 Trans Am WS6
Bright White
5.0 TPI auto
Trans Go shiftkit
Built on Wednesday
I am not sure of the altatude ther.. but I am in TX and it fairly flat... I think it might have had alot to with the temp outside.. it was about 36 outside... I got that time without even getting good grip and a busted tranny mount too.. BTW it is a A4 car peg-leg and all with 2.73's and if it makes a differance I had to run with my headlights up too..
PMD Power
ICQ 70557275
79 T/A 455 WS6
91 Firebird LO3
PMD Power
ICQ 70557275
79 T/A 455 WS6
91 Firebird LO3
MrJ my car is a freak!! You're right about these not being L03 heads (the #187 castings). But they're not #081's either. I just couldn't stand not knowing any longer, so popped of the driver's side valve cover this morning, and to my surprise, I read #10159553. I found this head in a block/head casting book I have, but it had no info on them,except that it was used on 87-95 305's, so it IS a 305 I guess. Does any body know what head this is? Could it possibly be a truck head? What was the factory HP rating on 305 TBI trucks?? Did the truck engine get the peanut cam?? This engine was replaced in by a Chevy dealer in 1998. I also found in the book, that in 97-98 they made a Vortec 305, they called it Vortec 5000, and these heads had a casting #12552520,and the book stated they had 1.84"/1.50" valves. I wonder if they would cost around the same as a Vortec 350 head?? hhmmmm - a Vortec headed 305 might be pretty quick, especially since since my bottom end only has 27K miles on it - it would worth it to me buy a set if they're cost was around the same as the Vortec 350 head, and if they flowed comparably. I'm going to research this some more, and let you all know more as I find it out.
New Best ET: 14.91 @ 92.9http://www.bassettracing.cz28.com
[This message has been edited by Basett Racing (edited January 07, 2001).]
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
dont buy 305 heads. 350s are much better
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 226/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter.
13.24@104
13.24@104
congrats on the time. it is a pretty good base line. it isn't as uncommon as most people think for an lo3 to run in the 15's right out of the box. mine ran 15.988@84.79mph when i first got it.
lata
tim
91 Camaro RS-LO3,Auto.
14.301 @ 94.39mph
The car is going street strip for next season. 13's here i come!!!!!
Edlebrock TES Headers, Cat Eliminator Pipe, Borla Adjustable Cat Back,Marche Pulleys, HyperTech Chip,Transgo Shift Kit,B&M Convertor(2000stall),Steve Spohn Rear Rig( all rod ends), Poly Front Bushings,Ported TB, 350 Injectors, Edlebrock Performer TBI Intake, Performer Heads, 1.6 Roller Tipped Rockers
http://www.mycar.net/mafb/registry/detail.cfm?id=299
lata
tim
14.301 @ 94.39mph
Congrats, that's a good time to start with, shouldn't take ya too much to shoot mid 14's and the sky's the limit from there!
Dan Young
1995 Z28/M6
Groton, CT
1985 Z28/A4
(Prospective purchase)
Dan Young
1995 Z28/M6
Groton, CT
1985 Z28/A4
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
On average Birds are slightly heavier than Camaro's.
More options come standard on the Bird than on the Camaro.
Headlight's on the Bird add a little.
Power antenna does too.
It's not a lot of difference on average maybe 15-35 pounds more for the Bird.
evilstuie
Jan 9, 2020 08:29 PM
