stats on actual IROC's
Car: 86 IROC-Z
Engine: 406
where can i find some actual stats on IROC's when they were used in IROC? iroc.com doesnt have anything.. heck trying to find soemthing from 4 years ago is hard enough. anyone know of some old magizines that would have some???
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Just ask what u want to know and we'll tell u.
89 RS
STILL Looking For:
An 87 IROC-Z28 350 TPI
Yeah I have an RS, but I want an IROC-Z!!
89 RS
STILL Looking For:
Car: 86 IROC-Z
Engine: 406
what size tires, what was the body made out of, dimensions, at what angle is the wing/spoiler, what was the weight distribution % *ie 49/51, HP/tq, how much was the car dropped/how far off the ground is it.
my answer is yes to all
90 RS 305 tbi, 4 3/4" cowl Hood, Edelbrock TES headers, Flowmaster exhaust, Crane roller cam, comp roller rockers, vortec heads/intake, ported tbi, w/new injectors, 1 inch tbi spacer, air foil, 14x4 k&n flat base air cleaner, Rebuilt 700r4 w/ B&M shift kit, B&M Megashifter, 3.23 posi, 2 12 RF's with mtx amp, top of line alpine cd player, soon to have 90-91 gfx, z-28 wing, new paintjob, rims, and all new lowered suspension. MSD probillet distributer, and coil in the mail
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
usually 16"
metal
Same as any other f-body
a little more depending if it was a 305 or 350
stiffer springs but not dropped.
I think you're expecting an IROC to be something special. It's a fancy name that was used for a few years replacing the Z28. Although cosmetically there were some differences between models, mechanically they were the same. IROC's came with a few more performance options that typical cars like RS , LT etc didn't have.
I think the answers you want can only be answered by GM and I doubt you'd get any better results from them. They won't even tell you why they change a simple fitting to another simple fitting.
Read through the f-body FAQ. If it's not in there then you'll have to contact GM.
metal
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I think he's talking about the race cars.
[This message has been edited by Apeiron (edited October 21, 2001).]
Car: 87 IROC L98
Not sure how much searching you've done then.
Start with this.
http://www.irocracing.com/current_season/garage.html
Start with this.
Car: 86 IROC-Z
Engine: 406
aww!!! i know they have stats on the new iroc firebirds... ok lets reword the question.
does anyone know where i can find some actual stats on IROC's *race cars* that were used from 85-90? geesh
what size tires: 27/11/15
what was the body made out of: fully adjustable tubular frame
dimensions:??
at what angle is the wing/spoiler:??
what was the weight distribution % *ie 49/51:??
HP/tq: 450HP@6,500RPM and 405TQ@4,800RPM
how much was the car dropped/how far off the ground is it:??
These cars had 750CFM Holleys, not 390.
dimensions:??
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
The specs I know of for the 1984 IROC series race cars that GM modeled the appearance of the poduction 85 IROC-Zs from are as follows:
Body All fiberglass manufactured by Diversified Glass Products.
Chassis Banjo Mathews Grand National tube chassis, fully adjustable for ride height and weight distribution.
Front Suspension Banjo Mathews designed unequal length control arms. Monroe hydraulic shocks
Rear Suspension Banjo Mathews coil spring, solid axle, hydraulic panhard rod.
Brakes Hurst/Airheart 4 wheel vented discs, 12.2" X 1.4".
Rear Axle Winters or Stock Car Products quick change, 3.90:1 for road courses, 3.50:1 for oval courses.
Wheels & Tires 15" X 9.5" Weld Wheels. Goodyear Eagle Grand National tires, 27" X 11".
Fuel Cell 33 gallons.
Transmission & Clutch Tilton Engineering triple disc clutch. Borg Warner Super T-10 four speed trannie.
Engine Small block Chevy prepaired by Katech Inc.
Displacement 355 CI
Bore X Stroke 4.00" X 3.50"
Compression Ratio 9.5:1
Heads Bowtie Aluminum.
Camshaft Crane roller, TR260/4167-2-6
IntakeHolley 390 CFM double pumper four barrel, Edelbrock Bowtie Victor Jr.
Exhaust Hedman 1 3/4" headers Side exit pipes, no mufflers.
Ignition MSD T6.
Weight 3350 Lbs.
Wheelbase 108".
Horsepower Tuned to 420 HP ±5 HP @7000 RPM.
Torque400 lbs/ft @4800 RPM
Top Speed 158 at Michigan, 179 at Talladega
Acceleration 0-60, 4.9 seconds.
¼ mile, 12.4 - 13.4 depending on gearing.
I'm not sure about the actual angle & size of the rear spoiler, but it was at aproximately the same angle and shape as the production spoiler but was about 4"-5" high, and had an adjustable height extension on the back to increase total height to around 6"-7".
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
[This message has been edited by IROCKZ4me (edited November 03, 2001).]
Displacement 355 CI
Ignition MSD T6.
Weight 3350 Lbs.
Wheelbase 108".
'86 IROC-Z Camaro
"Cogito ergo zoom"
- 355 cid
- AFR heads
- Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
- modified SLP runners
- TRW forged pistons/ceramic coated
- fully balanced
- Edelbrock headers/ceramic coated
- SLP cat-back
- Paxton supercharger
- Nitrous Express nitrous oxide
mustangman65_79
Aug 11, 2015 03:17 PM
