Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
1983 Tube Chassis Drag Build
Old Mar 26, 2019 | 11:07 AM
Phonedude's Avatar
Car: 1983 Camaro
Engine: 598 tall deck chevy
Transmission: Powerglide
Axle/Gears: Nine inch. 4:30
In the fall of 2017 I started to build a tube chassis for the 1983 Camaro I purchased off Craigslist. I started with kit from Chassis Engineering that was owned by two other people who were in over there head once they started the project. They cut and tacked 5 tubes together and quit. I took over the project knowing there was some tubing was missing. I purchased some more raw materials and an SFI spec rule book. What follows is my build
Old Mar 26, 2019 | 11:37 AM
Phonedude's Avatar
Car: 1983 Camaro
Re: 1983 Tube Chassis Drag Build
First day I rolled it in
Old Mar 26, 2019 | 11:50 AM
Phonedude's Avatar
Car: 1983 Camaro
Old Mar 26, 2019 | 12:09 PM
Phonedude's Avatar
Car: 1983 Camaro
Old Mar 26, 2019 | 05:47 PM
Phonedude's Avatar
Car: 1983 Camaro
Old Mar 26, 2019 | 06:14 PM
Phonedude's Avatar
Car: 1983 Camaro
Here we are today trying to figure out how to build the front of this car. The wheel base was 101 inches stock for an 83’ Camaro, which is the same as a Mustang Gt. I couldn’t leave it that way, so I figured out how to stretch the wheelbase to 105 1/2 inches and Increase the stability.
Old Mar 26, 2019 | 10:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Not bad at all. Nice to have a place large enough to do all that and tools/equipment to do all that.
Looks like at least 24.4C but probably 25.2C
Stretch the nose although you may want to find out what the specs are for a fiberglass nose first.
As much as I can dream, I could never pull something like that off. Just doing a back half was a huge project.
Old Mar 27, 2019 | 02:03 PM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
now we're having fun.....!
Old Mar 27, 2019 | 04:46 PM
SG91camaro's Avatar
Car: 91 Tube Chassis RS
Engine: 498ci
Transmission: PG
Axle/Gears: 35 Spline 4.86 ratio
Looking good my man!!! it has plenty of bars in it it should be very stable and stiff for some horse power.
Old Mar 28, 2019 | 09:21 AM
Phonedude's Avatar
Car: 1983 Camaro
Thanks for the compliments, yeah it’s a lot of work for sure, but it’s coming together, I’m started building it to a 25.4b spec in 2017 so I have to change my rear motor mount braces to meet the 2018 c spec revisions.
Old Mar 29, 2019 | 10:28 AM
Wolfster14's Avatar
Car: 1990 , camaro
Engine: 572 bbc
Transmission: power glide
Axle/Gears: 5.14
Great work.
thank you for sharing.
Old Mar 30, 2019 | 09:49 AM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
this is freakin awesome. i love these types of builds. keep us all updated.
Old Apr 1, 2019 | 12:22 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
So how do you make up for the stretched wheel base of 105 1/2 inches as opposed to the stock 101 inches of the stock body?
Old Apr 1, 2019 | 09:49 AM
Phonedude's Avatar
Car: 1983 Camaro
I have a harwood front end that has a stretch in the front fenders, between the wheel well opening and the door seam. Plus moving the body in relationship to the chassis and putting the front axle a fraction forward of wheel well center , Gives me 105.5
Old Apr 3, 2019 | 11:31 AM
Confuzed1's Avatar
Car: 83Z28 HO
You've obviously done your homework on this! It's looking awesome!
Old Apr 13, 2019 | 05:41 PM
Phonedude's Avatar
Car: 1983 Camaro
Old Apr 13, 2019 | 05:43 PM
Phonedude's Avatar
Car: 1983 Camaro
Absolutely the hardest part of the chassis to get straight and square
Old Apr 13, 2019 | 06:10 PM
AlkyIROC's Avatar
Car: 87 IROC L98
As much as I'd love one, it would be cheaper to buy someone elses tube chassis car (providing it has a current chassis cert), than it would be for me to build one. I did my own back half and full cage and that alone was a lot of work. A full tube chassis could cut around 500-1000 pounds off my car. Love to have around 2300 pound race weight.
Old Apr 14, 2019 | 03:03 PM
Phonedude's Avatar
Car: 1983 Camaro
It would be cheaper to buy a chassis car used, but I’m 6’4 and it’s hard to find anything that would be safe for my size. I enjoy working on the car when I have time. I looked at some used cars and they would require changing the cage and replacing worn out parts. It takes more time than money to do what I have done so far. We will see in the end if it’s worth it. Still have a lot to do.
