Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
info on Chrysler Conquest TSi
Old Mar 15, 2001 | 04:18 PM
86Sprtcpe's Avatar
Car: 1987 Camaro IROC-Z
Axle/Gears: BW 9 Bolt 3:27
Hey, a kid at my school just bought a 89 Chrysler Conquest TSi. He thinks hes hott s*** but i think his car looks like an overrated dodge daytona. anyway what i really want to know is the specs on this car. i know its powered by a mitsubishi motor and that its turboed but i dont know the hp rating or 0-60 time...do you think a 305TPI can smoke him? Thanks
Old Mar 15, 2001 | 07:22 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
I can't remember the specific numbers, and didn't turn up any specs in a quick search, but I want to say they had around 200-230hp, (230 comes to mind) and ran mid/high 15s in the 1/4. Probably be a good run for a 305 TPI auto, might win depending on year.
I ran one in my old mildly modded 86 IROC w/ the 305 TPI auto, and pulled him pretty easily. They're not bad looking cars...
There are a few modded Conquests and Starions (Mitsu sister car) around. Like any turbo car they can get fairly fast without too much work...
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
[This message has been edited by Ray87Z (edited March 15, 2001).]
Old Mar 15, 2001 | 11:45 PM
cy Z28's Avatar
Car: 1989 Formula 350 WS6
Transmission: 700-R4 2600 stall
Not saying that's what hes got... But www.buchurracing.com has a lot of tricks up hos sleeve. Including a 4G63 (eclipse GSX motor) conversion into a Conquest/Starion. That particular motor can be built to upwards of 600hp. So, there's definatly potential.
Should be a good run, if you win tell him to check that site and then come back if he ever wants to try again.
Cody "cyZ28" Young
'84 black on black Z28
355, 5-speed (on the way out. What goes back in, ooohh baby!!)
http://www.geocities.com/mustang_tbird/codypage.html
Old Mar 16, 2001 | 11:03 AM
92Z1LE's Avatar
A few years ago I was messing with one in my sister's 90 Plymouth Laser Turbo. I think the Lasers were 0-60 in 7.3-7.5, and we were pretty even at all speeds. We never went from a stop, but we got on it from around 20 and 50 up to around 100-105, and neither one of us gained any ground at all.
92 1LE 25th Anniversary Heritage Package
305 5-speed
Hooker Headers, SLP exhuast, K&N filters
Old Mar 16, 2001 | 11:09 AM
92Z1LE's Avatar
A couple of years ago I messed with one in my sister's 90 Plymouth Laser Turbo 5-speed. I think these Lasers were 0-60 in 7.3-7.5. We kicked it from a few different speeds (20,45,80) and went up to 105-110, and neither one of us gained any ground at all from any speed.
305 5-speed
Old Mar 16, 2001 | 11:21 AM
92Z1LE's Avatar
sorry about the double post. my computer at work is a piece of crap, and it shut down during my first post, so I figured it didn't post.
92 Z28 1LE 25th Anniversary Heritage Package
LB9 w/5-speed
Old Mar 16, 2001 | 03:32 PM
86SCBNJ's Avatar
The strongest motor in a Conquest was 177 hp. I checked it out, old issue of Car and Driver. If u got the auto, it was 145 hp. The 2.6 Mitsu motor has a decent bottom end, the headgasket likes to go on these cars. There are a lot of mods available, even today. I have a friend who owned one for a couple of years, traded it in for a 3000 gtvr4.
86 SC, 305 LG4, TH700R4, SLP headers, 3" cat and exhaust. Mild cam 204/214, .423/.442. SLP shift kit, richmond 3.73's w/limited slip. Susension Technique Sway Bars, Globel West Wonderbar, Poly everything bushings, Metco LCA's, Lakewood Panhad Rod. 16" ROH, with Toyo 245's. For autocross, 16" IROC's w/bfg R1's... Need more speed.....
Old Mar 16, 2001 | 07:13 PM
Ray87Z's Avatar
Car: 94 Z28
Axle/Gears: 3.23s
Yeah, I found some 1/4 times for them, 2 listed, both 86s. They ran a 16.0 and a 16.2. I saw a 188hp figure, don't know if it was right. A 305 TPI should take that if it's in decent tune and running right. I think I was thinking of older Supras before...
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
Old Mar 19, 2001 | 10:31 AM
vortech305's Avatar
I know this hindu kid whos like 6foot8inches and drives his conquest. Hes added alot of crap to that conquest(painjob,twin turbo,exhaust blah,blah)and i shut him up with the old school thang, thats righ the 71' Duster
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old Apr 7, 2001 | 02:36 AM
MikeDwhoROCZImports's Avatar
Chrystler Conquest TSI 1988
188hp@5000rpm
234lb-ft@2500rmp
15.8 @ 86.9
Old Apr 7, 2001 | 04:11 AM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
I knew a guy who had one of those back in 88. I had an 11 second, 383 LT1 powered,69 Camaro at the time.I used to race on Fountain Avenue.If there's anyone on this board from Brooklyn and was racing around in the mid 80s, should be familiar w/the place.I blew away every car that was there, and I raced for money so some of the faster cars didn't wanna race me.Anyway everyone I knew kept telling me "this guy is gonna smoke you".
I said "okey, bring it on".We raced for $100 and I took him out by a car length at most.I was surprized that the he kept up w/me at all. I later found out that he was running NO2 on a stock motor.Nitro was highly illegal and rare in those days. He must have been doing mid-high 12s.I was very surprized and even now how a lot of respect for those cars.
1990 Formula
Factory:TPI-305/Dual Cat(230hp),5 Speed,3.42 rear, Dealer:Aluminum Drive Shaft
Mods:SLP air foil,K&N Filter, Accel:wires,coil cap,rotor.Hypertech Thermomaster chip,Stat,Fan switch,TES headers,MSD6AL,AFPR(46), Harwood fiberglass hood,original GM "Notchback GTA" hatch.
Flowmaster 3" Cat-back exhaust,TB coolant bypass, Centerforce clutch (going).
Old Apr 7, 2001 | 07:20 PM
vortech305's Avatar
I know what your talking about in the 70's there was this guy who had a 68' plymouth Barricuda(HEMI) and had the fastest car in the area. Even beat the cops in their buicks(back then when they were cool and raced)i think he was in the high 11's w/ little mods. Ah the 70's wish i could turn back time
92' camaro
Soon to come!!!
Other car;
Old Apr 8, 2001 | 02:04 PM
86SCBNJ's Avatar
Fountain Avenue!!! I'm having flashbacks!!! One Sunday afternoon, yes Sunday afternoon!!! It was packed, there was a sandwich truck, an ice cream truck, some other guy selling beer, it was one big party!!! Till the cops showed up and turned on the hydrants.... Then we moved to the Conduit...... The good old days......
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
