Parts Wanted 2006 Looking for something in particular? Ask here.
WTB 350 roller block
Old Feb 15, 2005 | 07:07 PM
dharrison's Avatar
Car: 1968 chevy truck, 85 z/28
Engine: 355, 355
Transmission: 700r4, 350turbo
looking for 350 roller block, bare or short block, in the north georgia area or further away if shipping is cheap. non LT1 block prefered.
Old Feb 18, 2005 | 11:16 AM
Project_Speed's Avatar
Want a title? Post!
Car: 1985 Monte Carlo SS
Engine: Fully Forged 383 Stroker LT1
Transmission: Jackson Racing TH350
I have a used short block, mileage unknown (came in project car I bought). It was running great though... I bought it, drove it home 20 miles, and played with it some on that trip... I have a video of the engine running just before it got pulled if you'd like to see that...
By researching the casting numbers, I found that it was originally a GM Goodwrench Crate engine with 250hp/350ft-lbs built in the 90's as a replacement engine for mid-late 80's pickups... I have since tore down the engine but the short block remains intact, with cam, timing set, and damper still installed...
It is a 4-bolt main block, 350 cubic inches, part # 10066034, casting # 10066036, with 2 piece rear main seal.
It contains the following:
--Crankshaft part # 3932444; nodular Iron 1985 and older flywheel bolt pattern
--Powdered Metal Connecting rods Part # 10108688
--Cast Aluminum Pistons part # 12514101
--Hydralic Flat tappet Camshaft Part#3863151; Intake Lift-.383" Exhaust Lift-.401" (I believe this is with 1.5's); Intake Duration @ .050"- 194 Exhaust Duration @.050"- 202; Lobe Seperation-112 with mechanical fuel pump lobe
--Block is drilled for both L.H. and R.H. dipsticks. Plug is installed on passenger side, dipstick was on drivers
I prefer to have this picked up, but will work with you on shipping if so desired, but it will probably be pricy...
I'm located about 5 miles east of Nashville, TN, so not TOO far from you...
Let me know what you think... I was looking to get $350 for the assembled short block, or $200 for the bare block...
-Garrett
garrett@blackiceperformance.com
814-598-2501
Old Feb 18, 2005 | 11:24 AM
dharrison's Avatar
Engine: 355, 355
-Garrett
814-598-2501
that is not the block i am looking for. i am looking for a factory roller cam block that is machined for roller cam and lifters and needs no modification or expensive retro fit kits to install roller valve train.
thanks anyway,
Dale
Old Feb 18, 2005 | 11:28 AM
Want a title? Post!
understood...
sorry, i'm not familiar with what the block differences are between a roller vs. non roller block...
I assumed you would just swap the cam out for a roller cam and use roller lifters instead of flat tappet lifters...
good luck with your search...
-Garrett
Old Feb 18, 2005 | 10:36 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i have a roller block for sale. it only has about 800 to 1000 miles on it. have all the paper work to it. i was going to go with a tpi set up on it and ordered a set of afr heads in november and the heads hasnt come in yet so i decided to order a 383. if toyr intersted in it let me know. thanks.
Old Feb 19, 2005 | 06:41 AM
dharrison's Avatar
Engine: 355, 355
how much $ are looking to get for it? what did it come out of?
what are the casting #'s? shipping could be a problem. got any pic's?
Old Feb 20, 2005 | 07:16 PM
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
Hey there, I have a L98 short block for sale. I got it back when I had a L03, but since I got my 91 Z I really don't need it. It is a roller block with everything from oil pan, to lifters. I am in the Florida panhandle, so if you feel like making a road trip it wouldn't be too far. Let me know and I can email you more details.
Old Feb 20, 2005 | 07:44 PM
dharrison's Avatar
Engine: 355, 355
i can not make that trip anytime soon. you are about seven hour drive from me.
Old Feb 22, 2005 | 09:43 AM
305RSlc's Avatar
Well depends on how quickly you would need it. I'm not selling it locally or anything and if I don't sell it, and by some miracle come across enough money to start building it up, I was gonna do a HSR 383. But for now I want a bike so my money is going towards that and not building up the engine and it's sitting. But if you become interested, just let me know.
Old Feb 22, 2005 | 05:32 PM
ws6's Avatar
ws6
Engine: 350 w/vortec heads
Transmission: t-5
ive got a '97 5.7 vortex short block. im in south carolina. email me if youre interrested. webersc8@aol.com thanks
Old Feb 22, 2005 | 05:38 PM
dharrison's Avatar
Engine: 355, 355
i am looking for the old style block so i can put TPI setup on it.
thanks anyway,
Dale
Old Feb 23, 2005 | 11:51 AM
3rdgenstm's Avatar
Car: ‘92 Z28
I have a 1987 350. I am just south of Charlotte, NC. The car had 130K miles on it when I bought it and parted it. I don't know how it ran before other than the guy that sold it to me saying that it ran good. He had an electrical problem with the car and couldn't get it to run properly. I didn't care since I was going to part it anyway. It looks clean-- I pulled and sold the TPI setup. The lefter valley is real clean no sludge. I would like $300 for it. If interested email me. piedmontfbody@aol.com
Old Feb 24, 2005 | 10:50 AM
Durrell Jaxon's Avatar
Want a title? Post!
Car: 95 camaro v6 / 84 camaro Z28
Engine: 3.4 / 5.7
Transmission: /700r-4
305
i have an 305 roller block and its a short block. it has an new crank, bearings, rings, oil pump, and sump
Old Feb 24, 2005 | 11:20 AM
dharrison's Avatar
Engine: 355, 355
Re: 305
looking for 350.
thanks anyway
camaro71633
Sep 1, 2015 10:24 AM
Eric-86sc
Aug 24, 2015 09:01 PM
TA8487
Aug 16, 2015 12:21 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
anesthes
Aug 8, 2015 09:37 PM
