Yellow Bullet pics/updates, and new 370/t56 times/videos
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
This weekend at Cecil County Dragway in Rising Sun, MD has got to be the baddest small tire race in the northeast all year. Gates opened wednesday for the early birds coming in, but mostly people started showing up yesterday. those who tested yesterday paid a premium at $200/head
I got there bright and early this morning, around 9am or so. it was still expensive to test ($100/head today) but worth it for me since i have such little seat time. I unloaded, and got the wheels tires over to the M/T trailer where my good friend Buddy L. got me set up with a fresh set of 26x10.0Stiff's. we thought we were going to put tubes in too, but have to drill the valve stem hole out to a 5/8" hole and the way my wheels were built just wouldn't have that. so, we decided to try it without them. After a quick IC adjustment, I was ready to make my first pass.
first pass was an eye opener
it seems that the car has responded well to the higher rpm shift point, and smaller tires (ie, poor mans gear change). 11.05 @ 125 on a 1.57 60'. felt like a rocket once it hooked, though there was a slight bog to note. launch speed at 5500 rpm, 13psi in the slicks.
talked to Buddy about how it reacted, he said to up the pressure (who knew?!) ~.5-1psi and go up on launch speed. back up around and 5900 launch rpm, 13.75psi, BAM! 10.95 @ 126.2 on a 1.54 60'.
i can deal with that. backed it up with a 10.96 @ 126.7. .033 and .081 lights repectively.
pic of the new 26x10's, i'm surprised, i think i prefer them, lol
there are 450 cars here so far, and we haven't even gotten into qualifying or eliminations. i'll keep this thread posted as the weekend goes.
for now, here's a couple more thirdgens (not all of them) that are at the event.
it seems that the car has responded well to the higher rpm shift point, and smaller tires (ie, poor mans gear change). 11.05 @ 125 on a 1.57 60'. felt like a rocket once it hooked, though there was a slight bog to note. launch speed at 5500 rpm, 13psi in the slicks.talked to Buddy about how it reacted, he said to up the pressure (who knew?!) ~.5-1psi and go up on launch speed. back up around and 5900 launch rpm, 13.75psi, BAM! 10.95 @ 126.2 on a 1.54 60'.
i can deal with that. backed it up with a 10.96 @ 126.7. .033 and .081 lights repectively. pic of the new 26x10's, i'm surprised, i think i prefer them, lol
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
Re: Yellow Bullet pics/updates, and new 370/t56 times/videos
Video is awesome Matt, easily the best in-car I've ever watched. Makes me want to start rowing gears lol. Get it uploaded on here!
Engine: 7.0L
I'll get it on YouTube tonight so i can linkit here.
About 2 hours ago we did first round qualifier, I upped the launch rpm to 6000 and upper air to 14psi only to spin hard to a 1.70, and went 11.05 @ 125.
There are over 500 cars here. I'll try to get some more vids and pics when I can.
Yes, the red sportcoupe is a Jeff's car. He's number 3 right now in ultra street with a 5.12 @ 138
Live feed is at www.motormaniatv.com
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Nice Matt, was wondering when the 10a would come back!
How's the 1/8th looking?
Engine: 7.0L
7.03 @ 100.08
Car: 91 firebird
Engine: sb2.2 headed sbnos
Transmission: tsi glide
Axle/Gears: 4.30
Matt did you meet darrell with the blue x275 car? Bought some parts from him awhile back super nice guy just like to put a face with the name if hes in the pic?
Oh and awesome results. I also like the 26 wouldnt mind running some 8.5 stuff with mine if I ever finish it
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
You ever swap gears Matt?
Engine: 7.0L
the gears are still in GA, maybe later this winter. going through traps at 6600 so i definitely could use the 4.30s i think.
Today didn't start out quite as great as yesterday but ended well. I had a brain fart after we got into the staging lanes and didn't check tire pressure before pulling into the burnout box and the tires had been baking in the sun for nearly an hour in the lanes. when i got back to the pits i check tire pressure and it tells the tale as to why it spun so badly. 1.70 sixty, nothing really to report on that pass at all other than it spun like mad. tire pressure had risen a full psi.
