and another what will it run!
Car: 89 camaro
Engine: 383
Transmission: 350 tci 3000 stall
Well, after collecting parts for almost two years I finally got my new motor in and running! Im trying to line out a few things and fine tune the carb/ hope to have it ready by next weekend for track! anyone wanna take a guess on what it will run?? Im thinking in the mid to high 11s.
3400lbs
th350 3000 stall 373 gears
forged 10.1 383
UdHarold solid roller
249/255 640/640 110lsa
new Afr comp ported 195s
rpm air gap 750dp
hooker LTS 2.5 duals
3400lbs
forged 10.1 383
rpm air gap 750dp
Car: 1988 pontiac Trans Am GTA
Engine: DFI,Single Plane,200cc Dart I.E,355
Transmission: Th400 PTC converter
Axle/Gears: Stock Ausie 9 bolt w/3.45 gears
Re: and another what will it run!
I'd say closer to bottom 11s maybe 10.90s...buds 406 with similar cam and ported afr 195s, big stuff 3, accel pro ram w/90 degree elbow and ls1 TB ran 10.70s full weight Iroc with th400 and 3.90 gears..27.5 m/t streets....this is the info on his ported heads... (PORTED AT PORT PROS IN TEXAS to now 217cc. HEADS FLOW 298 @ .600 on Intake ..223 ON THE EXHAUST..W/ 2.05 Intake/ 1.60 Exhaust Ferra 6000 Valves and Titainium Retainers ),...he sold the car and motor alil while ago
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Low 11's should be possible (maybe even quicker). But not with that stall. I think you would be looking at something around 4000 for best performance.
Car: 89 camaro
Engine: 383
Thanks for the feed back. Yeah the stall is a tci street fighter I bought about 10 years ago. I hear now days you can call a converter company a get a 4000 that drives like a 2000. The heads are the newest comp 195s afr says they flow close to 310 @600. The car feels fast just driving it but Idk about a 10 It would be awesome to get a mid 11.
Car: '82 Z-28
Engine: 355
Transmission: TH-400, 8" ATI MRT
Axle/Gears: Moser 9", 4.56's
I don't think it has 10's in it as it sits; but mid 11's shouldn't be a problem as long as it hooks. Some more gear and a 4500 stall should wake her up, but have fun with it the way it is for now! Good luck!
Car: 89 camaro
Engine: 383
Im going to the track friday night. its about a 30 mile trip one way and im driving it. hopefully the 7.5 rear holds up and I can make it back home! lol The car hooked dead solid with the old motor but this has a little more power.
Car: 89 camaro
Engine: 383
well, I took it to the track friday night and it didnt turn out as well as I would have liked!
After a 30 min drive there was rain in the area so i went right to the staging lanes and down the track never even took the air cleaner off!
60 1.86
1/8 7.81 mph 91.30
1/4 12.13 mph 113.64
Next pass I never touch anything just wanted another baseline run
60 1.88
1/8 7.89 mph 90.37
1/4 12.28 mph 111.64
Soon I let off the gas I could tell something was not right and the motor was missing so I pop the hood and noticed the fuel pressure had dropped from 7 psi to 3 and the car was missing bad. I drove it home looked under the valve cover and a rocker was was laying between the valve springs. the pressure was back up to 7psi by the time i got back home.
60 1.86
1/8 7.81 mph 91.30
60 1.88
1/8 7.89 mph 90.37
Car: 89 camaro
Engine: 383
I put the rocker back on and everything seems to be fine. I learned I was not locking the poly locks the correct way. Im not sure when the fuel pressure dropped or what caused it? The car seemed to be hooking up faily well not sure why I didnt have a better 60ft. the car didnt 60ft well with the old motor. maybe the coverter?
Did get some nice pics
Car: 1990 IROC
A lazy 60' could definitely be the converter. Judging by your first pass listed above, the 1/8 MPH is the same as mine when I run 11.60 out the back. Your 1/4 mile MPH might be a little low. That could definitely be a fuel delivery problem. What is your fuel system setup? What was the DA at the track during these runs?
Car: 89 camaro
Engine: 383
I just have the gas tank stumped, a holley blue pump. stock lines and a mallory return regulator. I have no idea what the DA was!
Car: 1990 IROC
What's the diameter of your tire and what RPM are you crossing the stripe? Maybe the converter has a lot of slip. Also, the 60' is at least 2/10ths slow.
The holley blue should be sufficient (but the stock lines might be a crap shoot depending on bends,kinks, etc).
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
