Parts Wanted 2006 Looking for something in particular? Ask here.
I need some connectors and leads...
Old Apr 28, 2005 | 11:31 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I need the wires and connector for the fuel pump relay and the fan relay for a 88 305 TBI car. I am pretty sure that any 88-up fuel injected car has the same relay and wiring. I would like as much wire as possible coming off them.
I cut these awhile back. Now my blower motor will not function. Spliced them back on and it still won't work. I cut real close...so I think I cannot get a good connection.
Let me know if you have these. Make an price I suppose.
Old Apr 29, 2005 | 10:11 PM
Slow88lb9's Avatar
Car: 88 Iroc 91 Z28
Engine: 5.0 LB9
Transmission: WC T5 / 700R4
Axle/Gears: 10 bolt 3.73
I have i complete TBI harness i don't want to cut it up but give me $35.00 i will send it to you and you can do whatever you want to it.
Old Apr 30, 2005 | 12:26 AM
Transmission: 4l60e
35$ shipped or plus shipping?
I may take the offer I will let you know.
Old Apr 30, 2005 | 03:39 AM
Slow88lb9's Avatar
Car: 88 Iroc 91 Z28
Engine: 5.0 LB9
Shipped
Old May 1, 2005 | 10:56 PM
Transmission: 4l60e
I will let you know about the harness in a couple days.
Does it still have the black cover on it?
Old May 2, 2005 | 01:46 PM
Slow88lb9's Avatar
Car: 88 Iroc 91 Z28
Engine: 5.0 LB9
yes sir
Old May 2, 2005 | 02:27 PM
Transmission: 4l60e
Do most of the connectors and stuff look OK?
I am going to get it and strip everything I know I do not need.
BTW how hard is it to remove a wiring harness from a thirdgen?
Old May 2, 2005 | 03:58 PM
Slow88lb9's Avatar
Car: 88 Iroc 91 Z28
Engine: 5.0 LB9
the harrness came from a running car.i switched one over to TPI and this is the tbi harrness i took out.Its not to bad to change if the fender is off but it can be done with the fender on.I think the only thing missing on this harrness is two ground wires were cut just need to put a new ring termanal on,And the back up light plug was removed also.
Old May 8, 2005 | 12:51 AM
Transmission: 4l60e
Hey is it just the engine harness? Or is it everything? It doesn't have the wires going into the fuse box and stuff does it?
Can you e-mail me at camarosportcoupe@yahoo.com because I am probably going to buy it from you. I screwed mine up bad and I cannot get the heater and AC working. So I am going to buy the harness from you and go from there.
Old May 9, 2005 | 03:52 PM
Slow88lb9's Avatar
Car: 88 Iroc 91 Z28
Engine: 5.0 LB9
email sent
Old Aug 16, 2005 | 09:10 PM
RS1992's Avatar
I want this harnesss if you still have it. E-mail me at redblazerx@yahoo.com
I actually need the harness that goes to the blower motor and all the coponents around that or connected to that.
Old Aug 17, 2005 | 01:35 PM
Slow88lb9's Avatar
Car: 88 Iroc 91 Z28
Engine: 5.0 LB9
E-Mail sent
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
