shutting down at the high end
Subscribe
Mar 1, 2001 | 01:03 PM
I havent been to the track yet this season because I live in the midwest, but the last time I went to the track my car stalled after the run. As soon as I let my foot off the gas the car sputtered a few times and then shut off. It started right back up in the turnoff and I drove it back, but Im curious if this indicates a fuel starvation problem or just something that is normal. I have a the stock TBI pump with a mallory regulator.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 224/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, 3000 stallconverter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
Best time yet to come
12's?? :crossthumbs:
This is a Pic of my car in race trim www.tbns.net/billyjay/camero.jpg
Reply 0
Mar 2, 2001 | 08:04 PM
check your tps, when they start to wear out they can have dead spots that will stall the car when you go past them too fast.
lata
tim
91 Camaro RS-LO3,Auto.
14.215@94.30 w/ 1.917 60'
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Reply 0
Mar 3, 2001 | 04:04 PM
My edelbrock carb is not eqipped with a TPS .
Reply 0
Mar 4, 2001 | 01:40 AM
laff
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Reply 0
Mar 6, 2001 | 03:21 PM
eventually you will need a real fuel pump. going from a high pressure low volume pump to a lower pressure high volume pump will help. if you are getting on the brakes from a high speed run, fuel will slosh forward away from the metering block (jets) and will artificially raise the float & cut fuel to the float bowl. (holleys are more suceptible to this but most carbs suffer from the same malady) raise the floats a little, but that's about all you can do short of an updated fuel system or adding a dashpot.
BBC powered 82 firebird.
Street driven (barely) Best ET no nitrous: 9.42 @142mph , Fogger installed, shooting for low 8s in 2001
Reply 0
Subscribe