Old Aug 7, 2019 | 05:39 PM
Phonedude's Avatar
Car: 1983 Camaro
Making headway on the chassis. Just pulled it off the table so I can weld underneath.
Off the table and upside down. Time to weld the bottom
Old Aug 7, 2019 | 05:43 PM
Phonedude's Avatar
Car: 1983 Camaro
Old Nov 7, 2019 | 01:35 PM
Phonedude's Avatar
Car: 1983 Camaro
Making progress, had to change tubing around rear transmission mount to satisfy spec changes and make some more foot room.
Lower control arms and mounts done.
Moving on to the rear.
Old Feb 15, 2020 | 11:01 AM
Phonedude's Avatar
Car: 1983 Camaro
Brackets came out really good and tied in rear tubing nicely
Bought some new 4 link brackets, they were laser cut, but the holes were sloppy, so I made my own!!!
Making progress, everything fits good
This car is going to be a little heavy
Old Feb 16, 2020 | 11:58 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
freaking awesome project. very cool!!!
Old Feb 17, 2020 | 03:48 AM
Phonedude's Avatar
Car: 1983 Camaro
Thanks , appreciate the comments.
Old Apr 27, 2020 | 12:32 PM
Phonedude's Avatar
Car: 1983 Camaro
Made some brackets from 1/4 inch plate
Welded them to housing on a 2 degree angle
Fabricated back brace from 1/8
Lazer says it’s centered . Wishbone in background
Welded the brackets together first
Old May 31, 2020 | 10:38 PM
Phonedude's Avatar
Car: 1983 Camaro
Safety first
Making progress
Old Jun 1, 2020 | 07:25 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
bad-to-the-bone, nice work man!
Old Jun 3, 2020 | 01:06 PM
Phonedude's Avatar
Car: 1983 Camaro
Thanks, still alot left to do.
Old Jun 24, 2020 | 10:51 PM
Phonedude's Avatar
Car: 1983 Camaro
Hanging the doors
Old Jul 2, 2020 | 04:35 PM
Phonedude's Avatar
Car: 1983 Camaro
Fitting the front clip
Old Jul 2, 2020 | 07:48 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Really hard to compare anything here to stock, but is the engine set back compared to factory placement? It looks to be completely (or nearly) behind the front axle centerline.
Old Jul 2, 2020 | 08:18 PM
Phonedude's Avatar
Car: 1983 Camaro
The front of the block is actually 1.5 inches ahead of the front axle centerline. However, the front axle centerline is moved 4 inches ahead for a 105 inch wheelbase. Compared to a friend’s third gen with a bbc and a stock transmission location , I’m about 1 to 1.5 inch closer to the windshield base.
Old Jul 2, 2020 | 08:46 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Wish I had the space and the tooling to do all that.
Old Sep 9, 2020 | 01:36 PM
Phonedude's Avatar
Car: 1983 Camaro
Got the radiator and fuel cells mounted.
Getting complicated
Trying to size my wheels with a mock up wheel from a friends car
Old Nov 17, 2020 | 11:01 AM
Phonedude's Avatar
Car: 1983 Camaro
Test fitting front wheels and tires
Welding in driver side floor pans. I made them out of 22 gauge, bead rolled and hammer formed around the tubes
Old Apr 4, 2021 | 03:05 PM
Phonedude's Avatar
Car: 1983 Camaro
Finished driver side floor and seat
Hopefully cut this right
It fits
Powder coated
Old Oct 4, 2025 | 11:28 AM
Phonedude's Avatar
Car: 1983 Camaro
Still working on her , close to done
Powder coated
Powder coated
Ready for paint
Ready for paint
Waiting for the pinstriper
Old Oct 9, 2025 | 02:54 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Looking back at the older pictures, I have questions.
Wouldn't the front wishbone mount be better if the heim joint was vertical to allow more vertical travel?
When mounting the front shocks, how is alignment accomplished?
I'd like to see the sheetmetal work on the bottom corners of the firewall. Was it wrapped around the curve of the floor?
Where is the parachute mounted tube attached to with the rear tubework so high at the back of the car or is that just an optical illusion?
Fab work looks amazing and the diff alone looks really amazing.
85irocZ2819
Aug 31, 2023 03:03 PM
gt4373
Oct 13, 2017 09:16 AM
gt4373
Sep 21, 2016 11:06 PM
niceroc
Aug 11, 2006 04:20 PM
385LT1
Jan 12, 2003 08:26 PM
