Can you estimate 1/4 time from 0-60?
Re: Can you estimate 1/4 time from 0-60?
well thats depressing cause my mods are completly rebuilt bottom end, tpis big mouth lower intake, ported upper intake and ported slp runners, Crane 2032 cam, ADPR, hooker 2055 headers and Y pipe, full 3" magnaflow exhaust, ed wright piggy back chip, rebuilt trans with some upgrades, 9 bolt 3.45 limited slip, new firestone firehawk indy 500 tires..... now never got it dyno tuned yet cause hard to find someone who wants to do it, i found 1 shop but they want 500-700. timing is set at stock 6* BTDC, and my air/fuel wide band reads about 12.2 or so at WOT. was thinking about playing with the timing and fuel pressure regulator but not sure where to set them at.
wonder what can be wrong, would have to figure with those mods car should run better them stock....
think a dyno tune would make a big difference?
Well thats mostly full bolt ons but mild cam. They run mid lower 13's in good air on good tire with some converter.
No converter hurts 0-60 times and thus et. Dyno tune will pick up some power but its not worth 500-700. Id buy the equip and learn yourself. Its best thing you can do
I think its gonna take a big pressure change to bring air fuel back down that much but remember its also goin to change part throttle fuel and could make you too lean at cruise. Its easier to take 5-10% out the pe mode fuel table in the bin to get to high 12's air fuel
that stuff seams so complicated to me.... i looked into something called ebl flash or something that seems liked you can tune it live without taking the computer out and having to burn a chip each time.... any experience with that?
I havent played with that system but its not to complicated. They make tuning stuff that you can tune on the fly but chip burns arent that hard. Your combo sounds like it runs well on the base chip so only small and easy changes need to be made
evilstuie
01-09-2020 08:29 PM
Street Lethal
04-30-2019 12:14 PM
