Pacific Northwest Region Regional discussion board for WA, OR, ID, and BC.
Need Help Asap!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jul 11, 2003 | 02:16 PM
Project_1986_TA's Avatar
Car: 1986 Trans Am WS6
Engine: Mild 350 TPI
I just got a call from the shop and they said my rearend is totaly screwed and will cost $1495 to build it up with everything. I cant afford quit that much. Does anyone have a rearend for sale with discs, posi and good gears for racing and fuel economy?
PonchoTA: I might have to go with your car. We might have to work out a better price though otherwise i will just go with the shop. U wouldn't wanna take maybe a grand plus an Xbox, 7games, 2controllers and DVD package would u??
NEED TO KNOW ASAP..
Thanks,
Old Jul 11, 2003 | 02:33 PM
well my parents told me just to get it built up with the shops warenty. So im getting a built up rearend with new 3.73 gears and an eaton posi rearend and a whole bunch of other stuff. How do you think it will be going from 2.77broken posi to a 3.73 with an eaton posi?
Old Jul 11, 2003 | 03:13 PM
age's Avatar
age
Car: 1992 Z28 1LE
just what exactly is "screwed" in it? Last I checked, my Eaton posi cost me about $500 CANADIAN, and gears were about $300 CANADIAN (after tax)..
Old Jul 11, 2003 | 03:22 PM
Well....The ring and pinion, gears, posi, axle, bearings, and seal were all destroyed. Hopefully i should have my car back sometime today so i can see the difference of 2.77 to 3.73
Old Jul 11, 2003 | 04:49 PM
PonchoTA's Avatar
Wow. Too bad about the rear.
Mine has a warranty too, btw! With the discs already, about the same price.
I don't play video games, so that wouldn't have helped, but I could have split up the amount to pay the other 500 later...
GL
Old Jul 12, 2003 | 12:18 AM
MarkB's Avatar
Car: 1982 T/A -1986 Z28
Engine: 383 -305
Transmission: T56-700r
is this shop going to give you lube as well? sounds like a serious cornholing,i so highly doubt ALL that is wrong with the rearend,posi is probably worn out *shruG*
Old Jul 12, 2003 | 12:21 AM
yeah comes with everything, lube and even a possible speedo recalibration if needed. Well i guess the reason the rear is so bad was because its been running low on gear oil for quit some time, i just didn't notice untill it was too late.
Old Jul 12, 2003 | 10:21 AM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
i have a good used posi and axels out of a 83 camaro that had disc on it but i guess im a little late in posting this for you
mike
Old Jul 17, 2003 | 12:19 AM
bigdaddyvu's Avatar
Car: 84 T/A, 87 iroc-z, 86 turbo z-28.
Engine: 5.7, 5.7, 6.6
Transmission: t-5, 700r4,manual shift th350
Axle/Gears: 3.73, 3.52, 3.23
dude thats prison rape
I had my installed under $500 in spokane. minus the cost of the gears.
92GTA
Apr 9, 2016 07:39 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Brother Al
Oct 14, 2015 06:39 AM
92projectcamaro
Sep 24, 2015 08:09 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
