How big and wide of a wheel can we put on our cars..
How big are your stock tires? Of there 245's you can put on 255's for sure, I don't know how much bigger you can go after that.
- Red '91 Z-28 350
- 700-R4 Trans
- T-tops
- no major power
gaining mods, K&N
Filter, Flowmaster
exhaust -series 80-,
exhaust cut-outs - Best E.T. 15.0@93mph, Will improve that 1/4 mile time this spring.
- HardlinePerformance
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I know Andris had 275/40R17 tires on 17X9.5" ZR1 wheels up front, and 315/35R17 tires on 17X11' ZR1 wheels in back. They just about line up with the edges of the fenders and look really cool.
Greg Westphal
'87 IROC 305TPI/A4
Greg Westphal
'87 IROC 305TPI/A4
geez greg, no wonder you can hook with street tires
i ran 17x9's with 275/40's all the way around for street and autox last year. they fit great. only rub a little bit at full lock.
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
lata
tim
14.209@95.46mph
Best 60' 1.917
Car: 88 IROC
Transmission: auto
Would you be able to fit 295's on the 16 x 8 rim? just for the rear
Pat Hirsz
www.iit.edu/~hirspat/MyPage2.htm
88 305TBI
Mods:Hooker Aerochamber 3" exhaust, gutted kitty, March pullies, no smog, 180 thermo,
14x4 K&N, 3.42 gears(open), Ultimate TBI Mods,AFPR,MSD(ignition,coil&wires),Edelbrock TBI Manifold, 195ltr/hr fuel pump,
Eibach springs with KYB's all around,
Harwood cowl hood, Z-28 wing, fresh paint(black)
120,000 miles, 5spd, T-tops,slp headers on its way
92 RS, 305TBI, auto, 3.08 gears, 180 thermo, glasspack (no muffler)
Pat Hirsz
88 305TBI
Car: '87 Firebird
Engine: '89 Corvette L98, unstock
Axle/Gears: 3.23 posi
We run 16X12's on the Racecar.
But then we also have a 'wide body kit' on it
Redbird
Bayou Motorsports
87 Firebird-Daily Driver/Autocrosser
84 Z28-Full bore Autocross car
Delta Region SCCA
#00 C Prepared
Redbird
Bayou Motorsports
Delta Region SCCA
#00 C Prepared
Engine: 385 HSR
Tim, Andris is the one with the big wheels/tires. I have 255/50ZR16's on stock IROC rims, but I was still able to pull 1.9x 60-foot times on nearly bald BF Goodrich Comp T/A ZR's.
Greg Westphal
'87 IROC 305TPI/A4
Greg Westphal
'87 IROC 305TPI/A4
Car: '89 Firebird
Engine: 7.0L
17x9.5 with a 5-1/2 backspacing will fit all the way around with a 275/40-R17 tire. 17x11 wheels will not quite fit. To use them you will need to cut and refit part of the rear fender well and eliminate the emergency brake cable. Someone said a 295/50-R16 would fit. No it won't. I had some on my El Camino on a 16x9.5 rim with 5-1/2 backspacing and fit them on the Firebird for fun. Too wide of a tire and too tall.
There's a guy on here with a maroon RS running 17X12's on all four corners, if I remember correctly. Do a search for SEC, that's the kind of rim they are.
Matt86Z
~Check out my Thirdgen~
...This Ain't No Speedway!...
Matt86Z
can i run BFG 235 60 15 T/As up front and 12.5x28x15 M/T ET STREETS or 10.5x26x15 M/T Sprotsmens on the back with stock 15x7 Z28 rims with out rubing. Thanx
when the green flag drops the bull$hit stops
Curent: 350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
Spring 01: 406, Comp 282 solid cam, 2400 stall converter, every thing else the same.
R.I.P #3
R.I.P #3
Mutillator
Exterior Parts for Sale
Oct 1, 2015 06:05 PM
kyle5647
Aug 15, 2015 11:56 PM
