Cant get hooked up
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
Cant get hooked up
Hey fellas im in need of some help getting my car to hook up. Its a stock suspension camaro with a sb/th400, it runs mid 10s with 60foots from 1.41 to 1.55
I leave on the transbrake at 4200rpm ,whippes the tires around 2 or 3 times then goes. I had 3 way comp engneering shocks on the back and stock preloaded sway bar. I junked that stuff for qa1 double adjustables and wolfe sway bar, but not tested yet. Shocks are 0 rebound 12 compression.
Theres 90/10s and moroso trick spings in the front, copy of s&w torque arm, lca's in the bottom hole and 28x10 hoosier slicks.
Am i headed in the right direction with the shocks and arb? Should i have a shorter torque arm with a lower powered car?to hit the tires that much harder?
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
Re: Cant get hooked up
Why 4200 on the brake? What converter is in it? Did you always leave there?
I leave at 3500 with my 355...and it goes the same 60' as leaving at 3100..just does a better wheelstand.
Id look into some fresh tires...see if thats an issue...
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
These cars are too heavy to run anything but a stiff sidewall and expect them to last more than 40 or so passes.
Engine: 7.0L
A 28x10.5Stiff would last 100+ on my car. The radials last about 40-60 before the tread is gone. The non-stiff would beat the Sidewalls out of them before the tread would be gone.
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
Tires have to be done...if they used to work and not now. Nose heavy cars need all the help they can get for traction. I thought my radials were gone...balanced the car and it launched better than before...and i added 100# to the rear of the car.
i am not a believer in the sidewalls going away thing.... yet. ran standard sidewalls for probably around 100 passes or so with no signs of going away. i run a s&w torque arm as well as moroso front springs. i would say that if your car is spinning at the release of the transbrake, you should try to move the lca's lower to make it hit the tire harder. i normally ran 12lbs of air in my hoosier 28x10.5's.
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
This summer i tryed a shorter tq arm. 25 inches from the front tq arm bolt in length. I had the best traction with this set up but it was hit and miss and the tires where new then.
Then i tryed the pete z bars and that was a complete failure, Spinning everytime.
Both set up where with the cheap shocks and stock sway bar. Ill try stiff sidewall tires and go from there.
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
Its never been on any scales. I wouldnt say its lightweight or anything. Everything i took out i probley added back in with the cage and the s60.
Stiff sidewalls all the way, try tubes as well.. I would also agree with sidewalls being shot, mine go very quickly in my stick car, and had same issue in 87 when Auto.. I have pics with 12 lb of air and wheel almost on pavement on launch - however short tq arm also.
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
I finally got to try it out. 1.37 in 60 feet all day long. It seprates a little too much but i never seen any pictures untill racing was over, somthing to work on next year. Thanks for the help guys.
Nice launch.
mine seperates like that if it does a wheelstand. if it stays down its normally ok. i think when the car is at such an angle, the rear tires try to run out from under the car and thats why it seperates so much.
Engine: 7.0L
what torque arm is in the car? i noticed that the short torque arm cars (like mine, running a jegster) would seperate more than a longer torque arm...wonder if there is anything to that?
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
I copied off the s&w tq arm. Its 53 inches from the front bolt hole to the heim joint in front i think. I used a slider instead of a shackle, you can see part of the tq arm crossmember in the pucture.
Car: 1991 B4C Camaro RS
Engine: 370 lsx ls3 heads victor jr w/carb
Transmission: TH400 w/brake coan 8"4500-4800 stal
Axle/Gears: Moser 9" locker w/ 4.11's
Do you get any front end wobble that you can feel in the steering wheel after the front vines down I have similar front end setup and mine shakes like crazy if I really get aggressive off the line. Are u running a steering stabilizer?
Engine: 7.0L
I had the real bad wobble and it was worn tie rods and stuff.
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
I replaced the tie rods etc with my s10 steering box and it shakes a lottle but actually lands pretty easy 60' out from 1" off the bumper.
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
I had the whobble at the first of the season. Bought the ed quay steering damper and it hasnt done it since. I still have the ps box with the lines looped. Mine shook so bad i thought the wheels where falling off.
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
I think a lot has to do with your engine trans and gear combo...makes it drive out and down easier on the car...or a poor combo drops like a ton of bricks. Limiters may make yours perfect.
Z28/ZR1
Oct 23, 2015 01:04 PM
