subframe connectors?
i am building a 1988 iroc-z drag car and i was wondering if 350 horsepower is enough to need to install subframe connectors
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: T-56 w/hurst short throw
Axle/Gears: unknown
Re: subframe connectors?
Sub-frame connectors are a recommended modification for all third gens due to the flexible chassis.
So, just get them asap
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
my only regret about my UMI sub frame connectors was not putting them on sooner. Night and day difference they made in my car
Car: 84 camaro coupe
Engine: 360 sbc
Transmission: turbo 350 manual valve body
Axle/Gears: Moser 12 bolt 4.11 35 spline
I added connectors from S&W racecars and could feel the difference when we backed the car out of the shop.
Car: 1988 firebird formula 350
Axle/Gears: 2.77
subframe connecters may be next on my list, recommended brands,parts, part numbers, places to get deals,all help is greatly appreciated
Posted from Thirdgen.org App for Android
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
Had great luck with the UMI subframe connectors. Highly recommended.
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
Dont get hotchkis...had them on a car years ago and they fit weird.
Get a nice straight piece from a good company. Umi...spohn...etc
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i have put on UMI, Spohn, Jegster, Comp Eng, Lakewood, and have built my own...
i like the spohn the best out of all of them, but they still need some small teaking, as i don't really care to try to weld round tubing to a flat floor, so i typically add a flange to the front mounting area. just get them non powdercoated, cause their powdercoat is stupid thick, and takes quite a bit to get it to come off in the areas that you need to weld on. just blast it with your favorite color once their in.
otherwise, i won't hesitate to built my own again.
the only thing i haven't done yet is some thru-floor type...i haven't gotten adventurous to cut into a floor yet, lol
Axle/Gears: 2.77
i read that bolt-on kits arnt worth it. and welding is about the only thing my buddies charge me for. so the easiest to install weld-in kit is what id be looking for. easier for him cheaper for me.
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Engine: 7.0L
not quite...i was thinking more like 2x4 box tubing running down the perimeter that you could weld the floor to and a tie a roll cage into.
phoenix, i don't have any real clean pictures of the ones i built....i do this stuff on jackstands and it's a bit tough to get a clear shot unless the car ends up on a lift later.
here's the one picture i have
Engine: 385
Thanks, that'll work as a good starting point for me. I'll be doing mine off jackstands aswell, so I completely understand lol. What size is that tubing?
Engine: 7.0L
Engine: 360 sbc
The ones from S&W racecars are round tubing. They attach at the rear torque boxes, forward where the trans mount bolt to the frame rail, to the outter lip of the rocker panel and throught the floor below both front seats. They also provide a mount that moves the torque arm off the trans mount. I bought both when I did mine. I used a friends lift in his shop and got them install in about 4 hours. Mine are completely bolt in but could easily be welded if you desire. I did not in case I decided to switch cars later down the road. As i said before the change was remarkable. Car felt more solid when I backed it out of the shop. Also the car flat hooks at the drag strip. every thing else is still pretty much factory suspension, I am even still running factory trailing arms. Car hooks and goes. May the only down side is the rear where the connector mounts the the torque box hangs a little low--has not hung on any thing but some guys may not like the cosmetics of it. System was not very expensive and S&W were very easy to deal with.
I bought Frame connector, torque arm and twp 8 point roll bars and have been very satisfied. Roll bar fit like it was custom bent for the car.
Engine: 7.0L
i've used an s&w roll bar kit in an 89 RS a couple years ago, and i was also pleased with their fit. i'm going to get their bent door bars for my car probably cause i can't use my door handles with the straight bars i have in there now.
Engine: 360 sbc
I had to remove the arm rests also. I am not sure that the bent door bars would help, I have never seen them in a 3rd gen. Aside from the arm rests, which I had planned on having to remove every thing else fit really well. A little pushing and pulling t get everything lined up with the frame connectors but for a car that had been handled ruff and has 96k miles they went right in
TMZIrocZ350
Oct 7, 2015 12:09 PM
tmork454
Sep 29, 2015 06:33 PM
