First Time At The Track
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
So running my car down the 1/4 for the first time next week. Im hoping to land into the 13's but have a feeling im gonna be in the low 14's.
So my question is should I just go from foot on the brake to gas when the tree drops or you think I should take off at like 2200 rpms? I have a 2300-2500 stall torque converter....
Havent made a pass since my last 3rd gen in 1998. Ran a 15.8 on an 89 L03..
It does 0-60 mph in about 6 seconds, really dont know what to expect.
Mods:
Speed Density L98 - completely rebuilt
52mm Throttle body
Ported Plenum
Ported SLP Runners
TPIS Big Mouth Lower Intake
Crane 2032 Cam
MSD Distributor & Wires
Stock Heads rebuilt
Hooker 2055 Shorty Headers and Y Pipe
Gutted Cat (only because I had an injector get stuck open and melt it)
MagnaFlow 3" Exhaust Cat Back
9 Bolt Borg Warner 3.45 Limited Slip
Welded Alston Sub rame Connectors
Founders Performance Lower Control Arms & Panhard
Timing set at 8* BTDC
So what you guys think 13's?
Mods:
52mm Throttle body
Ported Plenum
Ported SLP Runners
Crane 2032 Cam
Stock Heads rebuilt
Re: First Time At The Track
Left foot on the brake, throttle up 'till it strains on the brakes, somewhere around the last orange floor throttle and slip left foot off of brake.
Good luck.
Good luck.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
You can try it both ways, or somewhere in between too. Sometimes leaving off idle will do best, by flashing the converter. It all depends on converter and combo. Be sure to report back. My best times were typically done by getting up as hard on the converter as I can go without pushing the car or spinning tires.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Ditto, all my cars from bolt on L98 to 383 on spray, to bolt on ls1 all 60'd best with full footbrake stall til about pushed thru brakes or spun tire. However all combos had same brand converter, Edge racing.
My 6.2l truck feels best brake stalling stock converter to 1800-2000 rpm compared to flashing it. No times to compare but seat of pants feels better
Engine: 5.7 L98
my tires are firestone firehawk indy 500 think i go right to the floor or semi-ease it in if i leave at like 1500 rpms? the car isnt making that much power, you see the mods above, but not on slicks either...
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
you should get more than one run . jus play with it an see what runs the best . try everything once . good luck
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Engine: 5.7 L98
Engine: 7.0L
It definitely is 13 sec capable. Getting it there on street tires will be the trick. You may find that it will spin MUCH easier at the track then on the street, and loading the converter may hurt you
Engine: 5.7 L98
yeah, the stock heads will hold me back and the extra weight of the vert dont help too. its 0 to 60 is 5.7 to 6.1 secs consistantly.
Street Lethal
Apr 30, 2019 12:14 PM