2nd hit was a different story though. the sun went behind the clouds, it was about 5pm or so and was starting to cool off a bit. i made sure i was at the optimal 13.75psi in the tires, and taught my wife how to use the tire pressure gauge. i'm hoping to give her the responsibility so we can do last minute checks after i'm strapped in. they were good to go and i suited up. everything about the pass was pretty excellent (except for the light). it went 10.91 @ 126.66 on a 1.55 sixty. my confidence in the car and my driving is increasing. i'm pretty happy.
it was hot today, even Roxy thought so
here's the pass
also met a fellow TGOer "zz4iroc". he stopped by for a quick coil spring trim
all in all a very good day.
it is note worthy that i looked back to see what the car did with the th400 in similar air conditions. granted i also changed the cam/intake, but i think it still gives a decent comparison.
previously:
2400' DA, 10.8x's @ 124ish, 3275lbs
currently:
2300' DA, 10.9x's @ 126ish, 3460lbs.
here's the pass
previously:
currently:
Engine: 7.0L
here's a video from yesterday. this was the 10.96 pass. i'm sure i have a ton of stuff to work on, but for pass number 7 with the combo, i'm pretty happy
http://www.youtube.com/watch?v=V9rtr...ature=youtu.be
Engine: 7.0L
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Doing great Matt, the more seat time the more natural the t56 will become.
Engine: 7.0L
it's coming around, for sure. i'm impressed with the trap speeds, especially at this weight.
here's a pic of the car launching. hasn't pulled the tires yet, but it's still a cool pic i think
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
They say up ain't forward, lol. Looks like it cannot leave any more straight than it is. Guess that th400 holds back compared to the gears in the t56. Well, as you said, hard to say since it is not identical engine combo.
Engine: 7.0L
Well, had a great weekend! Went out first round, but I got a ton of data and learned some stuff. I made a rookie stick shift mistake, pulled the 3-4 shift towards me instead of straight back, jammed the stick into the gate. Trans is ok, still shifts smooth but was a big hit to the pride, especially cause I treed the crap outta ole dude and was running him down hard. Best pass of the weekend ended up being a 10.91 @ 126.6. Gonna put more gear in it, fool with the carb more, maybe put the spacer in, and generally get more seat time. Going to training in KS for two weeks so probably won't hit it up again till October.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
No breakage and had a blast, sounds like a good time to me!
Car: 1991 B4C Camaro RS
Engine: 370 lsx ls3 heads victor jr w/carb
Transmission: TH400 w/brake coan 8"4500-4800 stal
Axle/Gears: Moser 9" locker w/ 4.11's
good work man. I saw your 10.91 pass on the live feed. sounded awesome. looked great!!!
Engine: 7.0L
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Darrell is a good friend of mine and he is definitely a good dude. He is on the left side of that picture wearing the black TSI shirt with the #31 on the front.
Matt your car sound completely isolated in sound compared to all the other SBC and BBC cars out there. That LS motor screams! Third gen's were representing for sure this weekend.
Engine: 7.0L
It was good to meet you Justin! yeah, hard to beat an LS motor at 7K
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
Hey matt...yeah you were a shifting beast!!! It was great racing with ya this weekend, and that 10.91 was awesome!!!
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
The real crappy part of the whole weekend for me was hooking in the left lane 1st round pro street...and then the 1st round of pro dial blowing the tires off in the right lane. This car never spins, so i dont know what happened...they did mop something before i staged.
Guess ill have to switch to slicks when these radials are done...or put the 80# weight bar back in the trunk
Engine: 7.0L
i have a brand new never mounted set of 26x10.0's
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
The et drags I just got in that size work great at 11 pounds for me. At 12.5 I was surprised the skipped and then hooked with the tight converter.
I wanna see how you do with the gear swap Matt! I am trying to avoid it with the th400 being a street car, but if I go 4L80....idk. The 80 builders say something about not shifting beyond 7000? What kind of crap is that?
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
Wow...i run 22.5 lbs in my hoosier drag radials. And thats with a 5300 converter and 4.56 gears.
But agreed...matt needs gears bad!!!
Engine: 7.0L
It liked 13.75# the best so far
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
****** those gears Matt
I ran my ET Streets at 10 psi for the best hook albeit they're a little old (but hardly used) reading the date code. Nothing spectacular but a 1.7x 60' with a 3700 lb near stock suspension coupe.
I was a little concerned after checking out the Mickey Thompson tech bulletin on inflation pressures.
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
awesome numbers man! put mine back together on monday and went for a run out on the highway, think my pinion angle issue is solved. don't worry about the missed gear, happens to the best of us.
where abouts in KS will you be training?
Car: 91 Z28
Engine: 6.0L LQ9
Engine: 7.0L
Yessir. The position is in MD though
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
That is awesome man !! nothing beats rowing the gears.. most fun one could ever have with the old pants on ...
Engine: 7.0L
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Awesome video!! I can't wait to get my 2nd gen finished, but I gotta get the wife's Iroc in storage so I can wheel the rotisserie into the middle of the garage!
LT1Formula
Oct 8, 2015 08:34 PM
