305 complete TPI
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
305 complete TPI
Looking for a stock (not modded) 305 motor wik the speed density TPI set-up, harness, computer, everything from the air filter to the stock exhaust manifolds. Worn out ok, but no knocks please.
Will be willing to buy the whole car if the car has relatively straight front fenders, doors, nose, suspensions pieces ie spindles control arms etc. Could care less about the interior. The closer to Texas the better.
Car: 1986 Z28
Transmission: T5 WC
PM recieved ... thanks!
and Chad, if I thought you were half-way serious (and at a reasonable price) I wouldn't hesitate for a second to part out that B4C... I could use the brakes, rear end disc, motor, spare trans, body panels etc, but I'ld have to ebay the porno red interior.
I was just kidding........
Unless your reasonable involves lots of zeros in front of a deciminal point behind a nice 6 or 7.....
I might sell it for what I have in it....
And I wouldnt mind an LS1/T-56......
Car: 2000CamaroSS,69 Camaro SS,91 Camaro
Engine: 383
Transmission: TH 400
Axle/Gears: Stock
Full Motor,trans,converter,driveshaft.$1000
305 TPI full dressed motor for the exception of A/C and pullies. Distributor down to oil pan, plugs wires. Comes with 700 r4 tranny,converter and driveshaft.
I have replaced...
Injectors with the Accel 19lb
New GM fuel rail
BBK fuel pressure regulator
GM distributor
Rotor
Cap
Plugs
Wires
Upper and lower intake gaskets
Rear main seal
PCV
O2 sensors
EGR
Vaccum lines and hoses
Valve cover gaskets
Throttle body gasket
It's only a 305 but is a strong runner with only 69,000 original miles on the trans, motor, converter,driveshaft. Ready to wire and fire. If you have any questions feel free to call me at 847-489-1982
Mike
I have replaced...
New GM fuel rail
GM distributor
Rotor
Cap
Plugs
Wires
Rear main seal
PCV
O2 sensors
EGR
Valve cover gaskets
Mike
Car: 1986 Z28
Transmission: T5 WC
Originally posted by Mojave
I have a SD 305 TPI setup I will sell you, with the rest of the car ....
Now Chad, say outloud, "I wouldn't mind winning the lottery!"
You're 2 for 2 so far!
Terrell351
Jun 13, 2021 01:13 PM
Sanjay
Aug 12, 2015 03:41 PM
