First 2014 shakedown passes for twin turbo 401
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Made 3 hits at street car night. Track was cold and rain was coming late. Struggled for traction 2/3 passes. First attempt was 7 psi at 3800 of tbrake to 20 psi no ramp in. Blew first gear off and let out, ran 2-3 thru 1/8 and coasted out.
Next pass was my best all night. Same tbrake settings but 1 psi or so more boost, plus ramp rate of 6 psi per second. Hooked at first but seemed to unload as ramp came in. Spun top of first thru the 1-2 shift. Then it went straight.
1.49 60'
5.96 123 1/8
9.12 155 1/4
http://m.youtube.com/watch?v=mrTmwIk...ature=youtu.be
Next pass i tried higher two step launch and 5 psi per sec ramp but it didnt take. Spun 1-2 hit limiter 2-3 and went 9.63 152
Lots left in it. Car was about 3725 lbs with me in it. 3700 even this morning with less fuel and no helmet lol
1.49 60'
5.96 123 1/8
9.12 155 1/4
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
Re: First 2014 shakedown passes for twin turbo 401
Car sounds great in the burnout box. Your car is moving bro! Can't wait to see this thing when you get it all dialed in!!! Mid to low 8's all day. Congrats!
Engine: 4++,350 & 305 CIs
Veddy nice!
Car: 89 Iroc-z
Transmission: TH400
I got tons of compliments on how this 5" exhaust sounded. Its really an awesome system
If i didnt spin it might have gone 8.99 that night. Track must have been damp. All the cars had condensation on them. Nobody was hooking well
Car: 89 Iroc-z
Transmission: TH400
Added another vid from different angle
Car: 89 Iroc-z
Transmission: TH400
Lol noone could tell with hood down and intercooler blacked out. 18's on front lol
Tell ya what very happy with hydraboost and c5's up front coming down from 155.
Car: 89 Iroc-z
Transmission: TH400
Tons left! Adding a third fuel pump and looking to get a more aggressive race gas tune. Should see 1200 whp and mid 160's. also could drop 100 lbs in exhaust and skinnies
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
the first pass it looks like you're on the brakes early?
Car: 89 Iroc-z
Transmission: TH400
No it was brake pedal not being adjusted far enough out. Dropped at high rpm i think possibly from hydroboost setup and trigger switch to turn on lights? I wasnt on it early that run
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
I haven't been around in a while. What has changed since you were just cracking high 9's a few years back? I think I remember some 9.70's were your best?
Car: 89 Iroc-z
Transmission: TH400
Lol everything! New heads cam setup new turbo hotside, new efi system, tons more boost and new rear/trans with brake
Car: 1986 Camaro SC
Engine: None
Transmission: None
Alright, well that sounds like enough for a few tenth's. lol
Good job man, I admire the dedication you guys have for these cars. It's really paying off.
Engine: 7.0L
thinking you should have stuck with yours now? lol
darwinprice
17
Oct 11, 2015 11:51 PM
the_hamturdler
Sep 30, 2015 12:50 PM
